Old 10-23-2008, 11:38 AM   #1
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Default possible bad fuel pump?
Car is a ej20g with sti 2.5 shortblock, yellowtop inj, wrx fuel pump, pfc, new age coil upgrade.
So while driving home on a road trip this weekend my car started randomly juttering/jerking while cruising at around 85. Pulled over when it became bad and initially thought ignition. Took off all the coils and double checked the wiring and cleaned up the wires a bit. Car started up and I continued to drive. Made it back home but the whole time occasionally the car would do the jutter.Felt like the car just lost power for a split second.
Yesterday while driving the car all the sudden severely started juttering and loosing power in and out and then eventually straight up died. Thought I was out of fuel. Filled her up and still nothing. Car cranks but doesn't turn over. After trying to start it a few more times the car started and idled for 10 min then would die.
Took the fuel pump out to make sure it was working. Could hear it spinning and pumped fuel out of the lines. BUT when just trying to turn over the car no luck. BUT if i prime the car (turn the key from off to on) a good 5-10 times the car will start right up run great and then die after 10 min.
So I'm guessing it's running off the fuel it was primed with then dying after it burns it? Or the pump can pump enough into the lines but can't hold pressure?
Really need some ideas here. When the car does start it runs very well.
hail2theTheif is offline   Reply With Quote
Old 10-23-2008, 12:04 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
could be the relay too or the ecu tonnection to the relay
cruise is an odd time to have it die
Old 10-23-2008, 12:12 PM   #3
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
thanks for the response jaxx. how can i check if the relay is bad?
Old 10-24-2008, 09:36 AM   #4
suberdave
Member#: 101865
88 GL-10 STi
dont check it by sound. put a fuel pressure gauge on it. i have had rendom problems like this and taped a gauge to the windsheld and drove, after driving for a while the pressure would drop and the car would die...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 10-24-2008, 10:57 AM   #5
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
so if the pressure does indeed drop, should i be replacing the fuel pump or the fuel pressure regulator?
Old 10-24-2008, 11:11 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
thought
what is the condition of the vacuum hose on the FPR
Old 10-24-2008, 02:58 PM   #7
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
just checked the vacuum hose. in great condition.......looks like i might have to just replace both parts and go from there...
Old 10-25-2008, 06:40 PM   #8
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
replaced the fuel pump and fuel pump wiring. everything seems to be good now. however....i can't deal with the stresses of this car anymore with all the other stuff goin on in life. time to sell it.
Old 10-25-2008, 06:58 PM   #9
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
didnt you just post that you loved it?
just buy a beater for like 400 bones
Hurley 2.5 WRS is offline   Reply With Quote
Old 10-25-2008, 08:55 PM   #10
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
I do love it. Doesn't mean I have the time to love it. 3 years goin on 4 owning a swap and it's taxing even with the fun.
Bad fuel pump? please help! VideoGameWrx Commercial ECU Reflashes 9 10-20-2007 12:32 PM
Bad fuel pump? scooby-stu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-11-2006 09:58 AM
Symptoms of a bad fuel pump? TyranosaurusWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-20-2006 03:51 PM
bad fuel pump? gotawd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-21-2006 09:02 AM
bad fuel pump?? any aftermarket?? pearlblack2.5rs Service & Maintenance 2 11-15-2001 02:17 AM
