Old 10-24-2008, 12:00 AM   #1
Hoak
Member#: 176182
1997 Legacy
Default Oil passage questions
So I have an EJ22T block with WRX heads. I picked the car up with this set-up. I have a few questions on oil passages and weather on not some are safe to use/plug.
-First off, can the two large passages under the crank safely be used for an oil cooler return and supply?
-Secondly, there are two smaller ports on the back of the heads (14mm bolts). Is it safe to use one of these for an oil supply for the turbo, and the other for an aftermarket pressure sensor?
-Lastly, there is a pipe coming off the drivers side head on the back. It was cut and soldered shut. I removed it and found oil where it threads in. What is/was that pipe?
Hoak is offline   Reply With Quote
Old 10-24-2008, 07:23 PM   #2
Hoak
Member#: 176182
1997 Legacy
bump!
porting oil passages wrxzzz Built Motor Discussion 5 04-20-2007 10:55 PM
Hex plugs on back of heads - coolant or oil passage? Patrick Olsen Built Motor Discussion 24 01-13-2007 02:24 PM
Hex plugs on back of heads - coolant or oil passage? Patrick Olsen Normally Aspirated Powertrain 9 01-13-2007 12:32 PM
Fujimoto oil drain valve and oil change questions ps99115 Newbies & FAQs 38 10-14-2005 09:14 AM
Oil Pressure and Oil Temp Question gaylemd Interior & Exterior Modification 3 05-09-2001 01:22 AM
