Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 09-18-2009, 12:54 PM   #176
audsyn
Member#: 26112
2002 WRX Wagon
Originally Posted by Scooby921 View Post
So...I put the Monster TD04 up for sale to see if I can make some money off it and cover the cost of the 19T upgrade. But as I looked at it last night and took pics I kinda fell in love with the porting job that was done. Not only is the outlet nice and smooth, but the inlet looks amazing. Tell me its right to save money and not use something this beautiful on my car!
Can't you just swap the compressor wheel for the 19T and keep the ported/coated exhaust housing? Since it's new there's no rebuilding involved.
audsyn is offline   Reply With Quote
Old 09-18-2009, 12:59 PM   #177
Haelan
Member#: 151045
2013 Subaru STI
CBP
I'd be worried about making sure the balance is correct with the new compressor wheel. No telling if it will be ok at 150,000 RPM unless a professional inspects it.
Haelan is offline   Reply With Quote
Old 09-18-2009, 01:03 PM   #178
audsyn
Member#: 26112
2002 WRX Wagon
I meant, still send it in to Blouch to install the wheel and balance it. But if it's new they won't have to do any rebuilding and obviously no need to port the exhaust side. Then you'll have both Monster hot side and 19T wheel.
Old 09-18-2009, 01:56 PM   #179
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
That was my original plan, but then I had a thought about saving some money. As was suggested/noted earlier, I can sell the Monster and the amount I make off of it would likely cover the cost of putting the 19T into a regular stock turbo. Then my only expense is injectors since I already have a walbro pump. So its up for sale for a week...if no one wants it I'll continue as planned and have a Monster 19T .
Scooby921 is offline   Reply With Quote
Old 09-18-2009, 04:25 PM   #180
RogerGTS
Member#: 69804
I thought my drive sucked...I live in Madison Heights and work in Novi. My drive is within your's .
RogerGTS is offline   Reply With Quote
Old 09-21-2009, 09:03 AM   #181
isis
Member#: 73283
05 CTS-V
03 Z1000
Originally Posted by bluerex47 View Post
Isis - If I remember right, you're using 575 pink injectors correct? How are those handling the setup? Do you feel those are more than adequate or should you have gone with something more...say 650s?
Modded stock injectors. Price is right
Pinks should work fine on a 2.0, no clue if the 2.5l would need more. I wouldn't bother with this turbo on a 2.5 though..
isis is offline   Reply With Quote
Old 09-21-2009, 09:21 AM   #182
aaronzgod
Member#: 196050
2002 VF-39 Rex
02C
okay so final word is this turbo produces more power and faster spool then vf39 my vf39 blew and thinking of getting another one or doing this mod to my td04
aaronzgod is offline   Reply With Quote
Old 09-21-2009, 12:49 PM   #183
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
According to specs the VF39 should still produce more peak power since it flows more air. Someone posted a plot showing the 19t making more power than a vf39, but I don't entirely believe it. The 19t makes great power numbers, but the VF39 should still be capable of a higher peak number.
The difference is that the 19t on a td04 turbine is going to spool faster and give you a broader range of useful power. If you want more power across more RPM the 19t is the better choice. If you want higher peak numbers go for another vf39.
Old 09-21-2009, 02:06 PM   #184
t00sl0w
Member#: 222521
2002 PSM wrx
soon to have 16g...yay!
enouogh bickering and chat chat...lets see a dyno!!!!
i am sending mine off to blouch shortly, and i want to knwo what to expect
t00sl0w is offline   Reply With Quote
Old 09-21-2009, 05:59 PM   #185
bluerex47
Member#: 73331
04 wrx
world rally blue
Check out the first pages. There are some dyno charts on there. Whenever mine comes to fruition there will be dyno charts for sure.
Hmm good point. However its tough to go back to stock lol. I'm going to have to think about this one. Thanks for the input!
bluerex47 is offline   Reply With Quote
Old 09-21-2009, 08:34 PM   #186
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
I'll place my bet now. All other mods being equal, the VF39 runs away from it at the strip.
Dave D. is offline   Reply With Quote
Old 09-21-2009, 09:23 PM   #187
AllAWD
Member#: 17079
I'd agree, but if that's your concern you are in the wrong thread. VF39 is going to be the best bang for the buck on shear acceleration at the strip.
I place more importance on faster spool for more fun on the street. I can't wait until i can afford the 19t and tune. I have spare injectors and a TD04 just waiting to be modded.
AllAWD is offline   Reply With Quote
Old 09-21-2009, 10:11 PM   #188
slowgrey08
Member#: 211738
2015 STI LE
2014 SWP Forester XT
I understand the more fun on the street bit, but unless your always just streetlight racing or something, the vf39 would be better IMO. Im always running outa breath at the top of my gears, and there is only so much a td04 can do at speeds over 60mph.
slowgrey08 is offline   Reply With Quote
Old 09-21-2009, 10:34 PM   #189
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
It all depends on what you desire. A turbo with quick response and good low-end torque is going to be better for daily driving in the city or congested expressways. If you drive through open roads and low traffic areas then I'm sure you'd find more enjoyment from the top-end a VF39 provides. If you're going to the drag strip the VF39 is obviously the better choice. If you're going to an autocross or doing a track day at a twisty track the 19T is going to pull better out of the corners and negate any advantage you have with the peak power from the VF39.
Old 09-21-2009, 11:02 PM   #190
xsnapshot
Member#: 170973
2004 WRX 4EAT
I don't understand the confusion on the capabilities of this turbo. The 19T flows 500 CFM @ 2.0 PR. (inlet temp 20 degrees C).
