Old 10-23-2008, 04:30 PM   #1
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Default 06 Wrx Vf39
Finally got my tune finished up by DSG (Dent Sport Garage) and I'm pretty happy with the results, 304.5hp / ~325tq
Mods are:
92 oct
Built motor, with Cosworth 278/274 cams
Helix EWG up-pipe, Tial 38mm EWG, with self made custom extension tube and dump tube
APS Inlet
Perrin V2 Rails
DW 750cc
Walbro 255lph
HKS DP
Greddy Evo 2 CB
SPT Inatke
SSAC FMIC
TGV Deletes
I might be missing some things but on to the good stuff.
Video while on DSGs dyno
http://www.youtube.com/watch?v=3ggWHiqJD2w
Video while on Swift's dyno before the final tune
http://www.youtube.com/watch?v=KexHCeOyhF8 (The title is wrong but that is my car)
http://www.youtube.com/watch?v=w_4y1aYZPFM
Edit - Video/sound clip of the cams
http://www.youtube.com/watch?v=nFeatm1RjrU
Enjoy!
-Rene
Rene2.5RS is offline   Reply With Quote
Old 10-23-2008, 04:33 PM   #2
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
ewwww... those cams are killing that little turbo... the fmic isnt helping either...
but its holding a bit more power past 5k i think...
but then again, im sure the vf39 is temporary
All4bSpinnin is offline   Reply With Quote
Old 10-23-2008, 04:35 PM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Built motor and a VF39?
Is this a rally car or something?
Audiosavvy is offline   Reply With Quote
Old 10-23-2008, 04:59 PM   #4
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Yes I blew the motor last November and built it with my final turbo in mind, Dom 3 or 4, HTA Green, or an ATP 3076 or possibly the new ATP 35.
When I was done with the build I simply didn't have the money for the new turbo, and I need to save up again for the doomed tranny,
-Rene
Old 10-23-2008, 05:34 PM   #5
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Gotcha! That makes sense. So you already had the turbo and everything, you just replaced the motor?
So what do you think of the new motor, pros and cons? I have to ask because I'll eventually be doing that, and it's not often that people do JUST the motor.
Old 10-23-2008, 05:49 PM   #6
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Let me say nothing smaller then a 52lbs/min turbocharger!!!
tux121 is offline   Reply With Quote
Old 10-23-2008, 06:00 PM   #7
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
I wouldn't say the cams are killing it with that turbo. I'm assuming heads are stock (correct me if I'm wrong), and if that's the case, you're not using the cams to their full potential. Get some more airflow head-wise and those cams might just shine.
zeropsi is offline   Reply With Quote
Old 10-23-2008, 06:14 PM   #8
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
I bought the EWG UP and a Tial EWG, the rails, injectors, and inlet when the motor was out since it would be the easiest time to do these mods. I also deleted and ported the TGVs while they were out.
The full motor build is:
Wiseco 100mm Pistons
ACL Race Bearings
Helix Forged Rods
Brian Crower SS Valves
Brian Crower Springs and Retainers
ARP Head Studs
Cosworth Cams
DSG did the motor work for me which was nice, dropped off an assembled long block and picked it up the same. The motor hates timing, which doesn't seem to be a bad thing since I am still making the correct amount of power running less timing. The only draw back to the forged internals is it doesn't like running when cold and is pretty noisy on cold starts, which the knock sensor picks up if the coolant is in the <130F range. Other than that is seems fine and the cams sound good at idle
My turbo list above is just that, minimum 52lbs turbo. I will not push the limits of the motor, because I do need it to last. I am only looking for about 380-430 whp out of the car and will most likely run it less for normal driving via turning down the boost.
-Rene
Old 10-23-2008, 06:17 PM   #9
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
They were opened a little, but again I was running out of money fast with the build so I skipped a full PnP job.
-Rene
Old 10-23-2008, 06:23 PM   #10
Sp00L
Member#: 169701
2006 WRX
1997 240SX
you should run meth and higher boost
Sp00L is offline   Reply With Quote
Old 10-23-2008, 07:42 PM   #11
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Soundclip, stat!
Old 10-23-2008, 08:23 PM   #12
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Soundclip, stat!
Enjoy
-Rene
Old 10-23-2008, 08:29 PM   #13
Audiosavvy
Member#: 150794
Qcab dakota 4x4
^^^ Thanks! I like, I like!
What exhaust manifold?
Old 10-23-2008, 08:37 PM   #14
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
Any manifold work/aftermarket? Are the cosworth cams avcs cams and are you running avcs?
howfast? is offline   Reply With Quote
Old 10-23-2008, 08:37 PM   #15
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Stock unmodified
Old 10-23-2008, 08:42 PM   #16
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Originally Posted by Rene2.5RS View Post
Stock unmodified
Thanks. Ok I'll stop bugging you with questions.
Until I think of another one
Old 10-23-2008, 08:42 PM   #17
howfast?
Member#: 102027
you need some grimmspeed work!
Old 10-23-2008, 08:49 PM   #18
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Yes the cams are avcs and yes I am running avcs. Cosworth has a couple different cam options depending on the motor you are running.
Keep asking, doesn't bother me. Helps clarify things for other readers.
-Rene
Old 10-23-2008, 09:35 PM   #19
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
I'm not a fan on water/meth injection. I would rather leave some on the table and then have a race fuel map for when I want to get on it, ie when I am at the track.
I am already running about 21psi in the mid range and then tapering to 15psi at redline.
-Rene
Old 10-23-2008, 09:38 PM   #20
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
I am up in the air about what to do, I am not sure if I will go moded stock manifold or after market manifold. I would be more inclined to port mine myself since I already have an egt probe in mine.
-Rene
Old 10-24-2008, 11:40 AM   #21
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
-Rene
Rene
We can always tap an egt for you if you wish. We'll even take your tapped cores back as long as it is tapped in the correct position(driver side).
Justin
GrimmSpeed is offline   Reply With Quote
Old 10-24-2008, 04:23 PM   #22
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Originally Posted by GrimmSpeed View Post
Rene
Justin
Yeah it is tapped on the driver's side. Like I said though, I am still up in the air as to which way I will be going in terms of a manifold. I will keep you guys in mind when the time comes though.
-Rene
Old 10-24-2008, 09:56 PM   #23
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
not bad what made you do a front mount on a vf39
jeremywrx15554 is offline   Reply With Quote
Old 10-24-2008, 10:38 PM   #24
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
-Rene
Thanks, and hope that answers it for you
-Rene
Old 10-24-2008, 10:53 PM   #25
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
ok sorry i guess if i would have read the whole thread i would have seen that.
06 WRX VF39 50/50 Meth/Distilled kn0bby8 Proven Power Bragging 17 11-13-2006 12:45 PM
FL: 06 WRX VF39 swap *help* 06blksubwrx South East Region Forum 6 08-28-2006 02:14 AM
Got a Protuned 06 WRX VF39 map? scooby24 AccessPort 3 08-11-2006 11:54 AM
06 WRX + vf39 + AP stage II STI DRNWAGN AccessPort 4 04-12-2006 06:26 AM
06 wrx vf39 cobb stage 3 numbers dodiox Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 02-22-2006 02:27 PM
