Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 10-21-2008, 09:17 PM   #1
racer_x
Member#: 175722
Default Cooling system problem - car idles at 3k
Hey folks,
Sorry to make a post, but after reading through different threads, my answers are still unclear.
First off, this is a 2002 wrx with a JDM version 8 STi 2.0L swap.
Basically, my friend was driving when his lower radiator hose popped off, causing the car to (very) briefly overheat. He saw the steam, shut the car off, and we've been unable to burp the coolant system by any method and get the RPMs down below 3000.
I am reluctant to let the car idle for 15-20 minutes at a time because of the fact that the idle is so high.
Suggestions?
I'm guessing it's the air in the system that's making it idle so high, but we can't get it out for crap. Help!
Thanks guys
racer_x is offline   Reply With Quote
Old 10-21-2008, 09:29 PM   #2
racer_x
Member#: 175722
BTW, temperature gauge reads low when car is cold, heats up to normal temp.
Old 10-21-2008, 09:29 PM   #3
racer_x
Member#: 175722
is it possible that this caused an issue with the IACV?
Old 10-22-2008, 12:17 PM   #4
racer_x
Member#: 175722
bump, thanks for looking
Old 10-22-2008, 12:23 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
did you take off the upper radiator hose to fill it? Doesn't coolant run thru the TB? could that throw off your idle? It may take a couple of cycles to get all the air out.
Old 10-22-2008, 01:28 PM   #6
racer_x
Member#: 175722
I bypassed the TB coolant because we're in FL
Cooling system problem gakusya Service & Maintenance 15 02-11-2011 09:00 PM
"Burping" Cooling System Problems.. STI_KLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 11-03-2008 03:16 PM
i have a big cooling system problem! TheBryman Service & Maintenance 11 06-12-2007 02:21 PM
Cooling system problem? taphonomist Service & Maintenance 0 04-17-2005 04:40 PM
I'm confused. Cooling system problems... fastenova Legacy Forum 10 04-16-2005 10:15 PM
