Old 10-22-2008, 12:40 AM   #1
mostasz
Member#: 170512
2012 WRX
Ice Silver
Default 07 WRX brakes on 04 WRX - good upgrade?
Is it good upgrade? I am looking for sharper brakes on daily driver compare to stock. Also, is it direct replacement? Or I need any modifications?
mostasz is offline   Reply With Quote
Old 10-22-2008, 09:04 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Have a read of jamal's Notes on Brake Interchangeability from the Brake Supersticky at the top of the forum.
Don't really know what you mean by 'sharper' but I would expect pad compound would be where you should focus - you can gain a certain amount by removing some of the front bias (which the Subaru 4/2 setup does) but there are more cost-effective ways of achieving that (e.g. the H6 rear rotor upgrade).
UkNuck is offline   Reply With Quote
Old 10-22-2008, 06:01 PM   #3
mostasz
Member#: 170512
2012 WRX
Ice Silver
Found my answer:
"Any FRONT caliper/bracket will bolt up to the front of any other modern Subaru (except the SVX), but in the rear there are different backing plates."
Thank You UkNuck
Old 10-22-2008, 07:21 PM   #4
MasterKwan
Member#: 98961
2003 WRX
I thought the 07's reverted to the same crappy brakes all the older ones had?
Old 10-22-2008, 09:14 PM   #5
rwdCivic
Member#: 155986
E92 M3
Jerez
Nope my 07 has the 4/2 pots just like the 06's.
rwdCivic is offline   Reply With Quote
Old 10-22-2008, 09:32 PM   #6
MasterKwan
Member#: 98961
2003 WRX
Nice.
Old 10-23-2008, 12:35 AM   #7
wopdeeze
Member#: 148597
00 GDA Jet Black
04 GGA PSM 10 SH5 XT
rear backing plates are pretty easy to change out my car is 8 years old and just took a little elbow grease to get the hub off. read my post about nissan calipers on the rear, just substitute your subaru calipers instead of nissan calipers.
wopdeeze is offline   Reply With Quote
Old 10-23-2008, 02:11 AM   #8
freshADR
Member#: 141565
2007 UGM Impreza
SoCal Flat Four #28
Subaru 4pots are definitely an affordable upgrade (if bought used). Honestly, they are about equivalent to Brembo's except for the heat dissipation aspect. These are the same brakes on the GC STi's
freshADR is offline   Reply With Quote
Old 10-23-2008, 09:35 PM   #9
supersuby2
Member#: 161678
2002 wrx V5 RA swap
Also i don't see it mentioned on here much but you can remove the brake bias valve that sends 60% brake to the front and 40% to the rear to make it 50/50 and all you need are a couple brakline couplers from an autoparts store for 3 bucks each. It helps alot and is really cheap and easy. Then put some hot pads on and you will be set real nice
supersuby2 is online now   Reply With Quote
Old 10-23-2008, 10:12 PM   #10
MasterKwan
Member#: 98961
2003 WRX
Yeah, I wouldn't do that. You'll just make the rear lock pre-maturely. The reason the rears get less pressure is, under heavy breaking they only do about 30% of the work because all the weight shifts over the front wheels. With ABS, it's probably not dangerous but, without ABS, you're asking to spin under heavy breaking.
03 WRX brakes on 06 WRX? salvator_rizzo Brakes, Steering & Suspension 12 01-11-2010 05:16 PM
06-07 rear wrx rotors on 04 wrx virjose Interior & Exterior Modification 3 03-03-2009 03:32 PM
03 wrx brakes on 04 STI rear end? wrxsubiemod Brakes, Steering & Suspension 9 05-21-2008 08:54 PM
06 sti brakes on 04 wrx scubywgn Brakes, Steering & Suspension 0 02-25-2007 11:55 PM
06 WRX Brakes on 05 WRX johnb990 Brakes, Steering & Suspension 1 11-23-2006 12:35 PM
