Old 10-20-2008, 09:19 PM   #1
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Default Offering help for Emanage Tuning
Mods, please don't move this as it only really applies to 93-01 Imprezas.
As some of you know I'm quite familiar with the e-manage, my last setup was an ej20 block, with 2.2 heads, delta regrind cams, 1.8 intake 370cc injectors, and 1.8 ecu. I was tuned up to 17psi before the td04l ran out of steam.
I have remotely configured a couple of E-Manages and would like to offer the same to others. Basically I'm not asking for money, (not that I would deny it) just wanting to help others get started. It takes about an hour or so which I connect to your laptop while you are in your car (wi fi needed of course) and I'll go over the settings and help you get started.
If you are in or around Vegas I would even help out with additional tuning.
Is this something anyone would be interested in? If so, PM or email me and we can set up a time. MOD's, if this gets enough interest, feel free to sticky.
Chad
www.uniquemotorsports.com
subachad is offline   Reply With Quote
Old 10-20-2008, 11:13 PM   #2
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
chad, get another subaru
mxpunk is offline   Reply With Quote
Old 10-20-2008, 11:30 PM   #3
Fail Wagon
Member#: 133584
i would love to. im in need of injector help bad. ej18 block ej22t heads td04 370cc injectors. whenever i wire the injectors in i cannot get the car to run right at all so for now im just running rich with the ecu controlling the bigger injectors draining my pockets... wanna help?
Fail Wagon is offline   Reply With Quote
Old 10-21-2008, 12:39 PM   #4
subachad
Member#: 8488
Teal
Yeah, you will need to set the injector sizing. On the emanage I tuned last night that was enough. On mine, I had to pull -35 from across the MAF table.
I can login to your laptop around 5pm Pacific Time M-F, email me to setup a time.
Old 10-22-2008, 03:03 AM   #5
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
wish you lived near me man. I'm gona be doin my EMU/turbo install this winter. and could TOTALY use some help from someone who knows thier head from thier ass with this thing...
IllNastyImpreza is offline   Reply With Quote
Old 10-22-2008, 01:06 PM   #6
subachad
Member#: 8488
Teal
When Subaru finally gets the FR Coupe launched... I'll be in the market for another Subie.
NastyImpreza, as long as you have a WIFI connection, I can login to your laptop while it's plugged into your car and help you get started with the Emanage tuning. That's the point of this thread.
Old 10-22-2008, 02:40 PM   #7
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
well, once I actually get an e-manage in and build up a motor, I will definitely be looking for some help. Perhaps by next spring....
EcksJay is offline   Reply With Quote
Old 10-22-2008, 03:54 PM   #8
#522
Member#: 2185
Awesome. this is pretty cool of you, subachad. I am in phx az and have put a bunch of info in a thread (http://forums.nasioc.com/forums/show....php?t=1575752) in this forum about install, but I have been working on the tune for a loooong time now. Car is very drivable and get's to 14 lbs of boost in 3rd and if I am in 4th, 18 lbs, but it my afr's are pretty inconsistent. I have the fuel trims fairly close, mostly +/- 3-4% but there are random 10%'s in obscure cells.
I have all the settings dialed in, but if you like, I can email you my most recent map so you could check it out. Or, let me know if you want to login remotely.
#522 is offline   Reply With Quote
Old 10-22-2008, 04:16 PM   #9
subachad
Member#: 8488
Teal
Sounds like you have it pretty well figured out. if you want to send me your map and also a log file of a 1st gear through 3rd gear pull, I'll check it out.
You might want to turn the boost down a little. I noticed I had to take away so much timing at 17+ psi that extra boost no longer gave me power. Once tuned at 17psi in 110+ degree heat, I dialed it back to 14psi to keep it safe.
Where are your "obscure" cells?
One thing to note is you can not subtract fuel using the fuel map, you have to subtract fuel using the MAP/MAF adjustment.
