#1 |
Member#: 172588
Vehicle:2005 saab 9-2x sti Black |
So, clutch is on its way out, act only sells a max of 400 ft lb 6 puck for the impreza or rs trans. 5 spd.
i was looking to get a wrx clutch because i believed the transmissions are the same but i realized that the wrx is pull style and the rs is push style. the 06-07 wrx has a push style clutch. i've checked to ensure that the splines are the same, and the bolt pattern for the flywheel should be the same as the sti shortblock is essentially the same as the 255 in the 06-07 wrx. the questions are.. will the 06-07 wrx 5spd clutch clear the bellhousing on the 05 rs transmission? the case is the same right? and will i need a new clutch cylinder or will the stock one be sufficient? (should be) thanks, its sort of a weird situation but i'm hoping the bolt up lego style subaru components will save me from buying a clutch that is too weak for the torque i'm putting down. yet still allow me to street the car.
| Thread Tools | |
| Display Modes | |
| 06 wrx flywheel type question | DigitalPunk | Transmission (AT/MT) & Driveline | 2 | 07-13-2009 11:44 PM |
| WTB: 06 WRX pull-type clutch, pressure plate, fork, master cylinder, 3.7 FD rear diff | gling | NESIC Private Classifieds | 0 | 06-07-2007 06:45 PM |
| WTB: 06 WRX pull-type clutch, pressure plate, fork, master cylinder, 3.7 FD rear diff | gling | Private 'Wanted' Classifieds | 0 | 06-07-2007 05:54 PM |
| 06 WRX Limited seats in 05 STI | STiylish WRX | Interior & Exterior Modification | 11 | 03-07-2007 05:57 AM |
| stock 06wrx catback mate to 05 RS? | vincent-h | Normally Aspirated Powertrain | 21 | 04-09-2006 10:08 PM |
