Old 07-30-2013, 10:52 AM   #1
EEkShh
Member#: 317977
OMGHi2U Misfires-not throwing codes...anymore
Hey guys a little backround:
I have an 02 WRX, pretty much stock so far only and AEM short ram (Which I took off) and a Turbo XS 50/50(I recently swapped back to the stock one with a new gasket). When I first got car I was not throwing any cells. About 6 months past, got into winter and all of the sudden I'm throwing misfire codes on Cyl 1 and 4. It can randomly popup at times, but the majority of the time it early in the morning when it is very cold, and only once the car gets to operating temperature, and the code shows up. I look at the code history and everytime it shows that the code pops on at 733rpm and no engine load. This morning I left for work and attempted to accelerate at about 3/4 throttle and the engine fell on its face, I let off the gas and it returned to normal. It was boosting 14.5 psi but now will only boost to a max of 6.6lbs(I've since fixed this-by replacing the boost solenoid). The IAM or DAM is at 16 so it shouldnt be running in "limp" mode. I've read a lot of forum posts and tried quite a few t/s steps but as these misfire codes seem to be a common issue I figure this a perfect place to share information (and help me get this figured out) Other good information...awhile back I had a friend hook up a tactrix and drive around with me and we noticed that at about 3k rpm the ecu is pulling timing.
- I'm not burning oil
-Compression tests came out good
-I'm not losing coolant
-I'm not blowing any smoke out the tail pipe
-I am no longer throwing any codes(only misfires in the winter)
-Issue remains
What I've done so far;
- Cleaned grounds(Intake manifold, ground by pitch mount, main ground from battery etc)
- Run several fuel injector cleaners thru the system
- replaced the fuel filter
- replaced spark plugs (stock factory recommended plugs and gap)
- double checked coil pack connections, white plugs in front, black plugs in back
- cleaed connections
- removed coilpacks and cleaned mounting surface
- replaced turbo inlet hose (was torn badly, post maf un-metered air)
- cleaned MAF very gently
- replaced cracked vacuum hosing(and replaced the pill)
- checked intercooling pipe, hoses
-cleaned IACV
**Recently**
*Swapped coilpacks 1 to 3 and 2 to 4
*performed boost leak test
*com,presion tested all 4 at 120 (I forgot to pull the fuel pump fuse and hold at WOT while testing)
*changed sparkplugs to factory part number, verified correctly gapped
*Bought an Access Port, Flashed to Stage 1 OTS
*Returned to the stock OEM Map
*Tested for boost leak- No leak present
*Replaced Intake Manifold and TGV gaskets
*Replaced injectors with know good ones (stock injectors)
*went thru entire Vacuum system and replaces all lines
*Replaced all PCV breather lines
*Replaced PCV valve
*Ran Sea Foam thru Vacuum line to clean carbon build up
*Recleaned all grounds
*Replaced the "blue vacuum t-fitting" behind the alternator
*Replaced boost solenoid- boost returned to normal
*Removed AEM intake, went back to stock
*Replaced Stock FPR with Tomei FPR
EEkShh is offline   Reply With Quote
Old 07-30-2013, 07:57 PM   #2
KFREX
Member#: 330609
2016 Subaru WRX
I really hope you figure this out, I am in a similar situation and its tearing my brain apart.
KFREX is offline   Reply With Quote
Old 07-31-2013, 02:59 PM   #3
EEkShh
Member#: 317977
Default Me TOO
Me Too, I'm losig my mind on this one. I've never been stumped by a car issue but this one is kicking my a$$! I've been monitoring my front o2 sensor and it seems a bit lazy but no code. Might try swapping o2 sensor with a know good one and see if that helps. I'm really running out of ideas. I talked to my local Subaru dealership and they said they had two stock maps released by Corporate Subaru for misfires and pinging. He said that Subaru doesnt release this info and the only way you find out about this map is by finding info on the forum. They said they would reflash my ecu for 60 bucks with the most recent Ping/Misfire fix map. I thought that maybe the issue however I did flash to an Cobb AP Stage 1 Tune and the issue persisted. I'm starting to wonder tho, if maybe the stock map changes some parameters that the Cobb access port does not change. I'll let you know when I figure this out.
Old 07-31-2013, 09:39 PM   #4
hoffmanEstates
Member#: 122043
04 wagonier
psm
Try buying new packs, i did at 100k as they are a wear item and fail at any point
hoffmanEstates is offline   Reply With Quote
Old 07-31-2013, 09:56 PM   #5
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Before you go spending more money clean your crank angle sensor and cam angle sensor. The problem has nothing to do with your stock map.
And read this, http://forums.nasioc.com/forums/show....php?t=2318069
2gnt2wrx is offline   Reply With Quote
Old 08-01-2013, 10:26 AM   #6
EEkShh
Member#: 317977
Default Thanks
Thanks I will try that and report back. I already swapped coilpacks with my buddies bugeye with no change so I know its not them. The clips are solid and not broken and stay on with no issues. Have you hada simalar issue on your 2002
Old 08-01-2013, 10:29 AM   #7
EEkShh
Member#: 317977
I've actually read thru that forum post several times but for some reason skipped over it
Old 08-02-2013, 12:39 PM   #8
EEkShh
Member#: 317977
Checked Cam sensor last night, It had a little dust on it, cleaned it off but no change. Will pull the alternator this weekend and check the Crank Sensor
