Old 12-16-2008, 02:14 AM   #126
STI_KLR
Member#: 189660
'02 WRX
Element Tuning Race Team
Originally Posted by Audiosavvy View Post
Yep, that's a defect, not a connection problem. But they're taking care of it, you can't ask for much more than that, especially for the price (let's face it, if it was the same price as the Koyo then none of us would have one ).
+1
totally agree.
STI_KLR is offline   Reply With Quote
Old 12-18-2008, 05:23 PM   #127
PSI_XTC
Member#: 123386
'12 IS-F
'08 Saab 9-3 TurboX
I'm definitely going to be getting one of these radiators, but had a quick question for those running them on their '02's. Is it easier to go with the radiator with the cap on it ('03+ WRX/'04+ STI dual cap setup) for filling purposes or should I stick with the non-capped tank only '02 one? Also, if I do end up going with the dual cap setup, can someone take a picture of their setup, so I have a general idea of what additional material is needed to adapt the duals. Don't want to bring a knife to a gun fight.
Geez, I'm so demanding. Thanks guys!
PSI_XTC is offline   Reply With Quote
Old 12-18-2008, 05:30 PM   #128
STI_KLR
Member#: 189660
'02 WRX
OEM style if you want to save $$$
Old 12-19-2008, 12:51 AM   #129
supersuby2
Member#: 161678
2002 wrx V5 RA swap
Thats one of the reasons i got this brand is because you can get either on with the cap or without. getting the one without makes install easier but it may be easier to burp the system with the 2 caps but im not sure. I would recomend getting the oem 2002 style without the cap for easier install and less expense.
supersuby2 is offline   Reply With Quote
Old 12-19-2008, 12:56 AM   #130
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
I got the OEM-style because I'm stingy with my $$
Audiosavvy is offline   Reply With Quote
Old 12-19-2008, 02:05 AM   #131
STI_KLR
Member#: 189660
'02 WRX
Old 12-19-2008, 12:33 PM   #132
PSI_XTC
Member#: 123386
'12 IS-F
'08 Saab 9-3 TurboX
Thanks guys! I'll save my money for the hookers and blow (or the coolant to fill up the radiator).
Old 12-19-2008, 01:06 PM   #133
STI_KLR
Member#: 189660
'02 WRX
or both.
Old 12-19-2008, 02:10 PM   #134
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
So what is needed to convert to the two-cap style of the newer ones?
It looks like just a plug for the breather hole on the new cap mount, and a new cap....
What am I missing?
DiscoGsus is offline   Reply With Quote
Old 12-19-2008, 07:24 PM   #135
PSI_XTC
Member#: 123386
'12 IS-F
'08 Saab 9-3 TurboX
Originally Posted by STI_KLR View Post
or both.
I like the way you think
Old 12-22-2008, 01:21 PM   #136
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I installed my cxracing radiator on saturday and haven't had any leaks thus far. Fitment was very good, and it looks badass.
2gnt2wrx is offline   Reply With Quote
Old 12-22-2008, 02:43 PM   #137
Strider327
Member#: 131280
2004 Impreza WRX
Okay installed the new radiator that came in. So far so good, I don't see any leaks as of yet which is good. Knock on wood.
Strider327 is offline   Reply With Quote
Old 12-22-2008, 03:05 PM   #138
STI_KLR
Member#: 189660
'02 WRX
hah, yes, *knock on wood*
but hopefully everything works out for y'all
Old 12-22-2008, 03:05 PM   #139
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
The only real thing I'm worried about is that o-ring on the petcock. Did everyone just leave it on or did you guys use a different o-ring?
Old 12-22-2008, 03:06 PM   #140
STI_KLR
Member#: 189660
'02 WRX
i had to use a crush gasket because my o-rings kept failing... but that was just me; no one else has seemed to have problems w/ the o-ring. i would test it first (if u haven't installed it yet) to make sure it doesn't leak.
Old 12-22-2008, 03:08 PM   #141
Audiosavvy
Member#: 150794
Qcab dakota 4x4
I used the OEM petcock and o-ring because the new one was broken during shipping such that the o-ring was pinched and compromised. It took a few days of gradual tightening (just a tiny bit a day as it was warm), but went just fine.
If it were me, I'd use the new petcock and o-ring.
Old 12-22-2008, 03:09 PM   #142
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Everything is installed and working properly but it made me raise an eyebrow when I tightened it. I'll just keep an eye on it. The stock drain didn't appear to have a gasket or ring on it though.
Old 12-22-2008, 03:46 PM   #143
STI_KLR
Member#: 189660
'02 WRX
i bought a crush gasket to use... the petcock that came w/ the radiator should have had an o-ring already on it.
Audiosavvy- how'd you use the stock petcock? mine didn't fit in the new raditator
Old 12-22-2008, 05:03 PM   #144
Audiosavvy
Member#: 150794
Qcab dakota 4x4
ninja
Old 12-22-2008, 05:55 PM   #145
STI_KLR
Member#: 189660
'02 WRX
ninja
Damn, should have known
Old 01-05-2009, 09:28 AM   #146
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Update: The Oring that came with the radiator on the draincock has failed. I did two fairly long trips over the holidays with no problem and it failed last night when I was taking my girlfriend out to eat. I noticed that the heat wouldn't turn on so I investigated. I pulled the oring out and just tightened the drain down as much as i could. There is no coolant leaking out. I also never saw a gasket on the stock one. Can someone verify that the stock plug does or does not have a gasket on it?
Old 01-05-2009, 11:19 AM   #147
STI_KLR
Member#: 189660
'02 WRX
My stock plug had an o-ring on it AFAIK.
Old 01-05-2009, 11:37 AM   #148
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Mine did. As mentioned somewhere in this thread, the new o-ring and petcock was compromised in shipping, and so I re-used the stock o-ring/petcock.
Old 01-05-2009, 01:14 PM   #149
Strider327
Member#: 131280
2004 Impreza WRX
The one that comes with it is not efficient and does not fit properly. I had to go out and buy a variety pack of o-rings and finally found one and fit snugged like the oem one did.
Old 01-05-2009, 02:29 PM   #150
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Thats what I'm thinking, But i just removed the o-ring and snugged it down. I don't have a leak Yet anyways...
car go bye bye sale, go fast parts valleysti Engine/Power/Exhaust 19 02-25-2009 11:41 PM
My Brother Go Bye Bye MarcinsSister Mid West Subaru Owners Club Forum -- MWSOC 21 03-08-2003 07:50 PM
ByE ByE biRDIEZ!!!! GO GIANTS WWWOOOOOO NeuBluScoobyBoi Bay Area Impreza Club Forum -- BAIC 1 10-15-2002 01:05 AM
Oh Joy.. my company is probably gonna go bye-bye... Hazdaz New England Impreza Club Forum -- NESIC 5 07-19-2002 06:47 PM
