Old 08-11-2010, 08:44 AM   #1426
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
1990 Miata
Judging by those results for the GT28 I wouldn't give it a second though. Its a pointless turbo. Turbine housing is larger than the VF39, so I would expect response to be slower. And the power potential isn't all that great. 170hp/175tq is pretty close to stock numbers on the local dyno, and 16G cars make more than 250/230. If I put it on the dyno I'd expect my 19T to make close to 240hp/tq.
Scooby921 is offline   Reply With Quote
Old 08-19-2010, 02:54 PM   #1427
Heedlessone
Visiting NASIOC Timeout
Member#: 254130
2004 STI
Hurr hurr
Default Frankenstien TD04
Ok, since this is a TD04 19T thread I was hoping someone on here could help me out.
I have a TD04L turbo that blew in my WRX, I replaced it with another stock TD04L turbo that I got for $200 on Ebay. I want to rebuild the turbo in my garage with a 19T compressor and I was hoping to try and fit in a TD04HL turbine wheel. Anyone think this can work?
I can PnP the hosing myself, but I'm curious to see if the TD04HL turbine will even have a chance of fitting.
Jon
Heedlessone is offline   Reply With Quote
Old 08-19-2010, 09:39 PM   #1428
erikkellison
Member#: 67412
Watch the video on Blouch's website.
My vote is "no freaking way."
erikkellison is offline   Reply With Quote
Old 08-20-2010, 03:45 PM   #1429
SilentDoomWgn
Member#: 246729
03 wrx wgn
blue
from what i found..... you would have to source a HL exhaust housing or get the L one machined out to the HL wheel. im not sure where or if you can even get a subaru HL housing but i know you can find a H housing.
im pretty sure if you read this thread you would have noticed that all the work to make a td04hl-19t would not be worth the end cost. the power increase is rather small and for nearly the same end price you could get a td05-16g that is proven to last years.
SilentDoomWgn is offline   Reply With Quote
Old 08-20-2010, 05:55 PM   #1430
Mooneyes13
Member#: 113666
60' all over you
2.0L stock
PT turbo
Wrx Dark Blue injectors 560cc
Walbro 255
STi tmic
Perrin Inlet
Invidia UP
ported headers
catless
NGK iridium plugs
cleaned MAF
K&N filter intake
wrapped exhaust
110oct
Mustang Dyno. Stock sti 220-230's
Mooneyes13 is offline   Reply With Quote
Old 08-21-2010, 05:27 AM   #1431
SilentDoomWgn
Member#: 246729
03 wrx wgn
blue
whats it run when on 91/93 which ever you use?
great numbers!! the power band looks like it should be tons of fun.
Old 08-21-2010, 10:45 PM   #1432
GenoaWRX9
Member#: 212459
2004 G35 DG
95 L black/muddy
The dyno graph above was of my car that wrecked, i think the numbers were down 15-20 from the race gas tune but the boost was the same. It was lots of fun to drive
GenoaWRX9 is offline   Reply With Quote
Old 08-22-2010, 08:35 AM   #1433
AllAWD
Member#: 17079
2001 SV650
Not to criticize because those are good numbers, but clipped TD04L/19T are at about the same. (Sorry to sound like Kanye West)
Without PT doing the HL wheel at such a low cost, I would say stick with the Blouch clipped L/19T or go up to 16g as a previous poster said.
AllAWD is online now   Reply With Quote
Old 08-22-2010, 09:08 PM   #1434
Heedlessone
Member#: 254130
2004 STI
Hurr hurr
So best option would be to just go with a 16G wheel. It was between the two, I was either going to buy a Ebay rebuild kit and Ebay 19T wheel for about $140 and do all the work my self, or spend $650 on a Blouch 16G. I was leaning toward the 19T because of cost and apparently they flow about the same CFM.
Thanks for the input.
Jon
Old 08-22-2010, 09:43 PM   #1435
AllAWD
Member#: 17079
2001 SV650
Jon
Don't forget the VF39/43 is in the same league and you might be able to get it cheaper.
$325+donor for Blouch TD04L/19T (240-260whp)
$400(used) for VF39 (250-270whp)
$650 for 16G (260-280whp)
Spool goes 19T>16G>VF39 (best to worst)
Old 08-24-2010, 07:57 PM   #1436
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
Throwing my hat into the ring as my pnp td04 is finally crapping out...
I've read through the meat and potatoes of this thread and I still can't make a decision of whether to go with the Blouch 19T offering or go to the small 16g. I love my setup now and have most all, if not all, of the supporting mods for quick spool and don't really want to lose much of any of that.
How noticeable of a lag response felt on the butt dyno between the 19T and the small 16g? xsnapshot, looking at you here...
MT_WRX is offline   Reply With Quote
Old 08-24-2010, 10:30 PM   #1437
xsnapshot
Member#: 170973
2004 WRX 4EAT
I was able to a fairly back to back comparison between PT's 19t upgrade and the small 16g. Honestly they spooled identically and after 3500 RPM, the small 16g made more power.
