#1 |
Member#: 10
NESIC
Vehicle:2005 Legacy Gt wagon Garnet red pearl |
i was thinking of getting the 22 front 22-24rear from rallispedcs group buy... what do you think? and i have the P1 suspension in.
#2 |
Member#: 437
NESIC
Vehicle:'91 Miata MX5 (Red) '09 Impreza OBS (Blk/Gry) |
You should give them a call. I think Dave ran the sway bars on his car for sometime, to check it out. My opinion is it is not really needed. If you have a 20mm in the rear, and the stock 19mm in the front, then the car is pretty balanced. Changing both diameters to a larger size while keeping almost the same ratio from frt/rear, what is the point? Especially with the P1, your car has no body role as it is.
Just my opinion. I know the bigger bars will make the car have less body role (or in your case eliminate it all together), but it seems like the price ($200 +) could be spent somewhere else to be more effective. Paul G. Ps-Bill, I am thinking of getting the anit-lift kit. Does this cause the tires to wear faster, or is it just a geometry change to the contol arm that you only notice when the car going through a hard corner? I guess my question is, does the anti-lift kit effect your everyday drive, and cause tire wear? |
#3 |
pooptastic
Member#: 1904
BAIC
Vehicle:2013 Tundra '02 BMW R1100S |
hey, maybe you guys could help me, suspension-wise? I just bought and installed a 20mm rear bar, and let me tell ya, it does nothing for me. Are there any relatively inexpensive suspension upgrades i could do? (this means without getting all new struts)
#4 |
Member#: 10
NESIC
paul the beauty of the anti lift kit is you have camber only while you turn your wheels so when you are driving straight you have no camber so you don't scrub off your tires
#5 |
Member#: 437
NESIC
Thanks Bill, I have to call Rallispec.
Jgard18, I live near Boston, and I have the 20mm and the Eibach Springs on stock struts. If you want to meet up sometime, you are welcome to try it out. I am surprised the 20mm does nothing for you. You should bring the old and the 20 to an autocross and try both. You would be amazed. Paul G. |
| Thread Tools | |
| Display Modes | |
| What do you guys think of this brake setup? | WRXem | Brakes, Steering & Suspension | 20 | 08-20-2005 09:55 PM |
| What do you guys think of this FMIC setup? | supermarkus | Member's Car Gallery | 57 | 06-10-2005 12:58 PM |
| What do you guys think about this setup for 04 *critism welcome* | CynicX | Factory 2.0L Turbo Powertrain | 1 | 11-16-2003 11:00 PM |
| What do you guys think about this set up | SkypatCorbin | Factory 2.0L Turbo Powertrain | 18 | 06-28-2002 04:51 PM |
| What do you guys think about this? | Lix | Normally Aspirated Powertrain | 4 | 02-13-2001 03:51 PM |