Old 10-22-2008, 05:46 PM   #10
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
remote access? crazzy I never even thought of that awesome. I will definatly hit you up once I've wired it all in. I was just given a laptop from a cousin who graduated college...but they took the harddrive out so I will have a laptop soon as I install one
Old 10-22-2008, 06:14 PM   #11
subachad
Member#: 8488
Teal
Yeah I have setup a few cars this way. Park within range of a WIFI spot, go to www.crossloop.com, download the free program and from the comfort of my couch, I can connect to your laptop while it's connected to your car. I can't do any road tuning for you like this, but I can help configure it and give you some pointers on tuning.
Old 10-22-2008, 06:21 PM   #12
#522
Member#: 2185
Well, you'll see when you see how my files are configured. I have the injector jumpers set to add and subtract. I have a complete EJ20G (motor, not ECU) in there with Sti side feed yellow tops, that thread I linked to has more details. So my IJ map starts around -40 and transitions into lower numbers as the boost RPM's increase. It idles like butter and drives pretty nice, but I guess I am uncertain what afr's I should shoot for in areas where the boost comes up faster than the rpms so I hit full boost before I would If I was launching and going through 1-2-3 gears.
The obscure cells I am referring to are on my factory ECU. I can drive around like I always do and never see a long term more that say -5. Then, if i coast in gear with just enough throttle to keep the injectors firing, I see a -10 here and there. I note what cells I'm in in tte ultimate, and accelerate and once I am back on them, the fuel trims are fine. It's something you would prob have to see while sitting in my car.
Also, do you use the speed correction map? If so, how do you have it setup? Dial the car in for 1-2-3 and then adjust the speed map for 4 and 5?
Anyway, I will email you the file I have setup and a screen shot that indicates some questions I have, easier with pictures.
Old 10-25-2008, 03:51 PM   #13
subachad
Member#: 8488
Teal
doesn't look like you need my help. Now unless something changed, I don't see how you are subtracting fuel using the injector map. The way it's wired in there is no way it can "pull" from the electric pulse, only add to it... that said it's possible newer versions are allowing fuel to be pulled by actually modifying the airflow map.
One thing I should have mentioned in my original post is how to determine knock. Here is an article that will help you build a damn good knock detector for $20.
http://www.autospeed.com/cms/article.html?&A=0353
Old 10-25-2008, 04:47 PM   #14
#522
Member#: 2185
haha, I'm always open for suggestions/information, so I'll send you what I got anyways, if you don't mind. Thanks for the link on the knock detector, I will be doing that soon since I am still pulling so much timing for safety.
But yeah, if you watch the INJ in and INJ out in the logging software, i see 1.4 in and about .8 out to accomodate my 440 injectors. if the car is running with my Scanner hooked up, you can enter -10 in the cells it's idling it and watch the fuel trims add 10 to make up for it. Maybe the 2.XX I have is different than the older versios.
Old 10-31-2008, 12:07 PM   #15
#522
Member#: 2185
I used that article as as a guide to build me knock detector with a similar device called "listen up" and shielded microphone wire and an alligator clip from Radio Shack. Works Awesome, thanks for that tip.
Old 10-31-2008, 12:39 PM   #16
Skidd
Member#: 1853
GC6 Supercharged
STM
Dang subachad.. that's a freakin' great idea!
Remote access to a laptop for remote tuning!!
I'm subscribin' to this thread!
Skidd is offline   Reply With Quote
Old 10-31-2008, 06:23 PM   #17
project_legacy
Member#: 114408
1999 Subaru Legacy L
30th AE Maroon
subscribed.
project_legacy is offline   Reply With Quote
Old 11-18-2008, 09:46 AM   #18
racerjon777
Member#: 145242
1994 Impreza L
EJ20K powered.
Any experience with LinkPlus?
