Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 06-14-2001, 12:19 PM   #1
webkris
Member#: 70
I sold WRX to buy
Dodge Neon Rally Car
Exclamation Attn: Whiteline Adj. Sway-bar owners!
Did you know about this??
Please check to make sure - this looks like a dangerous condition with the brake lines being rubbed.
http://members.iweb.net.au/~seajen/techSway.html
If this is "old news" let me know. I have not heard of it, and I know a lot of you guys have these.
- Kris
webkris is offline   Reply With Quote
Old 06-14-2001, 12:34 PM   #2
stumpz
Member#: 3348
2013 Polo TSi
Red
Post
Just put mine in last week. I'll have a look and keep you posted.
Thanks for the info Kris
Suresh
stumpz is offline   Reply With Quote
Old 06-14-2001, 03:26 PM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
I gotta check it out. When I installed it, I didn't notice the bar touching anything on the car though.
tmat3 is offline   Reply With Quote
Old 06-14-2001, 03:36 PM   #4
Hozay
Member#: 1248
04 Impreza WRX STi
Java Black Pearl
Post
looks like the problem only exists for those using the 22mm setting... im still learning 18mm ^_^
thanks for the heads up!
Hozay is offline   Reply With Quote
Old 06-14-2001, 03:41 PM   #5
imprezadan
Member#: 6935
1999 Impreza 2.5RS
Rally Blue
Post
Wow, glad I bought a regular 20mm bar from Bryan at a&b performance instead!
imprezadan is offline   Reply With Quote
Old 06-14-2001, 05:47 PM   #6
Jim Gurieff
Member#: 389
Post
Hi everyone.
Around 18-24 months ago we had some adjustable rear bars (22mm) slip through with 5mm extra length in the blade end.
When run on maximum adjustment and driven hard, the end of the bar could intermitently touch the brake mount support and hose.
The stock was isolated and rectified well before it became a major problem. Please contact your distributor or Whiteline direct if you have any concerns. There is some information and pictures available on the WRXSA site located at http://members.iweb.net.au/~seajen/techSway.html
Cheers
Jim Gurieff
Whiteline Automotive www.whiteline.com.au
Jim Gurieff is offline   Reply With Quote
Old 06-14-2001, 07:15 PM   #7
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Post
Wow, pretty cool customer service.
Good thing they are on top of things, and helping to rectify the problem, instead of pulling a "Pinto".
Paul G.
paultg is offline   Reply With Quote
Old 06-14-2001, 07:43 PM   #8
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
Post
Looks like the brake line mount could be moved forward a tad, with out breaking into the line. 4x4 guys do it all the time. The hard line is steel and can be bent ever so slightly. I've re-run new lines a million times, some times bent by hand and sometimes with a tube bender. In this situation it looks like it would be harmless to un bolt the mount, drill 2 new holes an inch forward, push the mount forward, put screws back in new holes.
If anyone finds their brake line cuts like this picture, REPLACE THEM and don't forget to bleed them.
Chris N is offline   Reply With Quote
Old 06-14-2001, 07:52 PM   #9
stumpz
Member#: 3348
2013 Polo TSi
Red
Post
Checked mine. According to my brother no problems. Running on 18mm setting.
Applaud Whiteline for being honest regarding this matter
Suresh
Old 06-14-2001, 07:59 PM   #10
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Post
Jim, Bob, Wojtek@Whiteline,
Any info on whether that affects the Legacy?
Mine is too new (only bought a couple of months ago), but I am sure there are more out there...
Cheers
anotherB4 is offline   Reply With Quote
Old 06-15-2001, 07:28 PM   #11
Hozay
Member#: 1248
04 Impreza WRX STi
Java Black Pearl
Smile
seems like a good reason to get Stainless Steel Brake lines... that would fix it, right?
Whiteline Adj Sway bars and endlinks, H6 rear setup/ power slot, Hawk HT10 and HPS lemon19mmm Suspension/Brakes/Handling 9 12-30-2009 04:42 PM
Attn: Whiteline sway bar owners Scoobyap1 Brakes, Steering & Suspension 13 04-01-2009 10:15 PM
Whiteline Rear Adj Sway bar for 02-03 tm999xxx Private 'For Sale' Classifieds 15 11-18-2003 10:55 AM
Brand New: Whiteline rear adj. sway bar w/end links RED WORKS(WRX) Bay Area Impreza Club Forum -- BAIC 0 12-17-2002 07:56 PM
Whiteline Adj. Sway Bar Settings HondaH8er Brakes, Steering & Suspension 6 12-31-2000 06:53 PM
