Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 10-16-2008, 05:42 PM   #1
00boostedRS
Member#: 115317
1992 Legacy SS
Default 92 Legacy EJ22T downpipe question
Does anyone know if an aftermarket down pipe made for a WRX will work without mods on a 92 turbo legacy?
00boostedRS is offline   Reply With Quote
Old 10-17-2008, 12:50 AM   #2
RallyColtTurbo
Member#: 16819
It will bolt up fine to the turbo and Transmission drop bracket. It is longer however.
From left to right.
USDM WRX 3" bellmouth, USDM WRX cat-less upper-downpipe, stock USDM WRX, stock '93 Legacy turbo (possibly the same as JDM WRX).
RallyColtTurbo is offline   Reply With Quote
Old 10-17-2008, 08:55 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
should have tagged them 02-07 usdm wrx dps
as i believe a 92-03 jdm wrx dp is the right length
Old 10-17-2008, 03:10 PM   #4
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
Yea, I agree with jax, looks just like my JDM WRX dp.
fishheadback is offline   Reply With Quote
Old 10-17-2008, 04:37 PM   #5
RallyColtTurbo
Member#: 16819
done.
Old 10-17-2008, 05:56 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you need the years as an usdm 08-09 wrx dp is even longer like the 05+lgt
<--nerd
Old 11-13-2008, 09:43 PM   #7
Nick Boxler
Member#: 180326
2005 WRX
HTA68'ed San Remo Red
what happens if you bolt up a WRX downpipe, to a WRX exhaust on a 91 Legacy SS?
Nick Boxler is offline   Reply With Quote
Old 11-14-2008, 12:46 AM   #8
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Too short.
damonmlime is offline   Reply With Quote
Old 11-14-2008, 03:48 AM   #9
RallyColtTurbo
Member#: 16819
page 3.
http://bbs.legacycentral.org/viewtopic.php?t=35213
Old 11-14-2008, 08:04 PM   #10
turbo_legacy
Member#: 164442
1993 legacy ss
winestone metallic
when i did mine on my legacy ss they had to cut the wrx pipe to fit.
turbo_legacy is offline   Reply With Quote
Old 11-15-2008, 12:40 PM   #11
Nick Boxler
Member#: 180326
2005 WRX
could you just make the catback shorter rather than cutting up the DP?
because my buddy wants to just use a WRX catless dowpipe, and then get the "catback" made at an exhaust shop.
Old 11-15-2008, 06:09 PM   #12
RallyColtTurbo
Member#: 16819
That's exactly what I did. No need to touch a WRX downpipe, only the cat-back. And you need to extend the Cat-back, not shorten it.
Old 11-15-2008, 08:36 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Originally Posted by RallyColtTurbo View Post
My thread is betterer.
Old 11-16-2008, 06:04 PM   #14
kingston
Member#: 25079
1987 Subaru GL
rust blue
can't you just leave it short and have the pipe slightly under the bumper or is it the hangers that don't line up?
kingston is offline   Reply With Quote
Old 12-10-2008, 11:22 PM   #15
soober_sean
Member#: 193374
2002 wrx 2.5L
they have one on legacygt the forums i for got where on there i saw it and how much but i know it was a pretty good price. sorry i couldnt be more specific
soober_sean is offline   Reply With Quote
Old 01-12-2009, 07:23 PM   #16
Nick Boxler
Member#: 180326
2005 WRX
we put a stock wrx downpipe on my buddies TLeg last weekend. then he got the catback built at a shop for like 190 bucks. way good deal. and then he is going to be able to bolt up a wrx catless downpipe to that.
Old 01-16-2009, 05:00 PM   #17
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
the flange angle might be off on the dp, mine hit my axel
i cut the midpipe and bent it at adifferent angle, if your stock dp back, it's way to long, if you can use a rex aftermarket dp back youll only need to lengthen it 3-4 inches
put in the dp, and take it to a shop
unless u can weld
Joynt93 is offline   Reply With Quote
Old 01-19-2009, 08:18 AM   #18
GodSquadMandrake
Member#: 175435
1986 RX7
Sunrise Red
I put the Nvidia V3 bellmouth for an 04 WRX on my 91 Tleg. It sits a little low. I also had to extend the wires for the oxygen sensor, no biggie.
GodSquadMandrake is offline   Reply With Quote
Old 01-19-2009, 01:06 PM   #19
Boost2the_moon_ej20
Member#: 112782
I ended up using a megan racing dp for a wrx, and an spt catback. The only mods I made were adding a section of pipe (with flanges) that went from the dp to the catback. I then heated/bent the hangers on the can to reposition them and tuck nicely under the bumper. The slant tip on the spt pretty much lines up evenly with the bumper.
Boost2the_moon_ej20 is offline   Reply With Quote
Old 01-19-2009, 04:37 PM   #20
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Anybody know of companies that sell direct fit catless downpipes for ej20g?
blkgm8 is offline   Reply With Quote
92 Legacy BF/BJ, EJ22T boomer3 Legacy Forum 4 07-23-2008 01:03 PM
92 legacy - couple of questions tappets Legacy Forum 6 01-22-2007 05:45 PM
92 Legacy Climate control question? Dealer Xing Legacy Forum 3 11-27-2004 12:27 AM
WTB: ej22t for 92 Legacy NGTD Private 'Wanted' Classifieds 1 10-04-2004 09:28 PM
WTB: ej22t for 92 Legacy NGTD Canada Region Forum 3 10-02-2004 10:10 PM
