#1 |
Member#: 38629
NWIC
Vehicle:1999 Legacy GT (STI) White |
I took my car to Pacific Raceways last week.
My car and another owner with an 04 WRX had EGT temps in the 1650 range. I think I hit 1680 once. Is this normal? What have other seen? Both of us are running one high flow cat I believe. What can we do to lower temps?
#2 |
Vendor
Member#: 88346
Vehicle:3108 A St SE Auburn WA 98002 |
That seems normal for a lapping day doing 150+ down the straight.
Add fuel to lower the temp. |
#3 |
Member#: 73072
NWIC
Vehicle:02 wrx, 04sti WRB squared! |
It really depends on where in the exhaust your egt sensor is located. 1650 is a normal temp to read if your sensor is located in the header manifold. you should read around 1400 if it is in the up pipe. much more than that and you could be running a lean.
#4 |
Member#: 164362
NWIC
Vehicle:2004 STi Black |
1650 is okay as long as the sensor is within 6 inches of the exhaust port. I had mine hit almost 2000
when my fuel pressure dropped off running 30psi on a Red. Thank goodness for forged pistons! |
#5 |
Member#: 68516
NWIC
Vehicle:2002 325i 2005 R6 R.I.P. MasterTuned© |
When I was at my last lapping day at Bremerton I hit 1700 a couple of times. Mostly only got 1650. Probe in manifold
Everything felt normal, no knock or stutter or anything (per log data from UTEC) |
#6 |
Member#: 63767
NWIC
Vehicle:2009 OXT 5-spd 2011 STi hatch |
I have got close to 1700 before during laping days. The last two I did was with a track map Tim Bailey built for me. I saw about 200 degree lower EGT temps with this map.
#7 |
Member#: 132286
NWIC
Vehicle:2006 STI sgm |
My sensor is welded in the header collector, I set my EGT alarm for 1650 and it went off once climbing the pass on the cascade loop run.
| Thread Tools | |
| Display Modes | |
| The " DUDE have you seen the OHLINS sales at Racecomp?.." sale !! | RaceComp Engineering | MAIC Vendor Classifieds | 49 | 01-24-2009 05:18 PM |
| Hey middle of the country people... Have you seen any Cicadas yet? | Josey Wales | Off-Topic | 30 | 06-03-2007 01:07 AM |
| Bleed brakes at the track - what do you do with it? | chimchimm5 | Motorsports | 17 | 10-05-2006 06:28 PM |
| What have you seen a WRX scoupe on? | nomadtw | Off-Topic | 17 | 12-19-2004 10:46 PM |
| sad day at the track...Whats my problem. | beobe99 | Factory 2.0L Turbo Powertrain | 4 | 11-09-2002 03:20 AM |