This is essentially a 16G worth of flow. The problem lies in the small TD04 hotside. This can be alleviated by a good port job and EWG, no clipping neccesary (good thing too).
metric units http://www.stealth316.com/images/td04h-19t-raw.gif
Standard units http://www.stealth316.com/images/td04h-19t-cfm.gif
I wouldn't be surprised to see someone hit darn near 300whp on 93 oct +meth on a really agressive tune. I just think everyone underestimates its potential and would rather just slap on a 16G/VFseries and be done with it.
If i were ever to upgrade turbos on my 2.0L, this would be the route i would go hands down.
xsnapshot is offline   Reply With Quote
Old 09-21-2009, 11:26 PM   #191
bluerex47
Member#: 73331
04 wrx
world rally blue
^^I've looked at the graphs before and done my homework too. Those graphs are a great help! Unfortunately, though, neither link worked for me.
I'm not planning on running an aggressive enough tune, but its nice to know that capabilities should theoretically be there.
Edit - If you search for turbo help threads, you can do all the math to determine how much boost you make at which rpm, and can basically chart how the engine should operate with the turbo. You can also theoretically determine your horespower ratings. Keep in mind though, that there are variables that can't be 100% accurate (such as VE). Search for the "13T compressor charts" and "reading compressor charts" if you're interested.
Old 10-02-2009, 02:59 AM   #192
scoobyWRXlove
Member#: 222927
Any 1/4 times on 19t?
scoobyWRXlove is offline   Reply With Quote
Old 10-02-2009, 03:47 PM   #193
dinosmash
Member#: 143598
05 lgt
Default im going next wed
so ill keep you posted.i have cut many 1.7 60ft times last time out with a small 16g.so my time should be a good estimate of what this thing can do at the track.
dinosmash is offline   Reply With Quote
Old 10-07-2009, 10:49 PM   #194
dinosmash
Member#: 143598
05 lgt
Default disappointed but ill try again in april
the track was so wet tonight it opened at 5 but we couldnt race until 730.
even when i had bald tires i had more traction cutting a 1.8 60ft.with new tires i cut 1.7 all day long.tonight 2.6 60ft all night.i just sat on the line doing 4 wd burnouts.even without a launch once my mbc hit i span the tires.best i could manage was a 14.1 at a little over 100 mph with the 2.6 60ft.id like to thank the guy with the mop who sopped up water for me at the starting line.this is by no means what this turbo can do .
Old 10-08-2009, 05:21 PM   #195
04 Wagon Boy
Member#: 181260
2004 Wrx
So what are you thinking the turbo is capable of? What were you running for boost?
04 Wagon Boy is offline   Reply With Quote
Old 10-08-2009, 08:54 PM   #196
dinosmash
Member#: 143598
05 lgt
20psi.spiking to 22 because it was cold out.i dont know what itll run for sure as i dont have any reference.ill be going back again next week.its burning me up not knowing what it will run.
if every tenth in the 60ft equals two tenths on the et.then the guesstimate mid 12s.car pulls strong real from beginning to end .i wont know for sure till i run it on a good night.car hooked better on the street than at the track go figure.
because of the power the car makes down low and the loss of traction.i felt like i was driving a mustang.
Old 10-08-2009, 11:47 PM   #197
bpang1
Member#: 67225
2015 Audi S4
Red
Man, this thread is great. This turbo is a pretty compelling upgrade. I was thinking I would need to spend a lot more cash but if i can just buy this turbo plus my current mods:
PDE DP
Turbo XS UP
K&N Filter
Opensource Tune
...do you guys think I would be golden or do i need the Pinks and the upgraded BCS? Obviously I would get re-tuned after the install.
I'm not looking for huge power moreso an upgrade for the street and auto-x...I hate having to deal with turbo lag and if this thing spools like others have posted...damn this might be the ticket.
bpang1 is offline   Reply With Quote
Old 10-09-2009, 03:15 AM   #198
xsnapshot
Member#: 170973
2004 WRX 4EAT
PDE DP
Turbo XS UP
K&N Filter
Opensource Tune
You'll need pinks or equivalent. This turbo has the flow potential of a small 16G. You'll want an upgraded BCS too for optimal spool up.
If i was upgrading on this turbo, i would send it in, and have the turbine ported (not clipped) with respect to blocking off the IWG and running EWG, then i would do pnpnc stock exhaust manifold with a 3-port BCS all on E85. Talk about quick spool up....
Old 10-09-2009, 11:42 AM   #199
samo22
Member#: 119693
1995 L w/ ej205
Yeah definetly go with sti pinks/550cc+ injectors or just mod your stock injectors. Also you should get an upgraded fuel pump. For maximum spool, you could do tgv delete and turbo inlet while you send in your turbo. I'd definetly do ebcs since you're gonna tune anyways. Maybe consider going with sti tmic or something similar since 19t has the flow potential of a small 16g.
samo22 is offline   Reply With Quote
Old 10-09-2009, 02:07 PM   #200
bpang1
Member#: 67225
2015 Audi S4
Red
Thanks to both of you. I admit I only read Page 1 and from what I was seeing I didn't see anyone mentioning an upgrade to their fuel pumps but it made sense given that all other turbo upgrades need that. So here's my shopping list:
UP - Done
DP - Done
Filter - Done
Blouch 19T with PNP
STi Pinks or mod stocks, whichever is cheaper
Walbro FP
BCS (which one is good/appropriate for this build?)
Trying to keep costs down and also noise down which Is why I need to stick to IWG vs. EWG.
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 09:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 09:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 11:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 02:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 08:19 PM
