Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 10-23-2008, 11:37 AM   #1
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Default Car won't start....help
Car is a ej20g with sti 2.5 shortblock, yellowtop inj, wrx fuel pump, pfc, new age coil upgrade.
So while driving home on a road trip this weekend my car started randomly juttering/jerking while cruising at around 85. Pulled over when it became bad and initially thought ignition. Took off all the coils and double checked the wiring and cleaned up the wires a bit. Car started up and I continued to drive. Made it back home but the whole time occasionally the car would do the jutter.Felt like the car just lost power for a split second.
Yesterday while driving the car all the sudden severely started juttering and loosing power in and out and then eventually straight up died. Thought I was out of fuel. Filled her up and still nothing. Car cranks but doesn't turn over. After trying to start it a few more times the car started and idled for 10 min then would die.
Took the fuel pump out to make sure it was working. Could hear it spinning and pumped fuel out of the lines. BUT when just trying to turn over the car no luck. BUT if i prime the car (turn the key from off to on) a good 5-10 times the car will start right up run great and then die after 10 min.
So I'm guessing it's running off the fuel it was primed with then dying after it burns it? Or the pump can pump enough into the lines but can't hold pressure?
Really need some ideas here. When the car does start it runs very well.
hail2theTheif is offline   Reply With Quote
Old 10-23-2008, 12:29 PM   #2
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
bad filter, or FPR?
neko is offline   Reply With Quote
Old 10-23-2008, 12:40 PM   #3
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Filter was changed a few weeks ago. How could i check the FPR?
Old 10-23-2008, 11:05 PM   #4
neko
Member#: 46500
Now with 200% more
hmm. think you need some sort of fuel pressure gauge or gauge like it. somehow see if you're hitting whatever normal fuel pressure we run. (what, 50-something psi?) Not sure how to rig up something quick n dirty that would work tho. Or, the old-fashioned way to test parts, swap out for another of the same. Got another FPR lyin around?
BTW, hows the old wagon doing? Looking much cleaner these days? I remember looking at several of your for sale ads and being quite tempted... Looks like the new powerplant's putting out some seriously lovable amounts of torque.
Old 10-23-2008, 11:53 PM   #5
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
I think Napa or somewhere like that might have a ghetto gauge you can hook up into the lines that will read the pressure. I'll have to check that route out tomorrow. Sadly don't have an extra FPR. That would be sweet though.
Other than this problem that exists right now the wagon is amazing. Couldn't be more happy with the new powerplant. Whole new car. The torque is unbelievable. I got used to the old motor power output but every time I get behind the wheel of the new engine it feels like I've never driven it before. Always feels like it's pulling strong instead of getting used to the power. It's nice. Gotta get her back on the road ASAP for winter time.
Old 10-24-2008, 03:56 AM   #6
neko
Member#: 46500
Now with 200% more
yeah, i gotta get me a wagon someday...
Good luck with the fueling issue.
Old 10-24-2008, 11:12 AM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
a 1.8 fpr will work ..
Old 10-25-2008, 06:41 PM   #8
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
replaced the fuel pump and fuel pump wiring. everything seems to be good now. however....i can't deal with the stresses of this car anymore with all the other stuff goin on in life. time to sell it.
Car won't start - help blackmedal Legacy Forum 20 11-11-2005 02:46 PM
Car won't start. Help flp_sde Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-26-2004 03:31 AM
Rat chewed on a wire, now car won't start ! Help ! 99LegacyGT Legacy Forum 3 07-14-2003 04:16 PM
my car won't start help!!!! ChasuRamen Normally Aspirated Powertrain 4 01-12-2003 11:08 PM
car won't start- help ASAP cindergarden Normally Aspirated Powertrain 8 08-19-2002 08:16 AM
