Old 10-16-2008, 10:59 PM   #1
PhastEddie
Member#: 136545
2006 Evolution IX
Default Just returned car to stock, LOUD annoying squealing sound under boost!
Ok, I swapped back the stock exhaust manifolds, stock turbo, downpipe blah blah blah. Car is now back to stock and I get this loud shrieking noise which seems to appear when the car hits boost. I had my wife in the car rev the motor up to the point where it started squealing as I had the hood open and walked around the car. It seemed loudest near where the uppipe meets the exhaust manifold. And it is so loud it actually hurts my ears when I am their listening for it. Now, I originally thought it was a bad turbo, but I have since changed the turbo, and still the same result. So do you guys thing its an uppipe leak where it meets the exhaust manifold?
PhastEddie is offline   Reply With Quote
Old 10-16-2008, 11:03 PM   #2
Forbidden
Member#: 173244
2016 WRX
blue
did u put new gagskets on...? or copper spry the old 1's? thats your problem.
Forbidden is offline   Reply With Quote
Old 10-16-2008, 11:04 PM   #3
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
you have a leak... High pitched whistles in my experience are typically post turbo. If you think its on the exhaust side, put some tape over the connection and drive the car. Pull the tape off and look for carbon...
gto7419 is offline   Reply With Quote
Old 10-16-2008, 11:05 PM   #4
Arctic Penguin
Member#: 119532
2006 WRX
no doubt...up leaks do this
Arctic Penguin is offline   Reply With Quote
Old 10-17-2008, 07:23 AM   #5
PhastEddie
Member#: 136545
2006 Evolution IX
That is a very good point, but I have proven a long time ago that new gaskets arent always necessary. I have used the same gasket 5 times over with no leaking issues. I guess they won't work 6 times???
Old 10-17-2008, 07:24 AM   #6
PhastEddie
Member#: 136545
2006 Evolution IX
That is what I am thinking. It sounds like its coming from around the 02 sensor area, I will check it out tonight.
Old 10-17-2008, 02:58 PM   #7
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Definitely an uppipe leak, they shriek like mad.
twizzstyle is offline   Reply With Quote
Old 10-17-2008, 07:36 PM   #8
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
^+123456789 on the uppipe leak.
Use the copper spray gasket stuff.
paintbing is offline   Reply With Quote
Old 10-17-2008, 09:23 PM   #9
PhastEddie
Member#: 136545
2006 Evolution IX
That is what I always use. I did notice that it seemed that the uppipe was tightened more on the top then the bottom, which would only mean to me that the manifold was at a tight angle when I tightened it before. This time, I loosened all the manifold bolts so that the exhaust manifold was loose. Then tightened the uppipe bolts first so that it would seat flush. Then I tightened the manifold bolts. It sounds nice and quiet now.
Loud Pssssssssssssssssssssh Sound Under Boost lordizzy626 Newbies & FAQs 11 03-12-2010 09:10 AM
returning car to stock.. parts for sale pending replacement... gotboost06 NWIC Private Classifieds 21 01-31-2009 09:34 PM
Loud squealing/buzzing under boost. tube Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-07-2008 02:52 PM
SO-CAL : Returning car to stock sale afro Private 'For Sale' Classifieds 53 10-13-2005 08:52 PM
returning car to stock...lots of stuff FS... ron_c1 Bay Area Impreza Club Forum -- BAIC 49 11-20-2003 12:21 AM