I bought ai42's old 94 (you built the up and dp)
Here is what im running, minus the tons of susp/brake upgrades
EJ18 (stock engine, stock heads, stock everything)
TD04 Turbo (boosting at 12 psi)
Link Plus EMS (custom wired in, all functionality works, A/C works etc)
Legacy Turbo 370cc Injectors
2002 WRX fuel pump
Ebay special FMIC kit
TurboXS Bypass valve Type H34
Exhaust:
Subachad Up-pipe/Downpipe
Custom 2.5" midpipe w/ high flow catalytic converter
Blitz Nur Spec Axle-back exhaust
My current tune was done by Shawn, but its really really rich, and killing the MPG and im sure its robbing a few horsepower. Currently the boost is set at 14psi but it will soon go up to 15-17 once the new clutch is in. Any pointers/tips I should know about this setup? Ive been running the tune/setup for the past 90k miles (no exaggeration) and the only thing that ive had to replace was the turbo. It really says alot for the ej18 engine.
racerjon777 is offline   Reply With Quote
Old 11-18-2008, 03:29 PM   #19
subachad
Member#: 8488
Teal
yeah the ej18 is solid. As for the tune, can't really help you as I have only really messed with the E-Manage. The trick to MPG is to get your idle and cruise set to around 15:1.
Old 11-23-2008, 07:13 PM   #20
curjac
Member#: 188951
i have an emanage blue that i bought used and im wondering where the jumpers and rotary dials are supposed to be. i have a 96' impreza 1.8l. thanks
curjac is offline   Reply With Quote
Old 11-24-2008, 01:09 PM   #21
subachad
Member#: 8488
Teal
Here is the manual, this should help you considerably
http://www.mohdparts.com/emanage/man...ual/index.html
Old 04-18-2009, 07:43 PM   #22
Skidd
Member#: 1853
GC6 Supercharged
STM
Hey Subachad... I might have a challenge for you! You still up for helping out some Subies with EManages?
http://www.rs25.com/forums/showthread.php?t=92852
I'm expecting to finally have it installed tomorrow. It "should" be pushing boost into the system. I plan to try and setup a pretty fat and safe initial map, and attempt to make use of the LC-1 A/F unit too. But, I'm always ready and willing for a little more help.
Up to trying to remote tune for a SCd Impreza?
Old 04-28-2009, 07:59 PM   #23
subachad
Member#: 8488
Teal
I haven't been here in a while and I only miss a thread by a week... nice. SC RS, nice, wouldn't think tuning would be much different than turbo, same rules still apply. Your maps would just begin adding fuel earlier... then again around 2500 RPM the fuel and timing modifications are quite high anyway.
Old 04-28-2009, 09:59 PM   #24
Skidd
Member#: 1853
GC6 Supercharged
STM
It might be worth noting that I have an SRS-10 reflash too.
D'Oh!
Old 04-29-2009, 07:53 PM   #25
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
2012 Ford Fusion 6MT (DD)
This is great help! I'm trying to figure out what route to go for EMS with my hybrid setup. Right now I'm running off an OBD1 EJ22T ECU that gets me by and provides plenty of fun but I know the car needs a good tune. Do you see a lot of eManage's pass through your area? I might be interested in buying one that was programmed to get my car to run, then I could take it from there with the rest of the tuning process.
impreza_GC8 is offline   Reply With Quote
NJ: WRX STOLEN offering reward for help Sausage Tri-State Area Forum 24 02-04-2006 12:17 AM
NJ: WRX STOLEN offering reward for help Sausage Car Audio, Video & Security 37 02-03-2006 08:21 PM
FS:best offer takes Unichip with tuning software and tuning pots.. Boost_Junkiee Private 'For Sale' Classifieds 4 08-18-2003 09:21 AM
FS: Best offer takes Unichip with tuning pots and software... Boost_Junkiee Texas Impreza Club Forum -- TXIC 2 08-15-2003 10:47 AM
MRT in Oz offers free EcuTeK re-tune for 1 year if you upgrade with MRT parts Jon [in CT] Engine Management & Tuning 10 02-12-2003 06:32 PM
