Old 10-19-2008, 03:02 AM   #1
Hardline
Member#: 187001
Question Big project underway, need advise
I am in the process of doing a engine/driveline swap for a friend of mine into a 95 Legacy. The Engine is a Japanese EJ20, which is being converted to single turbo, and the transmission is a 5-speed AWD unit that came attached to the engine. Fuel management is being handled through a Megasquirt with Ford's EDIS ignition system. My question is that the rear differential was not included with the other parts, and I need to know the final drive ratio needed to find a suitable replacement. The Legacy had an automatic transmission prior to beginning the swap. Any input would be greatly appreciated, as Google has once again proven to be of no assistance. Thank you.
Hardline is offline   Reply With Quote
Old 10-19-2008, 08:48 AM   #2
John*G
Member#: 19562
95 coupe
red
You could try this to reference your transmission code, or call a dealer with the tranny number and ask.
http://www.i-club.com/forums/showthr...r+ratios+stock
John
John*G is offline   Reply With Quote
Old 10-19-2008, 01:42 PM   #3
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
elislider is offline   Reply With Quote
Old 10-20-2008, 12:05 AM   #4
Hardline
Member#: 187001
Thanks guys for the replies. I have one last question...... Where would the transmission model number be stamped into the case. It is in the low 40s right now, and I really don't want to crawl around in the cold looking for this number....... Thanks
Old 10-20-2008, 08:54 PM   #5
elislider
Member#: 133923
03 Legacy GT wagon
its on a paper sticker IIRC
Old 10-28-2008, 10:33 PM   #6
Hardline
Member#: 187001
ty752vbcaa was the tranny code. I found out it uses a 4.44:1 FDR, and the Diff on the car is a 4.11:1. Wont work. Does anyone know where I can find one that will work?
Old 10-29-2008, 10:17 AM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
4.44's are pretty hard to come by if you want a rear LSD. If you are willing to forego the LSD, they were in a number of the auto tranny Foresters and Legacy Outbacks in US cars starting around 2000.
Old 10-29-2008, 11:10 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
just source a 4.44 from an auto...the diff you have now isn't LSD...buying an LSD and installing would be a nice upgrade and would save a bit of time.
Old 10-30-2008, 09:04 PM   #9
elislider
Member#: 133923
03 Legacy GT wagon
you can get a 4.44 rear LSD from an 00/01 USDM 2.5RS. also some legacies and foresters have them too. make sure you get the right axles though, because the legacy subframe changed in 01 and the axles changed along with, however the impreza didnt change and neither did the forester, until 02 (IIRC). all i know is that the axles can be a pain in the ass if you dont get the right ones. to speak the obvious, you will need axles that match the diff on the diff side and the hubs on the hub side, however the hub splines changed around 96ish and then again in 01/02 for legacies and then others. so just be careful
try www.car-part.com and search for Carrier part (thats what the rear diff is called)
also reference this page:
http://wac.addr.com/auto/obs/lsd/lsd.html
Finance or Loan? No previous credit history, big down payment. Some advise please. NJ EsTeaEye General Community 33 02-28-2008 08:52 PM
BIG project...ideas and thoughts please edaniele1212 Off-Topic 5 05-09-2005 02:18 PM
Swap underway, need sway-bar help… xcntrk75 Subaru Conversions 5 03-29-2005 11:25 PM
New project underway, most of you should like this...... SubyNewbie Mid Atlantic Impreza Club -- MAIC 11 11-22-2002 08:52 AM
96 To 2000 Model, Big Project! LarryMak Interior & Exterior Modification 15 06-03-2001 11:00 AM
