Old 10-19-2008, 10:06 AM   #1
fpan
Member#: 146900
2007 WRX wagon
Urban grey
Default Replacing airbag OE seats - airbag light on?
Hello guys,
I am thinking of replacing the seats in my 2007 WRX wagon with some Recaros. The problem is that the original seats have got side airbags so I am wondering whether replacing them with non-airbag ones will cause the LED on the dashboard to stay on?
What have you guys done?
Thanks a lot for your help,
Fivos
fpan is offline   Reply With Quote
Old 10-19-2008, 10:19 AM   #2
MD04WRX
Member#: 72891
2004 WRX SDN JBP
96 SVX -2012 Fiesta
Subaru Banner
The airbag light will come on if you replace the seats. There are a number of threads on the issue (search and you'll find everything you need). On my 04 it was easy to turn off the light, but your car has seat position sensors and the passenger seat has a weight sensor.
MD04WRX is online now   Reply With Quote
Old 10-19-2008, 11:44 AM   #3
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
if you get a 3.3ohm resistor it will go away.
D Money is offline   Reply With Quote
Old 10-19-2008, 03:10 PM   #4
subaru3169
Member#: 55252
* pullup bar *
resistor
subaru3169 is offline   Reply With Quote
Old 10-19-2008, 10:06 PM   #5
TRooper
Member#: 62422
2006 Lotus Elise
1.8L of Fury!!
Originally Posted by subaru3169 View Post
resistor
Shame on you guys, I would expect more accurate answers from "Gurus".
Unfortunately, resistors alone will not fix this issue. As MD04WRX mentioned, you will need to swap over the passenger side "passenger detection bladder" and the driver side "seat position sensor". This applys to 06/07 WRX/STi owners. Here is a tutorial I made on the bladder swap.
06/07 passenger detection system swap
TRooper is offline   Reply With Quote
Replaced wheel studs, now ABS light on...Arghh wadejg Brakes, Steering & Suspension 5 06-29-2010 01:21 PM
ABS, Airbag, and Rear Diff light on after washing engine Acejam2k Factory 2.5L Turbo Powertrain 6 06-02-2010 12:32 PM
AIRBAG light on with sti 2004 seats in wrx 2004 ? WRick Electrical & Lighting 0 03-31-2006 10:11 AM
Airbag light on after new seat install? jikhead Interior & Exterior Modification 35 06-21-2005 07:27 PM
Airbag light on with sti seats? dgp Interior & Exterior Modification 10 11-04-2002 12:48 PM
Message Board Statistics All times are GMT -4. The time now is 10:08 PM.
