Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-20-2008, 09:04 PM   #1
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
Default What's this wire/sensor/plug? JDM v3 STi
trying to figure out some remaining wires on my v3 swap.
this wire comes out of the engine like so:
will update with more wire questions when i get to them
02/20/09 heres another im not sure about but it looks important
http://i43.tinypic.com/27yn5go.jpg
10/25/08: http://i35.tinypic.com/10newj4.jpg
it is a white wire with green stripe and 1 dot. it comes out of the coolant crossover tube, and i followed it all the way back up into the dash somewhere to a black plug with about 10 small pins.
elislider is offline   Reply With Quote
Old 10-20-2008, 09:49 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
ide bet coolant temp sensor, for the gauge. it dose not go to the ECU just up to the gauge in the I/P.
-=Suberdave=-
suberdave is online now   Reply With Quote
Old 10-20-2008, 10:20 PM   #3
elislider
Member#: 133923
03 Legacy GT wagon
thanks! ppl on rs25 said the same
got another one:
1 wire (no splits or joins)
on engine block harness it is green w/white stripe (i think)
goes to the main harness and changes to red with a blue stripe
goes straight up to the gauge cluster
when i traced that pin on the gauge cluster plug on the stock USDM 93 impreza cluster, it looks like its for the "defrost on" light, which doesnt seem to make any sense. is that right? or does the RHD/JDM cluster (old style impreza, not 2.5RS style) have something else in that spot? or are the wire trace paths different?
Old 10-21-2008, 09:42 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
oil pressure dummy switch?
Old 10-21-2008, 04:57 PM   #5
elislider
Member#: 133923
03 Legacy GT wagon
thats what somone on rs25 said, oil pressure sensor/light somethingorother, goes straight to instru panel, single wire
Old 10-21-2008, 04:57 PM   #6
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
[chris farley]that would be correct[/chris farley]
Hurley 2.5 WRS is offline   Reply With Quote
Old 10-22-2008, 09:41 AM   #7
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The RL wire for the oil pressure light has also been several other colors on the Version 3. On later JDM cars it is WR and on USDM it is either GW or GB. Either way it goes to the cluster. One more thing to note is that the older cars the temp gauge is two wire, one goes from the gauge to the sending unit and the other then grounds to the ECU via a sensor ground along with a couple other wires, usually RG.
One wire that you will not find much info on is the WL wire that runs to the cluster, this one is for a EGT warning light.
Z
Zephyr is offline   Reply With Quote
Old 10-22-2008, 12:29 PM   #8
elislider
Member#: 133923
03 Legacy GT wagon
Z
there was a white/blue wire in the ecu that on the charts i saw, it wasnt used in a swap, and IIRC its not on the ECU pinout diagram. is that what youre talking about? btw what does EGT stand for anyways
Old 10-22-2008, 03:15 PM   #9
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
WL=White/Blue. In the FSM Subaru indicates blue wires as L since B indicates Black.
EGT=Exhaust Gas Temp
Z
Old 10-22-2008, 05:55 PM   #10
elislider
Member#: 133923
03 Legacy GT wagon
oh ok im pretty sure i got that wire off and labeled. im at work now but ill check later probably
Old 02-20-2009, 02:09 PM   #11
elislider
Member#: 133923
03 Legacy GT wagon
got another one (noted in first post as well)
Old 02-20-2009, 03:54 PM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
where is it in the harness?
Old 02-20-2009, 09:21 PM   #13
elislider
Member#: 133923
03 Legacy GT wagon
near the dash / cluster / fusebox portion? i think? idk its been a while since i took that shot
Old 03-03-2009, 05:24 PM   #14
elislider
Member#: 133923
03 Legacy GT wagon
bump. nobody?
Old 03-03-2009, 06:05 PM   #15
MasterKwan
Member#: 98961
2003 WRX
Looks like a light sensor to me. My STI swap had a light sensor on the dashboard for the auto-ac.
Old 03-10-2009, 06:05 PM   #16
elislider
Member#: 133923
03 Legacy GT wagon
auto a/c? hmm.. there might have been another wire related to that too that i saw in the wiring diagrams... interesting.
Old 03-15-2009, 05:49 PM   #17
lele
Member#: 156792
94 Ver2 STI
pretty cool, what color does the V3 cluster illuminate?
lele is offline   Reply With Quote
Old 03-27-2009, 12:45 PM   #18
elislider
Member#: 133923
03 Legacy GT wagon
i didnt get a cluster with my engine. though i bought a JDM v3ish STi carbon-fiber-bezel cluster on ebay. I havent plugged it in but from what ive seen all the early jdm clusters, at least v1-3, illuminate kindof whiteish red
Old 03-27-2009, 01:57 PM   #19
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
wonder what color my V4 sti cluster will light up...
Rei_Akira is offline   Reply With Quote
Old 03-28-2009, 03:39 AM   #20
elislider
Member#: 133923
03 Legacy GT wagon
What's this wire? Tut4u2 Electrical & Lighting 9 08-28-2008 05:52 PM
SoCal: JDM v3 sti engine, tranny & powerfc for ej20k wal.lin 1993 - 2001 Impreza Specific Parts 15 03-03-2008 12:41 PM
What's this wire? jace2k5 Electrical & Lighting 10 01-07-2008 09:40 AM
'97 JDM WRX ECU -> '97 JDM V3 STi ECU Zora Subaru Conversions 8 08-01-2006 01:14 PM
What's this intake sensor for? Wombat North Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-01-2005 06:18 PM
