Old 10-17-2008, 08:56 AM   #1
05subylah
Member#: 132143
2005 Impreza RS
Default Help! Car will not move
Here is my problem:
I go out and start the car (05 RS, 85000 miles, manual) and hold the clutch in for a second while the car is in neutral. When I let the clutch out, while in neutral, it lurches forward and stalls out. I try and again and does the same thing. It acts like it is in gear but is really in neutral. When I put it in any gear, it tries to move, but will not move more than an inch, no matter what the gear. It stopped when the hint of a smoking smell started. My first impression is the clutch, since it has not been replaced but I could very be wrong. Also, I have had trouble the last few weeks putting it in first gear when I need to pull away from a stop. What do you all think? Thanks for any help.
Luke
05subylah is offline   Reply With Quote
Old 10-17-2008, 09:10 AM   #2
alexjander
Member#: 176630
2002 WRX Wagon
Have you gone in the engine bay and confirmed that the car is indeed in neutral? Can you feel it going through the gears?
Could be a disconnect between the shifter and the actual transmission, so you think it's in neutral, but it's not.
alexjander is offline   Reply With Quote
Old 10-17-2008, 09:10 AM   #3
Spootypuff
NASIOC SUPER Supporter
n00b jesus
Member#: 200000
2012 Wrangler
Yea go try that ^^^
Spootypuff is offline   Reply With Quote
Old 10-17-2008, 09:13 AM   #4
05subylah
Member#: 132143
2005 Impreza RS
I can feel it going thru the gears, but will check the engine bay when get home tonight. The clutch does not slip though, so I am lost.
Old 10-17-2008, 09:15 AM   #5
Schniz
Member#: 158349
e-brake
Schniz is offline   Reply With Quote
Old 10-17-2008, 11:58 AM   #6
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Originally Posted by Schniz View Post
e-brake
bingo!!!!
Probably stuck...
4wdrift is offline   Reply With Quote
Old 10-17-2008, 12:29 PM   #7
05subylah
Member#: 132143
2005 Impreza RS
I have searched and I think it is a broken or bent fork in the tranny. If it was the e-brake then the car would not stall in neutral with the clutch out.
Old 10-17-2008, 12:35 PM   #8
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
I would think bent fork as well...
gto7419 is offline   Reply With Quote
Old 10-18-2008, 03:16 AM   #9
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Impreza GC8
True...
Car will not move in any gear WRteXan Transmission (AT/MT) & Driveline 2 01-07-2010 08:46 AM
Help! Car will not crank. Sounds like a machine gun. em199si Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-02-2007 04:16 AM
Help. Car will not return to idle... LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-09-2005 11:49 PM
need help car will not fire 387hardcore Pre-2002 Factory Turbo Powertrain 2 05-03-2004 12:58 AM
need help car will not run 387hardcore Tri-State Area Forum 20 03-22-2004 01:29 PM
