Old 06-12-2010, 09:44 PM   #101
Frank_Zuccarini
Member#: 88939
2011 WRX STi Hatch
World Rally Blue
I can't help chiming in on this evil hill assist thread.
But first, I think that some people don't grasp the concept that most Subarus with Hill Assist have a mechanical system, which releases when the clutch is just about to be engaged, whether it has been brake locked for one second or one hour. Only the 2009+ STi's have an electronic version, which uses a timer, but makes it easy to disable this 'feature'.
My Forester has the mechanical system, which works reliably and precisly as designed to do. I do not need it, and I would much prefer if it did not exist. I can physically remove the system from the car, but I've decided that doing so would be more of a pita than living with it. And by the way, my biggest problem with it is that my garage is at the top of a steep driveway. Every day, as I back out of the driveway, I engage the clutch to roll out of the garage. Then, gravity takes over and I begin to roll down the hill. I immediately disengage the clutch since my speed quickly exceeds that which will ensure that I bottom out at the gutter. Gravity still speeds me up to the point that I must slightly brake the car. And here is the dig. Every time I apply the brake, the hill assist engages and totaly stops the car. So, I must re-engage the clutch 3 or 4 times just to safely roll to out to the street. This is a pita, and causes needless wear on the clutch.
Being able to deactivate the Hill Assist on the newer STi's is nice, but why on earth is the default position 'On'. I don't need (or want) the thing, so why must I turn it 'Off'? I can easily see that it has value for newer drivers, but imho, these drivers should have to turn it 'On', and they can deal with the indicator light. It's the same thing with my "Self-Dimming Rear View Mirror". I find this feature annoying any time except at night, on the highway, and yet I must disable it nearly every time I get into the car. Again imho, I think that it should be 'Off' by default, and turned 'On' by those who desire it. It came as part of a package or else I would not ever have had it in the car.
I'm done now. Thanks for listening......................Frank
Frank_Zuccarini is offline   Reply With Quote
Old 06-12-2010, 09:45 PM   #102
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Originally Posted by etothen View Post
Same here, driven manuals all my life and I never, ever have noticed the hill assist holding the 09 as the clutch engages, not once in 30k mi and I regularly park at my moms house when I visit (she loves her granddaughter) , both ways on one of the steepest hills on the west coast, no problems ever.
Well... Then this "feature" was made for people like you... or...
1; It isn't working right in my car... cause it SUCKS...
2; It is working right in you guys cars... good for you...
3; It is working right in everyone's car and some people actually need it...
4; Nobody should actually need it... And if they do, then maybe they shouldn't be driving...
JMO... Been driving for almost 40 YEARS and in ALL those years have stalled a car/vehicle, maybe, 5 times, including learning to drive stick... This '09 STi I have probably stalled 15 times in the last year... Something is just not right with this system... Boo... Hiss... Subaru.
wrxdrvr is offline   Reply With Quote
Old 07-10-2010, 09:14 PM   #103
Rex2008
Member#: 198257
2008 WRX
WR Mica Blue
No offense Frank, but I don't believe the 2009 STI's are the only ones with a electronically controlled Hill Assist. As I recall when I look at my WRX 2008 transmission, there was no mechanical hill holder attached to it. On the older subarus there was a cable attached to your bell housing on the tranny that allows you to adjust your hill holder which you could disable by simply taking it off.
There isn't anything like that on the 2008 WRX. Not to mention there is a warning light on the dash when it's disabled which leads me to believe that it's electronically controlled. If your referring to the actual "brakes" as being mechanical then yes I would have to agree.
I personally hate the hill assist. I have to get my motor up to about 1.5-2k and then release the clutch only to watch it bolt forward and almost stall out. Makes me look like I can't drive a manual when I've been driving one since I was a young buck.
Rex2008 is offline   Reply With Quote
Old 07-12-2010, 12:35 PM   #104
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Yeah, the Incline Start Assist was introduced on the '08 Impreza.. all models... then the '09 Forester and then the '10 Legacy/Outback. The '09+ WRX and STI are the only cars that can have the ISA disabled. It's the same system in the '08.. but the controller doesn't have the software for switching it off.
