Old 10-23-2008, 01:43 AM   #1
fourage20
Member#: 136149
2002 WRX EJ207
Default axle nut size
are the nuts that bolt the axle to the hub the same size (threaded part and outter part) on a 2004 sti and a 2002wrx?
fourage20 is offline   Reply With Quote
Old 10-23-2008, 01:45 AM   #2
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
Yes. They should both be 32mm's if I understand your question correctly.
wrxwagon253 is offline   Reply With Quote
Old 10-23-2008, 01:47 AM   #3
fourage20
Member#: 136149
2002 WRX EJ207
well pretty much i want to know if i can reuse the nuts that are on my wrx axles to my 04 sti axles.
Old 10-23-2008, 01:48 AM   #4
wrxwagon253
Member#: 125620
05 3076R Wagon
If you have em both there try threading the nut on . It shouldn't be any different thread or size. There the same.
Old 10-23-2008, 01:52 AM   #5
fourage20
Member#: 136149
2002 WRX EJ207
i dont have the sti axles yet. lol. theyre coming on friday. but i dont know if the nuts are coming with them. i gotta do a whole rear hub/spindle, brembo and axles swap for my 6 speed. i just dont want to run into a problem with the car taken apart.
Old 10-23-2008, 03:51 AM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
You should replace the nuts every time.
If you do reuse them make sure to torque it down properly and stake the nut or your bearings will fail in no time. I recently had to replace a hub/spindle/axle because the nut I reused multiple times didn't stake properly and loosened up over time which let the bearing separate and eventually damage surrounding parts.
Old 10-23-2008, 12:20 PM   #7
fourage20
Member#: 136149
2002 WRX EJ207
what should it be torqued too?
Old 10-23-2008, 09:09 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
You should never loosen or tighten the axle nut with the weight of the vehicle on the wheel. The specs vary depending on year and model even though they are of the same design but they are usually around 115. I suggest at least 130 personally.
Old 10-23-2008, 09:48 PM   #9
fourage20
Member#: 136149
2002 WRX EJ207
how big of a pain in the dick will it be to loosen the axle nut? im also changing the whole hub assembly so how hard will it be to pull out my old ****? like the long bolt that holds the spindle to the control arms and the spindle to the struts. im just doing the rear.
Old 10-23-2008, 10:52 PM   #10
fast71
Member#: 123735
2002 WRX PSM /2.5
Turbo_mike built, PPG'D
Originally Posted by fourage20 View Post
how big of a dick will it be to loosen a nut?
whoa there buddy!!
fast71 is offline   Reply With Quote
Old 06-11-2009, 10:59 PM   #11
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
any locations to get some axle nuts for cheap?
arco is offline   Reply With Quote
93 impreza AWD axle nut size? omeskcus Normally Aspirated Powertrain 4 12-21-2008 12:56 AM
Need quick answer plz..99 OBS front axle nut size? Herm99 Impreza Forum 1 10-30-2008 06:37 PM
Axle nut size? John__Gotti Transmission (AT/MT) & Driveline 4 10-07-2008 05:15 PM
Axle nut size of 90-94 Legacy w chapman Newbies & FAQs 1 08-20-2005 01:17 AM
Drive Axle Nut Size? xcntrk75 Transmission (AT/MT) & Driveline 4 12-17-2004 03:56 PM
