Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-22-2008, 09:49 PM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
Need EM solution...
Default can someone please explane Leakdown vs compression test?
somewhere along the lines I fell off the boat with this one...
anyone ??
IllNastyImpreza is offline   Reply With Quote
Old 10-23-2008, 10:41 AM   #2
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Compression Test: Testing for compression in the cylinder using the starter to crank the motor with no spark/fuel. Plug a peak-pressure sensor into the spark plug hole, turn the crank so the piston is at bottom than tap the starter. Piston will compress the air in the cylinder as it goes towards top dead center. If your car is broken then you won't get the stated compression numbers. Thinks like broken rings, valve seats, pistons, messed up timing, and headgasket all will give you lower numbers.
Leakdown: Pressurize the same system through the spark plug hole with the piston at the top. If something is wrong, then the air will leak out, and you won't be able to hold a high pressure in the tested cylinder. Its more useful than a compression test because it helps to diagnose the problem somewhat.
-Air out the exhaust = exhaust valve/valve seat problem.
-Air out radiator cap = headgasket to the water jacket
-Air out oil cap /bubbles = headgasket to oil, or broken rings/pistons.
-Air out intake = intake valves
Both test are done on a warm engine, because as the motor warms up all the metal parts expand a little and the rings/valve seals become as good a seal as they are ever going to.
Edit: I'm a rere
DiscoGsus is offline   Reply With Quote
Old 10-23-2008, 10:44 AM   #3
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
I assume that you know what a compression test is. A leak down test is like a compression test in reverse. the engine is rotated to TDC compression stroke. (both valves closed) the crankshaft is locked so it can't move. a hose is installed in the spark plug hole and regulated air is pumped into the cyl. ( to keep it simple) lets say 100 lbs. of pressure is pumped in and the leak down gauge reads 80 lbs. that will mean that 20% is leaking past the combustion chamber, it could be leaking past valves, rings, head gasket, etc. you can tell where it is going by listening to the exhaust, intake , crankcase, etc. I use a leakdown tester to find head gasket leaks by removing the radiator cap and watching for a rise in coolant level. It never fails to ID a gasket failure.
leak down test will tell you alot more than a compression test, the only time I use a compression tester is to ID the cyl. I need to do a leak down on. with most modern engines anything more than about 15% is worth looking into, and if you are above 20% you are broke.
The engine must be at TOP dead center compression, with the piston at the bottom, how will you take into account cyl wall wear? I have found major difference in readings between TDC and BDC
crampfan is offline   Reply With Quote
Old 10-23-2008, 12:11 PM   #4
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
You are correct, I mispoke (and edited to change it.)
Old 12-24-2008, 12:45 AM   #5
werix
Member#: 194082
2002 wrx
is the fuel pump or the pressure of the gaz coming in the cylinder have an effet on compression test ? ( sry im a noob trying to understand all of this )
werix is offline   Reply With Quote
Old 12-24-2008, 01:22 AM   #6
rkramer
Member#: 118209
2015 WRX Limitec
nope, you don't start the engine during either test, in fact you have to make sure you can turn it over with the starter during a compression test, but it MUST NOT START. (so no fuel, and no pressurized gas entering the system) You are just measuring how well the cylinder can compress the intake charge.
Old 12-24-2008, 01:39 AM   #7
SubeN'Siren
Member#: 151171
02 Subaru WRX
How do you manage to do this on a "warm" engine without burning the crap out of you're hands?
SubeN'Siren is offline   Reply With Quote
Old 12-24-2008, 07:02 PM   #8
beegmon
Member#: 150043
I dont mean to thread hijack here, but I am brand new and dont have the required post count to start a new thread.
I was hoping some one could give me their take on the following compression + leakdown results I just got. They look good to me.
05, STI, stock, 47000 miles
Stone Cold (Compression check only):
#1 -- 130 psi
#2 -- 130 psi
#3 -- 130 psi
#4 -- 130 psi
Hot (Compression + Leakdown -- Dry)
#1 -- 135 psi -- 0%
#2 -- 130 psi -- 9%
#3 -- 130 psi -- 5%
#4 -- 130 psi -- 1%
Hot (Compression + Leakdown -- Wet)
#1 -- 140 psi -- 0%
#2 -- 135 psi -- 1%
#3 -- 135 psi -- 0%
#4 -- 140 psi -- 0%
The leakdown losses are not doubt coming from the rings since the wet tests sealed them up.
I got the test down because I am seeing really rough idle and missing up to around 3k. I have checked for vac leaks, replaced the MAF and O2 sensors. I havent pulled the timing belt cover off and check and see if the belt jumped any teeth, but from the looks of it I dont think thats the issue either. The plugs are new, the coil packs are all good, and the injectors check out fine as well.
In any case any input on the above numbers would be great. Thanks!
beegmon is offline   Reply With Quote
Old 12-25-2008, 02:57 AM   #9
valetudospang
Member#: 144007
Edit: I'm a rere
How do I get the "Piston to the Top"??
Merry Christmas!
valetudospang is offline   Reply With Quote
motor question - leakdown vs compression test jackdempsey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-18-2009 06:20 AM
Where can I get a leakdown and compression test? jcbluescooby Tri-State Area Forum 13 05-21-2009 05:22 PM
Leakdown and Compression Test Results Hah72215 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-24-2008 02:35 PM
Cylinder Leakdown vs Compression Test Explained NITROS Service & Maintenance 3 02-13-2007 03:42 PM
Can someone explain a leakdown test? blackie Service & Maintenance 1 04-23-2005 12:20 PM
