Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 10-23-2008, 03:37 PM   #1
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
Default adding turbo on a 2.5rs, couple questions
so I am trying to do this cheap.
I can get stock wrx exhaust, intercooler, and a sti turbo for free.
I have 02 2.5rs.
It's going to be done by a shop, so to make it cheap and simple.
I would need a exhaust pipe L shape kinda? to connect the header up to the engine bay. customize the wrx stock downpipe to fit after the turbo[plug the o2 sensor hole].
bracket for securing the turbo. does the wrx oil pan fit the 2.5rs? so I can skip the drilling the pan and tapping for oil.
for boost, I suppose I can just use a MBC to set it to 5psi and call it a day??? or dropping in the wrx fuel injectors w/ fuel pump, and install the stock wrx ECU,would it work?
I know there is a lot more to it, such as oil line/coolant line.
qualityracer is offline   Reply With Quote
Old 10-23-2008, 04:31 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
reddevil is offline   Reply With Quote
Old 10-23-2008, 07:29 PM   #3
Arctic Penguin
Member#: 119532
2006 WRX
THIS one AGAIN???
Arctic Penguin is offline   Reply With Quote
turbo on a 2.5RS? BAMBOO Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-18-2007 12:13 AM
WRX TURBO on 04 2.5RS sanremors Normally Aspirated Powertrain 26 09-10-2004 12:23 AM
WRX Turbo on a 2.5RS. Parts Wanted. RyansJDMgc8 Normally Aspirated with bolt-on Forced Induction Powertrain 34 09-07-2004 12:52 PM
GSX turbo on a 2.5RS??? Impreza2.5 General Community 1 03-07-2002 03:56 PM
