Old 10-20-2008, 06:24 PM   #1
Bugeyeballa
Member#: 163662
2005 661+ AWHP STi
Mineral White Metallic
Default WRX Thermostat
Hey everybody I believe my thermostat has reached its final day.. I purchased a new one but not sure where it is or how to replace it, can anybody give me some help or link to a thread that has directions? its on a 2004 WRX
Bugeyeballa is offline   Reply With Quote
Old 10-20-2008, 06:48 PM   #2
mikeythejew
Member#: 141672
www.scoobymods.com is a great site for the backyard WRX mechanic.
Online Subaru service manual subscription from SOA, but will cost you $34.95 for a 72 hour subscription. http://techinfo.subaru.com/html/index.jsp
mikeythejew is offline   Reply With Quote
Old 10-20-2008, 08:36 PM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
well - you should purchase a new gasket as well. The gasket goes around the outside edge of the thermostat. The thermostat housing is what the lower radiator hose connects to - replacement is easy (after you drain the coolant) - remove the lower radiator hose (2 bolts), remove the thermostat housing, pull out the old thermostat, insert the new one (pay attention to the position of the jiggle valve), reinstall the cover, reinstall the lower radiator hose, refill with coolant, and off you go.
Definitely check out scoobymods
Old 10-20-2008, 09:16 PM   #4
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
^^^^^+1
Yeah, it's easy. Just don't forget to burp the cooling system <---- VERY important.
Spenk is offline   Reply With Quote
Old 10-20-2008, 10:20 PM   #5
2.2 awd
Member#: 120954
1991 subaru legacy
gray taupe
yes you must not forget to let the air out after you refill through the top radiator hose
2.2 awd is offline   Reply With Quote
Old 10-20-2008, 11:36 PM   #6
Bugeyeballa
Member#: 163662
2005 661+ AWHP STi
Thanks everybody, i am on my way out to the garage right now to try and fix this problem... I will let you know how its goes!
Old 10-21-2008, 05:36 PM   #7
Bugeyeballa
Member#: 163662
2005 661+ AWHP STi
Thank you everybody who helped, the subie is running well, it took a while to get the housing off and coolant went all over me but it runs good now so thank you :b anana:
wtb: wrx thermostat housing blueGC Private 'Wanted' Classifieds 3 02-14-2008 05:55 PM
NEW!!! WRX THERMOSTAT Genuine Subaru Impreza Turbo quick108 Engine/Power/Exhaust 3 01-13-2007 10:29 AM
Need WRX Thermostat info ? makofoto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-06-2004 12:03 AM
WRX Thermostat Housing vrg3 Private 'Wanted' Classifieds 2 02-25-2004 03:26 AM
WRX thermostat location gqzboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-18-2003 06:24 PM