The Hill Holder was a mechanical system that pre-dates ISA and was only on the Forester by '08 (?).
Old 07-12-2010, 01:00 PM   #105
hieu1004
Member#: 240385
E92 BMW M3
I believe only the STi does, my '10 WRX does not have the ability to disable ISA, at least to my knowledge....
hieu1004 is offline   Reply With Quote
Old 07-12-2010, 01:10 PM   #106
Lboogie
Member#: 171611
2014 FiST
Blk
I found the incline assist to be very handy when getting out of an uphill parking spot in one of the hilliest parts of San Francisco, with a car full of people, at night. No clutch killing needed thankfully.
Lboogie is offline   Reply With Quote
Old 07-12-2010, 04:39 PM   #107
BoneJj
Member#: 222089
Satin Pearl White
I've come to realize that I can get around the hill start assist by not holding the brake pedal down too hard. mine only engages when I put the brake pedal down hard while stopping. Also if you shift to neutral while at a stop light this will disengage the hill start automatically as well. So now when I come to a stop I stay in neutral or switch to it as I stop or I just don't hit the brakes that hard as I come to a complete stop.
I've been trying to find a way to disable it without unplugging things in my WRX and that has come to no solution but in that time I have learned to work around it.
BoneJj is offline   Reply With Quote
Old 07-12-2010, 05:02 PM   #108
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
That is the whole point of this thread... We shouldn't have to Work around it... The people who need this feature should be the ones turning it on...
Old 07-12-2010, 05:06 PM   #109
BoneJj
Member#: 222089
Satin Pearl White
trust me, i completely agree with that statement but it's one of those things that for ow we just have to suck up and deal with unless we want to start hacking up wires and messing with other things.
There is a tilt sensor that is supposed to be in the system somewhere to help make the system engage more on hills, maybe if you find a way to make it read level all the time it wont engage the system nearly as much...
Old 07-12-2010, 05:10 PM   #110
rugger17
Member#: 248147
2010 WRX
the instructions to disable the hill assist program is listed in the owners manual for my 2010 wrx
rugger17 is offline   Reply With Quote
Old 07-12-2010, 05:14 PM   #111
scott.olson
Member#: 227718
I have an 05 Forester XT with the hill holder, not sure if it was on the 04 or not
scott.olson is offline   Reply With Quote
Old 07-12-2010, 05:18 PM   #112
hieu1004
Member#: 240385
E92 BMW M3
If you look closely, you'll see that it is for the WRX STI. If you didn't know, Subaru manuals are written generically....
This is taken directly from my 2010 WRX manual, see below:
Old 07-12-2010, 05:26 PM   #113
BoneJj
Member#: 222089
Satin Pearl White
^^^ beat me to it...
while it is in there, it doesn't work. I tried 20 times to get it to work and it doesn't. It only works on STi models.
Old 07-12-2010, 09:04 PM   #114
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Why, yes it is... It's on my '09 STi too, and yes, I CAN turn it OFF... but why should I have a warning light on, my instrument panel all the time warning me that my hill assist is off????? It's BS... Cars manufactured for the dumb/uncoordinated that shouldn't be driving anyways...
EDIT; And for those of you that think the hill assist is the cat's meow... Maybe you shouldn't have a drivers licence.... Same as with all these other "helpers" that are coming out... Lane change beepers, automatic parking, automatic braking when too close to other car when catching up.... Sheesh get a cab if you actually need any of these "features'...
Old 07-13-2010, 01:54 PM   #115
Lboogie
Member#: 171611
2014 FiST
Blk
It ain't the cats meeow, but it is handy 'when needed', like traction or stability control, or ABS, or Airbags, or crumple zones.
Remember that in AWD cars like ours, it takes a little more energy(controlled) to get the entire drivetrain into motion.
I actually enjoy some of Subie's "low tech" nature, ascompared to all the gadgets and helpers in the Evo and GT-R. People drive them and are like "omg I can do anything in this car!" Yeah cuz the computers and mechanical devices are doing all the work bub.
It can be a slippery slope from a simple vehicle feature (drl's, hill assist) to replacing the driver (auto braking, self parking).
