Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 10-16-2008, 07:04 PM   #1
00boostedRS
Member#: 115317
1992 Legacy SS
Default 92 legacy turbo trouble shooting question
Im having an issue with my legacy starting. It cranks over but doesnt fire up right away, I crank it over probably 5-8 times and pump the accelerator before it finally kicks over and starts. Does that sound like a FPR problem? or a MAF problem? Once it starts it runs fine, so because of that Im pretty positive its getting enough spark. Any help would be much appreciated.
Thanks,
Grant
00boostedRS is offline   Reply With Quote
Old 10-17-2008, 12:01 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
How long have you had the problem? Do you have a hard time starting all the time, or only when the engine is cold or hot?
Hard starting issues on the first gen legacy while the engine is either cold or hot are typically caused by a faulty/old coolant temp sensor.
Legacy777 is offline   Reply With Quote
Old 10-17-2008, 02:40 PM   #3
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
possibly your fuel pump is on it's way out
www.legacycentral.org
Joynt93 is offline   Reply With Quote
Old 10-20-2008, 12:45 AM   #4
00boostedRS
Member#: 115317
1992 Legacy SS
yeah its been hard to start real regularly, a buddy told me it could be a few things. the CEL light has been coming on and off also. at this point I too think its a fuel pump issue. i replaced the o2 sensor because i was getting 200 miles to a full tank. i was told that a corroded ground on the fuel pump might be to blame. that sound like a possibility?
Old 10-20-2008, 12:21 PM   #5
Legacy777
Member#: 4800
First thing you should do is check the ECU for codes. You could be chasing your tail or going in the wrong direction. See what codes come up on the ECU.
Instructions to pull the codes are on my site
www.surrealmirage.com/subaru/engine.html
Old 10-21-2008, 11:26 PM   #6
ultrasonic
Member#: 18006
Why spend time guessing? Why ask the forum? Ask the car! It's trying to tell you something....
Pull the code. Tell us what you find.
ultrasonic is offline   Reply With Quote
Old 10-22-2008, 02:28 AM   #7
gene4ace
Member#: 108210
yup cheack for voltage at fuel pump, and check for resistance across the fuel pump, from fuel pump to ground and also check the fuel pressure
fyi also check the fuel pump relay
gene4ace is offline   Reply With Quote
Old 10-23-2008, 06:29 PM   #8
00boostedRS
Member#: 115317
1992 Legacy SS
I pulled 9 different codes from the ecu, apparently water got into the harness when the motor was cleaned so the ECU was fried. All the sensors and fuel pump checked out fine. Apparently 1 out of 10 cars this happens to. Is there a better way to clean the motor with out this happening again?
IC Spray Setup Questions for a 92 Legacy Turbo smh0101 Water/Methanol Injection, Nitrous & Intercooler Cooling 8 04-26-2008 12:25 AM
93 impreza + 92 legacy turbo = ??? Ru fan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-26-2001 05:19 PM
0-60MPH time on 92 Legacy turbo!! Ben Legacy Forum 1 04-02-2001 07:20 PM
0-60mph time on 92 Legacy turbo!!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-02-2001 05:55 PM
G-tech Pro Result on 92 Legacy Turbo!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-02-2001 09:31 AM
