Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 03-15-2011, 08:56 AM   #1526
barryj
Member#: 146723
2005 WRX
Has anybody gotten the PnP or Ceramic Coating from Blouch??
Wondering if it's worth the cost:
$50 ceramic coating of the turbine housing
$95? for PnP
Anybody using a Turbo jacket?
barryj is offline   Reply With Quote
Old 03-17-2011, 09:22 AM   #1527
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
$95? for PnP
I did not get my 19t from Blouch, but it was ported, polished, and coated. I don't know of the coating does much. I'm sure it retains a little more heat, but the stock heatshield is still better for protecting the intercooler from radiant heat. The port and polish of the turbine inlet and outlet was awesome. That's probably one of the major reasons I was able to clip the turbine wheel and still retain stock-like boost response. You'll probably get a better result sending your turbo to Grimmspeed for port and polish. I don't think Blouch does any polishing and I think they only port the turbine outlet.
Scooby921 is offline   Reply With Quote
Old 03-17-2011, 04:40 PM   #1528
AllAWD
Member#: 17079
For what Grimm is charging for their service, I would recommend getting a bigger turbo. There is no way their performance claims are legitimate and polishing is not going to do anything for the flow. It's just aesthetics of the finished product. There's not enough material you can remove to make a difference. Unless Grim can show a CFD model to disprove me you just can't make power from nothing. Same wheel pushes the same air mass.
You retain stock boost response because you have a stock turbo housing and because you got it tuned. I gained 500 rpm earlier spool going from OTS to a custom tune.
AllAWD is offline   Reply With Quote
Old 03-17-2011, 06:01 PM   #1529
xsnapshot
Member#: 170973
2004 WRX 4EAT
^agreed. I haven't seen enough evidence of porting/polishing providing worthwhile gains to bother. It still takes the same pressure differential pre/post turbine wheel to get x psi of boost.
And just to reiterate for those who haven't read the whole thing. This will not spool up as fast as an unmodified stock turbo. It simply is not possible. When you clip the turbine wheel you are loosing surface area on which work can be done on the turbine wheel, to gain more total discharge through the unit to help higher RPM flow. It will be close, but don't be surprised to see it lag behind 100-200 RPM or so.
The blouch upgrade DOES consist of both the compressor upgrade AND the turbine clip. At least when I called them about it, they do not even sell the upgrade without being clipped, as it creates "too much of a mismatch" in mikes words, and they would not even warranty it.
As far as worrying about "area under the curve" between the 19T and a 16G/VFXX variant. Let me put it this way, the only "area" you are loosing out on is the difference in the two curves of the 19T and 16G/VFXX to left of the peak boost RPM of the 16G/VFXX. This means once the 16G/VFXX has reached full boost, any power the 19T is making over the 16G/VFXX is because the 16G/VFXX is not being pushed to the same boost level, or some other aspect of the tune is suffering. From peak boost on a 16G/VFXX will ALWAYS make MORE power given the same mods/fuel/good tune.
xsnapshot is offline   Reply With Quote
Old 03-18-2011, 01:06 AM   #1530
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I considered one of these turbos for my car for a long time as I do a lot of autox and rallyx where quick spool is essential. In the end I went with a vf36 and could not be happier even though the cost is more.
Red line is current setup after we changed to a better dump pipe and higher flowing cat. 285hp if you can't be bothered converting.
JDwhiteWRX is offline   Reply With Quote
Old 03-28-2011, 02:59 PM   #1531
barryj
Member#: 146723
2005 WRX
Just gave Blouch to go ahead for the 19T upgrade on the TD04 I sent in.
Just FYI: the upgrade price is now $395.....not including fixing any problems with the turbo you send in....
Old 03-29-2011, 09:26 AM   #1532
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
^^What are you planning for injectors? Who is tuning your car when the turbo goes in?
Old 03-29-2011, 02:28 PM   #1533
barryj
Member#: 146723
2005 WRX
I got a Walbro pump and 07 STI blue Inj.
Grimmspeed EBCS, GS Up, GS PnP maniifolds, Invidia DP
The 19t turbo won't go in until April 21 when I take the car to the tuner down in Mass for the install and tune.
Old 03-30-2011, 08:48 PM   #1534
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Ok so I got my car on the dyno at Efi and here what I got .
02 wrx 115000 5s
Td04 19T H wheel and yes there are more mods .
Mustang Dyno report 258 Tq 3800 rpm
255 Hp 6300 rpm
I will post up the report later on,
The numbers are not bad but I know that it could of make more(how?), Well I did a compression test in Feb and got 120 psi in each ,yes its low but all read the same thats the good part,but if I did my math right I could of gotten close to 297 Tq and 301 hp if each cylinder was at 160psi
If I am wrong please correct me.
trinistyles is offline   Reply With Quote
Old 03-30-2011, 08:54 PM   #1535
azscooby
Member#: 115297
2002 ej207 vf34
I've been following this thread for quite some time and decided to give this a whirl.
I had installed a small 16g and was very unimpressed - spool time sucks....4100rpm 20psi.....that's not what I was hoping for.
So I'm going back to my TD04 with the 19t upgrade. I sent it off three weeks ago and look what arrived today!!
All I can say is WOW! this thing looks brand new, very nice work.
I do have some questions for you all.. I'm going for "spool like a son ova bitch". So I could use your input.