I need to stress the fact that my data comes purely from 2nd gear pulls as well, which fall between a 5 speeds 2nd and 3rd gear. I make full boost (21 psi) in hot humid weather at 3800 rpm in 2nd gear. If i had a 5 spd, I would venture to say that 3rd gear full boost would be seen by 3500 rpm. (also remember I have an auto which doesn't load the motor the same...it causes slower spool). In colder weather it will only get better.
Im also running 2 degrees less timing everywhere pretty much because i simply dont need as much to make good power with the small16g.
Gas mileage has been the same 16mpg (e85) with both turbos.
I can't comment on the blouch 19t as ive never ran one, but now that I have run the small 16g, I cant imagine being very happy using the 19t and being limited to the smaller hotside.
The 19t compressor itself is comparable to the small 16g on paper, but in the real world its less efficient and moves less air per psi of boost as a whole unit.
Unless price is the only issue, go with the small 16g and youll be quite happy. (or any other TD05 7cm^2 based turbo)
xsnapshot is offline   Reply With Quote
Old 08-27-2010, 08:08 AM   #1438
AllAWD
Member#: 17079
2001 SV650
That's pretty much exactly what the tuner I talked to said about a DB Monster clipped L/19t he owned vs customer 16gs.
Old 09-01-2010, 09:09 PM   #1439
ISELLSUBIES
Member#: 256485
2002 WRX Wagon
welp, this made up my mind!
ISELLSUBIES is offline   Reply With Quote
Old 09-03-2010, 12:04 AM   #1440
xsnapshot
Member#: 170973
2004 WRX 4EAT
Just thought I'd throw in a little fun piece of information. I'm getting 21 psi by 2800 rpm in my final gear. Yes you read right. 2800 rpm. Also note that is without being able to go past 30% throttle position. (or else it downshifts). Tonight was a nice cool night and I reached full boost 100-150 rpm quicker than I was able to in the super hot/humid weather.
Old 09-03-2010, 02:59 PM   #1441
OrbitalEllipses
Member#: 178811
2013 WRB BRZ
:banana:
That's a small 16G right xsnapshot, What's the lb/min on that?
OrbitalEllipses is offline   Reply With Quote
Old 09-04-2010, 12:18 AM   #1442
xsnapshot
Member#: 170973
2004 WRX 4EAT
Yep. Small 16g. Not sure on the lbs/min, but I can tell you that I was getting 4.5-4.52 mafv on a stock airbox/sensor/housing in the hot humid weather with a peak boost of 21 psi tapering down to 18 at redline. last night I had to be pulling a bit more than that although I wasn't logging that parameter.
this coming winter on a good DA day, I want to see how close to making out the maf I can get. I'm guessing I max out around 4.65 ish.
Old 09-05-2010, 04:27 PM   #1443
Heedlessone
Member#: 254130
2004 STI
Hurr hurr
Isn't it 35 lb/min for the small 16G?
Old 09-05-2010, 07:33 PM   #1444
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
1990 Miata
At a pressure ratio of 2.0 the rated flow of the small 16g is ~520cfm. I don't feel like doing the math to convert to mass flow rate.
Old 09-10-2010, 08:38 AM   #1445
cueball89
Member#: 90513
2003 wrx wagon
black
PhatBotti Tuning tuned a 19t on a 2002 wrx. Don't know the supporting mods and what not though.
cueball89 is offline   Reply With Quote
Old 09-10-2010, 08:58 AM   #1446
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
1990 Miata
^I'm getting closer to that. My rebuilt 19T has been in the car and running strong for 2 weeks now. I haven't finished the tune, but current airboy numbers are 250hp/250tq. Peak boost of 19psi at 3200rpm in 3rd gear. I could make a bit more power if I weren't still using the stock TMIC and stock y-pipe. I need to find some money and fix that problem . With better flow and cooling I might be able to hold more than 16psi at redline. Of course when I do that I may need more than 550cc injectors.
I also need to fine tune the wastegate. I'm overboosting at 3200rpm and its cutting duty cycle and hurting my peak torque numbers. Once I get that smoothed out I'll be posting up my own results thread.
Old 09-10-2010, 10:34 AM   #1447
trinistyles
Member#: 71627
0205 Vf39 Wrx/Fz XS
Wbp/silver
Sti Mikey and Mike did a great job on my 02 Wrx TD04 19-H wheel,this turbo came to life and he could of gotten more but we played it safe,I have not dyno the car as yet but post it up when I do.
trinistyles is offline   Reply With Quote
Old 09-10-2010, 11:31 AM   #1448
Subian
Member#: 202804
2002 PSM Sedan
20g/ewg/Phattbotti Tuned
You can always Airboy/Virtual Dyno the logs you have for a rough estimate?
Subian is offline   Reply With Quote
Old 09-10-2010, 11:37 AM   #1449
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
lb/min = cfm * 0.069
520 * 0.069 = 35.88 lb/min
Phatron is online now   Reply With Quote
Old 09-10-2010, 02:54 PM   #1450
cueball89
Member#: 90513
2003 wrx wagon
black
Good to hear that it's up and running well again. I still can't get over the the accordion style y pipe.
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 08:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 08:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 10:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain 8 10-31-2008 01:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain 6 06-07-2008 07:19 PM
Message Board Statistics All times are GMT -4. The time now is 09:47 PM.
