Old 10-24-2008, 12:17 PM   #1
bape-ape
Member#: 136009
96 RapeWagon
Ugly
Default JDM 207 GC8 ECU vs US gas?
Would there be a problem with the JDM GC 207 on US 93?
bape-ape is offline   Reply With Quote
Old 10-24-2008, 12:38 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
few factors
A:sti or sti RA
B:93 or e-10 93
Old 10-24-2008, 12:40 PM   #3
bape-ape
Member#: 136009
96 RapeWagon
Ugly
non sti, Might be a type R coupe if that maters
Old 10-24-2008, 06:45 PM   #4
folkstyle171
Member#: 134326
1998 STi Type R
I may be wrong, but I thought all the type R where sti? (mine is)
On my old 20k I ran 93 (us gas) for about an hour, then drained the tank and did a proper fill. I don't think there was any pre-det, but it ran really rough. That could have been the crappy gas too though.
folkstyle171 is offline   Reply With Quote
Old 10-24-2008, 07:25 PM   #5
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
I run 93 on my version 8 JDM STI swap and I notice knock when I'm at low RPMs (before knock correction kicks in) I use alcohol injection to bump up the octane when in boost. It would probably be a good idea to tune for whatever fuel you are going to run.
IMPREZive 02 WRX is offline   Reply With Quote
Old 10-25-2008, 10:29 AM   #6
theonlygreat
Member#: 65916
1996 Impreza WRX
Just fill it up with premium and you will be fine if the engine is stock. Japan uses only RON which ends up being a higher number than our system (RON+MON/2) with basically the same fuel. If you don't know what RON and MON are, google it!
theonlygreat is offline   Reply With Quote
Old 10-25-2008, 12:39 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes but e-10 93 has a different lambda than 93 with no ethanol
needless to say my standard 97 wrx, which has a j&s safe guard, pulls timing regularly under boost..
Old 10-25-2008, 06:30 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Zach, is that you?
USDM STI ecu vs JDM STI ecu Gadiel Engine Management & Tuning 4 11-15-2011 09:41 AM
tuning a usdm 02 wrx ecu vs. a jdm 02 sti ecu domestic_abuser Engine Management & Tuning 1 03-26-2008 06:23 PM
GC8 EJ20K exhaust manifold VS US WRX exhaust manifld keirnna Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-01-2008 04:40 PM
USDM STi vs JDM AVCS vs US WRX timing belt cover CTKAG Subaru Conversions 1 03-25-2006 09:22 PM
JDM STI GC8 to US GC8 houston1 Subaru Conversions 9 06-10-2003 06:43 PM
