Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 10-24-2008, 12:58 AM   #1
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default '08 STI stock with AP base map vs Pro tuned
This '08 STI was one of the few stock cars I have seen in a long time for a custom tune
This dyno sheet is the base line - 100% stock
Middle is Cobb Stage I 93 off the shelf map
Top is custom tuned Pro Tune map
alfriedesq is offline   Reply With Quote
Old 10-24-2008, 02:02 AM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
So it's making 301/353 with no mods except a custom tune?
For some reason I find that hard to believe, even on a Dynojet...
I'm not hating, but if that's the case then that's a VERY potent, very underrated car.
Audiosavvy is offline   Reply With Quote
Old 10-24-2008, 02:22 AM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
boost...afr....anything?
i think the stock peak hp would been 10-15whp higher if it didnt knock at 5500rpm
can you explain how you guys (tuners in general) pick up hp at high rpm with these small turbos? From what ive seen the stock maps run a crap load of timing as it is.....and leaning it out doesnt seem to pick up that much (not 40whp worth).
that leaves boost. what does the boost taper to on a stock 08? and where did you end up on the tune? has to be going from 10psi stock up to 14psi or 12 up to 16....am i close?
looks good. tuning has come a long way in the last 8 years....
Old 10-24-2008, 03:08 AM   #4
socalLGT
Member#: 89752
08 STI
Most of my 08 STi maps taper to around 14.5 psi up top. That is pretty much all the stock turbo has to give up there. Most tuned maps will actually run less timing up top than the stock maps, but between the increased boost, leaner AFR's and optimized AVCS (particularly exhaust AVCS on the 08's) you can increase peak power significantly over stock. BTW, I can say that the average stock 08 STi makes about 20 whp less (albeit on CA91 octane) on my Dynojet than the car in the original post made for Al.
socalLGT is offline   Reply With Quote
Old 10-24-2008, 10:25 AM   #5
squashman
Member#: 71718
07 STI LTD
257WHP/270WTQ stock.
That's a high reading dyno... but it's a good baseline/starting point so that if or when it makes huge numbers on a mild turbo upgrade, we'll know why.
squashman is offline   Reply With Quote
Old 10-24-2008, 11:40 AM   #6
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Very. My guess is this car is actually around 270/300 whp/wtq.
Timeslips would be a better judge.
cucamelsmd15 is offline   Reply With Quote
Old 10-24-2008, 12:50 PM   #7
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
91 octane is a totally different subject.
The gains in top end power result from leaning out the a/f slightly, running more boost, reducing the open loop delay, and avcs.
Comparing numbers from one Dyno to another is not very useful. I am more interested in comparing the difference from starting and ending point. That and the shape of the curve are what I look at. Al
Old 10-24-2008, 02:56 PM   #8
Audiosavvy
Member#: 150794
Qcab dakota 4x4
That's a good point.
Old 10-24-2008, 03:28 PM   #9
Phatron
Member#: 36033
CEO PhatBottiTuning
yeah the 35-45 whp gains are right in line with other shops unmodded tuned 08's
04 STi Stage 2 on Base Map Tune...12.63 and 109 MPH LTBlackBird Proven Power Bragging 8 04-22-2010 04:52 PM
2008 WRX: Stage 2 RalliTEK map vs. Pro Tuning awd_dreamin AccessPort 1 08-19-2008 02:41 AM
06 WRX Tr - Stage I - Ap2 base map vs Dyno Flash Pro Tune Dyno Flash Proven Power Bragging 6 08-12-2007 09:18 PM
Modified Injectors with Cobb AP Base Map 2.5 wrx904 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-08-2005 03:59 PM
utec stage 2 base map vs tune LatentWagen Engine Management & Tuning 21 06-20-2004 09:32 PM