Current mods include
PnP exhaust manifolds,
Grimmspeed crossover pipe
Grimmspeed uppipe
Invidia divorced bellmouth downpipe
Greddy SP2 cat back
STI JDM V7 intercooler with scoop and splitter
Gimmick turbo inlet (would not recommend to anyone)
TGV deletes
Dark Blue injectors
Walbro FP
Grimmspeed EBCS
Is my crossover pipe going to kill my spool? I've heard mixed results.
Is there anything else I should change to minimize my spool time?
and the pics!
[IMG] Uploaded with ImageShack.us[/IMG]
azscooby is offline   Reply With Quote
Old 03-30-2011, 09:01 PM   #1536
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Grimmspeed crosspipe will not kill your spool up and I would go cat less also but thats just my 1c
Old 03-30-2011, 09:10 PM   #1537
azscooby
Member#: 115297
2002 ej207 vf34
Yep, catless already!
Old 03-31-2011, 04:01 PM   #1538
barryj
Member#: 146723
2005 WRX
AZ,
Looks good! It looks like Blouch Ceramic coated it and PnP it? What was that cost???
Should get my 19T in the mail today from Blouch!!!!
Old 03-31-2011, 05:13 PM   #1539
azscooby
Member#: 115297
2002 ej207 vf34
No ceramic coat ....I don't think, they just rebuilt it and did the upgrade. But I'm now wondering if they did, can't quite tell it just looks super clean.
I had pnp'd it beforehand, but it looks like they cleaned it up.
Very impressed with the work.
Old 03-31-2011, 09:43 PM   #1540
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Is that the stock turbine on there? looks like it wwas chipped,no mater you will love it.
Old 03-31-2011, 10:41 PM   #1541
azscooby
Member#: 115297
2002 ej207 vf34
not sure exactly what is stock and what isn't.
I do know the wheel is clipped (think that's what you meant.)
And yes, I hope i love it!
The lag on the 16g was horrendous - 4100rpms 20psi - was hoping for much better.
Hopefully this gets me under 3k rpms full spool.
Old 03-31-2011, 11:12 PM   #1542
barryj
Member#: 146723
2005 WRX
Alright....here's another TD04 19T...just arrived today....check it out and compared to AZ's!
Old 04-01-2011, 12:17 AM   #1543
xsnapshot
Member#: 170973
2004 WRX 4EAT
Do you have any idea of why your system was so laggy when others are seeing that amount of boost at least 500 RPM sooner on the small 16G in 3rd gear? I hate to see you downgrade to try and fix a problem with the wrong solution. Even on my slushbox 4EAT I see that amount of boost by 3700 RPM in 2nd gear.
I would double check your boost control system and tune, as whatever was hindering your spool on the small 16G could very well hold you back with this as well.
Old 04-01-2011, 08:27 AM   #1544
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Yep from Barryj pics I can see that the turbine wheel was chipped,looking good B
Old 04-01-2011, 08:55 AM   #1545
barryj
Member#: 146723
2005 WRX
Hey Thanks Trin,
I also got a Greddy Sprectrum Elite Catback showing up today ($625 delivered from Image Import...thanks Josh!)...Yeah!...more presents for me!!!
I'm looking forward to getting the 19T in and the low end torque and no lag...but an alterior motive was that at my Tuner it's only half the price to swap out the same turbo as compared to installing a totally new/larger turbo....that saves me $500!...which more than payed for the 19T.
Old 04-01-2011, 10:35 AM   #1546
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
What are you using for tuning software? Are you going opensource, accessport, something else? If you're using RomRaider/ECUFlash PM me your email addy and I'll send you the ROM image from my 19T'd '05 WRX.
Old 04-01-2011, 05:45 PM   #1547
barryj
Member#: 146723
2005 WRX
Hey Scooby,
Yep my Tuner says RomRaider/ECU Flash. Would love to see your ROM!
barryj01@msn.com
Old 04-02-2011, 12:46 PM   #1548
scprs
Member#: 172359
2005 STi
have this on my car for almost two years and have been very satisfied with it. I am making a switch though. I made 283/335 on a dyno jet.
scprs is offline   Reply With Quote
Old 04-02-2011, 01:42 PM   #1549
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i have looked through this thread alot and even though i am way past the point of the smaller turbos like these, i did once have an experiance with a turbo of the sort, i believe it was originaly a saab turbo, but basically it was about the same turbo yall are getting made, with the 19t, but the biggest advantage it had a a TD04Hl like they have here
http://cgi.ebay.com/ebaymotors/ws/eB...d=150582749243
i went ahead and had a 16g wheel put in, and it ran great, 285-295whp on air boys if i remember correctly ( its been 2.5 years ) but the biggest advantage i saw was that it made 20 psi at 3200 rpms, in third, and 3000 in 4th, and i think i managed 22psi at 3000 in 5th, it was a monster for down low torque and great mid range.
some of the research i did before i bought it
http://www.saabscene.com/forum/index...topic=31609015
and here is some i posted, i was wrong it spooled faster, http://forums.nasioc.com/forums/show...ghlight=td04hl
and pictures of said turbo
seanathanq83 is offline   Reply With Quote
Old 04-02-2011, 04:01 PM   #1550
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Hey Scooby,
barryj01@msn.com
I'll try to get it to you tomorrow afternoon.
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 09:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 09:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 11:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 02:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 08:19 PM