Old 07-15-2010, 08:34 PM   #116
funnycar
Member#: 75253
2008 STi
wrb
Originally Posted by hieu1004 View Post
That's odd, my hill assist releases the instant the clutch grabs and have never stalled.
+1. I don't need it since i've been shifting gears for decades, but it's not a hinderance.
funnycar is offline   Reply With Quote
Old 07-15-2010, 10:24 PM   #117
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Well, it certainly IS a hindrance to me on my '09 STi... It DOESN'T come off with the clutch (it has a timer), It comes on even on flat ground when I stop fast and the car squats it thinks it's on a hill... It's just useless/stoop-id and frustrating to deal with. And yes I could turn it off but then there I sit, staring at this yellow warning light every-time I drive it...
Old 07-15-2010, 11:27 PM   #118
hieu1004
Member#: 240385
E92 BMW M3
You have the option to turn it off but complain about a warning light.... I agree it is stupid and silly, but if you really hate it that much, just get a different vehicle.....
Old 07-16-2010, 12:06 AM   #119
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Naw, I just want some cheese with my wine...
Old 07-17-2010, 04:11 PM   #120
funnycar
Member#: 75253
2008 STi
wrb
Maybe a dealership could replace the tilt indicator. I believe a "could not replicate" would be the analysis...
Old 10-27-2010, 03:07 PM   #121
makopolo
Member#: 260046
2011 WRX Hatchback
2011 WRX and those instructions only apply to the STI. I really want to turn it off because I drive my buddy's truck fairly often and dont want to loose the practice of starting on a hill. Plus I like a manual transmission because of the extra work to get from A to B......
Really which I could turn it off permanently, but dont see how
makopolo is offline   Reply With Quote
Old 11-20-2010, 10:34 PM   #122
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
The1SloR/T is offline   Reply With Quote
Old 03-26-2011, 10:26 PM   #123
Mr Joshua
Member#: 276568
2011 WRX STI Sedan
Obsidian Black Pearl
Originally Posted by Cocoa Beach Bum View Post
Disabling Hill Start Assist is possible only on STI model and results in instrument panel warning light staying on when you drive.
I found the same information in section 7-41 & 7-42 of the 2011 Impreza Owners Manual.
It seems to be still only available for STI models even in 2011 which is too bad for people with other models that suffer with the HSA gremlin..
God knows i've stalled mine 3x so far and i've been doing hill starts for 25 years.
Mr Joshua is offline   Reply With Quote
Old 04-07-2011, 06:55 PM   #124
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Yeah, same here- just bought a 2011 wrx and after driving my 2008 sti with the hill start assist disabled, I had forgotten how much I hated it. Stalled the WRX like 10 times already. Don't ask me how the hill start assist was disabled on my sti because someone helped me with it and I don't know what they did, but now I'm going to find out how to do the same on my WRX. Pretty sure Subaru knows a way, they just aren't telling us.
Frank A is offline   Reply With Quote
Old 04-08-2011, 07:45 AM   #125
Mike.J
Member#: 174522
08 STI
I have an 08 STI and would love to turn it off. I’ve been driving manual cars since 1997 and I don’t need it. I REALLY HATE IT when I stop on an incline so small that I don’t notice it, but the Hill Holder locks my brakes. Then when I start, I almost stall and look like a noob.
Mike.J is offline   Reply With Quote
will 08/09 sti side skirts fit 08/09 wrx sedan? slowgrey08 Newbies & FAQs 3 08-04-2015 08:24 AM
08/09 WRX Tail Lights vs. 08/09 STI Tail Lights elscoobie20 Interior & Exterior Modification 2 07-22-2009 05:11 PM
Need STOCK 06/07 WRX, 08/09 WRX, and 08/09 STI dynojet plots or numbers Unabomber Proven Power Bragging 17 03-04-2009 04:27 PM
Will a coilover for an 08/09 hatch work for an 08/09 sti? pio!pio! Brakes, Steering & Suspension 1 12-13-2008 07:28 PM
My 08 WRX and Hill Assist nova7ny General Community 64 02-23-2008 03:50 PM
