Vancouver Impreza Club
Old 10-20-2008, 10:39 PM   #1
truenosan
Member#: 78893
2013 Scion
FRS
Default is a clunking sound normal after sway bar install?
there wasn't anything at first, but today as I was going over some bumps, it started to clunk. I just installed cusco sways over the weekend (big thanks again to ricewagon ) Went for the usual testdrive after, and everything was kosher.
But, when turning hard to 1 side and going in a circle, there would be a slight rubbing sound. We checked under the car again and there doesn't appear to be anything that looks like it is rubbing.
And now the clunking, I'm just wondering if this is normal?
TIA
truenosan is offline   Reply With Quote
Old 10-20-2008, 10:58 PM   #2
Zordos
Member#: 165121
could you have installed the bar upside down? when i installed my RT bar upside down it would rub on the lower control arm when i turned the steering wheel either way hard and got the odd clunking when going over speedbumps.
the ends of the sway bar should go under the lower control arm instead of over. i might still have some pics for visual aid if needed
Zordos is offline   Reply With Quote
Old 10-20-2008, 10:59 PM   #3
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Aside from making sure everythings still torqued down to the proper spec (important!!!), look for any signs of rubbing or wear on suspension parts.
My front sway bar rubs slightly on my tie rod when I'm making a very specific maneuver, I wouldn't have figured out what it was unless I noticed the small patch of paint that was rubbed off.
Splinter is offline   Reply With Quote
Old 10-20-2008, 10:59 PM   #4
NightHawk
Member#: 175181
not sure if its related but i noticed the same thing after installing a strut tower bar...
NightHawk is offline   Reply With Quote
Old 10-20-2008, 11:03 PM   #5
shum_87
Member#: 129898
2001 Impreza
I've experienced the same clunk noise..but never took care of it
suppose I should now.
shum_87 is offline   Reply With Quote
Old 10-20-2008, 11:41 PM   #6
truenosan
Member#: 78893
2013 Scion
FRS
i didn't torque down anything, I more or less elbow torqued it. Do you know where I could find the proper torque specs?
There are no signs of rubbing, thats why I'm totally clueless.
I'm pretty sure I didn't install it upside down. But I better double check.
Pretty sure that an installed strut tower bar should not have any clunking sound. there are no moving parts on it
Old 10-20-2008, 11:48 PM   #7
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
The kit should have come with torque specs on the instructions.
An overtorqued mount, for instance, could cause the bar to bind up and move in big jerks instead of smoothly.
Old 10-21-2008, 12:07 AM   #8
truenosan
Member#: 78893
2013 Scion
FRS
Thanks, I'm going to take a look at the instructions which I placed away nicely somewhere lol
Old 10-21-2008, 12:46 AM   #9
clsmooth
Member#: 86394
2000 RS Coupe
Blue Ridge Pearl
I have a Whiteline rear sway bar. When the car's on the ground, there's slightly less tension on the endlinks then when the car's in the air.
I have the 'fat' Whiteline endlinks. They jiggle in their brackets when going over small bumps. Normal in my case I guess. I'll eventually get around to getting some of their 'skinny' endlinks...
clsmooth is offline   Reply With Quote
Old 10-21-2008, 01:09 AM   #10
truenosan
Member#: 78893
2013 Scion
FRS
i have kartboy endlinks. boy what a difference just looking at em.
the stock endlink in the front was just pathetic.
and damn cusco bars, the instructions are all in japanese...
the only english part says "these parts are made for japan only, it must not be used in any other country"
Old 10-21-2008, 09:55 AM   #11
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
well thats your problem right there.
Japan probably has different gravity or something
Old 10-21-2008, 09:57 AM   #12
jaydow11
Member#: 138952
2011 STI Hatch
Pearl White
Dude, you need to torque those nuts down HARD or they are going to clunk like no body's business!
I went through this when I did my Whiteline sway install... Couldn't figure it out for the life of me....
I then replaced every single nut and bolt and torqued the crap out of them...
And oh sweet silence!
Also check your brackets that are connected to the frame. There were some nuts that were loose on mine that made the bracket move around and clunked... I kept thinking it was the endlinks....
jaydow11 is offline   Reply With Quote
Old 10-21-2008, 06:33 PM   #13
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Also you may have installed the end link on the wrong side of the sway bar?
Just ask Jay at Dale's he see's this all the time!
dasnowman is offline   Reply With Quote
Old 10-21-2008, 07:33 PM   #14
FIDS
Member#: 185128
2005 Stage 2 STI
+1 for "Dude, you need to torque those nuts down HARD or they are going to clunk like no body's business!"
I put 1 inche sway bars (by hotchkis) on the front and rear of my 04 and the drive initially was quiet but by the next morning they were clunking while drving straight. I talked with a service tech at Hotchkis and he recommended to tighten them right down and ignore the torque specs assigned. When the bars are created, the holes are made a little large to accomadate different setups so the torque is an unknown variable or recommendation.
So just crank down but be carefull not to break anything.
FIDS is offline   Reply With Quote
Old 10-21-2008, 09:19 PM   #15
Heavy Rippin'
Member#: 127648
99 Outback
Green
Grease!
Heavy Rippin' is offline   Reply With Quote
Old 10-22-2008, 12:27 AM   #16
truenosan
Member#: 78893
2013 Scion
FRS
funny how the clunking now is gone
Either way, I'm going to get at it and torque it down. I'm pretty sure they are on right. I'm going for an alignment on Sat anyways
Japan's gravity must be different !!
Old 10-22-2008, 08:52 AM   #17
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Go.
Necromancer is offline   Reply With Quote
what is a fair price to get the fount and back sway bar install ppericfe Brakes, Steering & Suspension 5 02-06-2007 03:28 PM
Wheel alignment required after front sway bar install? wrxrex Brakes, Steering & Suspension 1 11-29-2006 10:55 PM
sti rear clunk following spring/sway bar install waploom Brakes, Steering & Suspension 2 09-20-2004 03:08 PM
Is my front sway bar installed correctly? (pic) lupohki Newbies & FAQs 7 07-10-2004 01:03 PM
Is some Whistling Normal after Silicon IC Install?? WheelsCSM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-09-2003 10:36 AM
