Old 03-20-2002, 11:54 PM   #1
Clegg
Member#: 7761
2008 VW R32 #3858
Default Level Ten 4EAT service Quote
I talked to Level Ten via email and got a quote to do a Valve Body, and Torque Converter work AT their shop ( drive out there chill for a few days and drive home).
Total was around 1900$ ( 700$ labor which is right on with what any local shop would want and possibly a hundred cheaper). with the Valve body being re-tuned, and the T/C being moved up 800 RPM for stall and keeping the full lock up capability. ( so you dont loose your gas millage on the freeway)
Clegg is offline   Reply With Quote
Old 03-21-2002, 10:05 AM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Re: Level Ten 4EAT service Quote
Well...
IIRC, Protorque's charge is $495 and L10 is $595 for the TC
The valve body was like $650? with $700 in labor... that's spot on.. so you save a hundred bucks going through protorque, but either way.... sounds good.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 03-21-2002, 04:14 PM   #3
IgotWRXed
Member#: 14868
2002 wrx
whats the pros and cons(if any) of getting a valve body? i was just gonna do the TC. well im prob just gonna have to, because i have no money jorge u ever have any track numbers of just the TC? or did u have the vf on before u got the tranny mods?
IgotWRXed is offline   Reply With Quote
Old 03-21-2002, 06:11 PM   #4
RobPA
Guest
Member#:
Pro-Torque does the TC's for level 10, so its not much differance whether u get it from level 10 or pro torque, other then about 70+ bucks
Old 03-22-2002, 10:27 AM   #5
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Just the TC.....
Low 16's.... <----> Mid 14's....
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 03-22-2002, 10:53 AM   #6
IgotWRXed
Member#: 14868
2002 wrx
WOW, this mod is definetely worth it. mid 14s is like a stock 5spd.
Old 03-22-2002, 11:09 AM   #7
Clegg
Member#: 7761
2008 VW R32 #3858
The valve body just keeps the line pressure real high through the entire power band giving you REAL fast and hard shifts. This will prolly wear the belts and clutch packs less since there isnt the gradual engagement ( in the loosest sense of the word, since stock shifts are still way fast) that rubs the belts and clutch packs before engage'n fully.
Jorge, How complex is the T/C install? I mean is it just dropping the tranny, and swapping it? If so I may just buy the T/C on my own, and when I get the group N engine mounts put on, I will see if Jeremy wants to help just pull the engine. ( can get some more stuff done rather easy then)
Anyone know how hard it is to remove a valve body and re-install it on one of our tranny's?
Old 03-22-2002, 12:21 PM   #8
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Doing a TC is as hard as doing a clutch...
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 03-25-2002, 11:24 PM   #9
nathman
Member#: 11787
2002 WRX wagon
Default AT Mods for dirt
A lot of my fun with my Auto WRX wagon has come from playing in the dirt, I absolutely love practicing the sliding turn out in the desert....thinking about trying a rallyX...would the T/C stall speed mod be a benefit to rallyX/rally type driving, or even an autoX, or is it mostly for launching?
nathman is offline   Reply With Quote
Old 03-26-2002, 12:06 AM   #10
IgotWRXed
Member#: 14868
2002 wrx
from my understanding, the TC will help you accelerate quicker in the low rpms, reguardless of how you are driving (i.e. launching, or just mashing the pedal) this would be an excellent mod for when you need to go fast quick, say after hitting the breaks going into a turn, and need to power out of it.
Old 03-26-2002, 02:15 AM   #11
PadreWRX
Member#: 5311
2004 GTO 11.2 @ 123
Was 4EAT '02 WRX 13.1@104
Default Re: AT Mods for dirt
I find the reponse on my new TC to be better all around in the low and mid-range. I've never autocrossed or rallied, but from daily driving, I think it would be a huge improvment. IMO.
Padre
PadreWRX is offline   Reply With Quote
Old 03-26-2002, 12:22 PM   #12
Torch
Member#: 10172
Has anyone done the Torque Convertor swap themselves? If so what was it like? Any special tools?
The reason I ask is because I dont want others working on my car if I can help it. I have swapped engines & transmissions before in f-body's but nothing import.
Torch is offline   Reply With Quote
Old 03-26-2002, 08:37 PM   #13
Clegg
Member#: 7761
2008 VW R32 #3858
I have not done one myself but I have heard numerous people say engine and tranny pulling in a subie is VERY similar to a domestic rwd car ( due to placement of the tranny in relation to the engine and such.)
IPT, Level Ten, and my 4EAT- the lowdown RiftsWRX Transmission (AT/MT) & Driveline 7 05-09-2005 10:25 AM
Level Ten VB - read if you have it! PeteDucati Transmission (AT/MT) & Driveline 21 10-07-2004 12:21 PM
Protorque or Level Ten? BCWRX Transmission (AT/MT) & Driveline 4 03-29-2003 09:30 PM
Pro Tech or Level Ten Torque converter? ImprezedRS Transmission (AT/MT) & Driveline 3 08-23-2001 02:11 PM
Level Ten transmission MikeYOX SVX Forum Archive 3 05-23-2001 05:47 AM
Message Board Statistics All times are GMT -4. The time now is 01:40 PM.
