Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 10-24-2008, 08:07 PM   #1
jays05
Member#: 78165
05 STI 35r + e85
Default 505whp @ 21-22psi straight 93octane NO METH
Yeah!!!
I had my STI tuned by Junior at The Shop CT today.
It made 489whp and we were just about to say "that's enough" and do a road test, when I remembered about the QTP cutout. So Junior made another pull with the cutout open and bam, 505whp. We had to stop here because the car is out of fuel. Next spring I'll have it retuned with some DW1100s.
This is on straight New York E10 93 octane piss, no meth injection, race gas, or crazy timing/AFRs.
Engine Mods
Block bored to 100mm
CP Pistons + Rings with skirts coated by Swaintech
Pauter Rods
ACL Main Bearings .25mm under
OEM Rod Bearings
Crank/Rods/Pistons balanced
OEM Head Gaskets
ARP Head Studs
Cosworth Cams 278/274 AVCS
Supertech dual valvesprings, TI retainers
Supertech +0.5mm Stainless valves
OEM timing belt
Cosworth timing belt guide
Cosworth 10mm Oil Pump
Moroso Oil Pan
ATI Super Damper balancer
Crawford Air/Oil Separator
Cylinder head work by Applied Flow Technology
Engine assembled by Ron @ RAW Performance
Installation and fabrication work by Synapse Motorsport
Fuel System
Dual in-tank walbros
Perrin fuel rails
PE 850cc injectors
Grimmspeed 8mm Phenolic Gaskets + TB Coolant Bypass mod
Forced Induction
Garrett gt35r .82ar
Tial 44mm EWG
Custom FMIC w/Garrett 900hp core, 3" charge piping
Exhaust
Gruppe-S UEL Header
2.5" Uppipe
3" Catless Downpipe
QTP E-Cutout
Borla Hush Catback
Header, Uppipe, Downpipe heat-wrapped
Cooling
Koyo Radiator
Samco hoses - black
Crucial 160d thermostat
Drivetrain
OEM Flywheel
ACT Xtreme 6-puck w/sprung hub
Cusco Motor/Tranny Mounts
Group-N Pitch Stop
Kartboy SS + Kartboy/TiC Shifter Bushings
Kartboy/TiC Tranny/Rear Diff Bushings
Whiteline subframe lock bolts
Beatrush lightweight front subframe
DSS Aluminum Driveshaft
DSS Rear Axle Bars
Braided Stainless clutch line
Brakes/Wheels/Tires
Hawk HPS Pads
Goodridge SS Brake Lines
OEM Gold BBS 17 x 8" + Kumho Ecsta MX 245/40R17
Electronics
Cobb v1 AP/ST
TXS UTEC with Speed Density, TXS 4.5BAR MAP
Defi Link BF Gauges - Fuel Press, Oil Press, Oil Temp
Apexi AVC-R Boost Controller
Greddy EGT Gauge
TXS Knocklite
Valentine-1 with remote display
The car drives great, and pulls harder than it ever did before. Driving home, just past the toll booths for the mass pike I did a 1st thru 4th pull and burned the tires in 1st, 2nd, and 3rd. I'm not sure what happened in 4th but it was time to shift right away.
jays05 is offline   Reply With Quote
Old 10-24-2008, 08:13 PM   #2
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
damn sick numbers bro!
What raw block do you have, track series? or signature series? And does the e-cut out make that much of a difference?
and do you think the dw1100's will be enough on c16? I know they are discontinuing them so hurry up, I think I got one of the last few sets left. Apparently they're stopping everything between 850-1600
D Money is offline   Reply With Quote
Old 10-24-2008, 08:16 PM   #3
RumblingDice138
Member#: 182853
2011 WRX
jez dawg that is some sick numbers, wish i had the cash flow for those mods
RumblingDice138 is offline   Reply With Quote
Old 10-24-2008, 08:20 PM   #4
jays05
Member#: 78165
05 STI 35r + e85
I have the DW1100s and all the top feed stuff sitting right here, so no worries about them being discontinued. I only wanted to run pump gas for now, and cash is starting to run low so I just got the car tuned as-is.
This motor was built by a local shop Synapse, and then Ron rebuilt it after a head gasket failure. So it is not a track series, signature series, etc.
Well we saw 15whp right off the bat with the cutout open and there was another pull that hit boost cut which would have been close to 520. The car has a Borla Hush catback so the cutout really relieves a lot of backpressure.
Old 10-24-2008, 09:18 PM   #5
jays05
Member#: 78165
05 STI 35r + e85
Dyno video... the last clip with the cutout open, I think that was the run that hit boost cut.
http://www.youtube.com/watch?v=IIRn062QSFI
Old 10-24-2008, 09:23 PM   #6
Blacksails192
Member#: 142686
back to european
killer power and a really clean car!... are you in the albany area? im in upstate ny and some of my friends talk about your car...
Blacksails192 is offline   Reply With Quote
Old 10-24-2008, 09:27 PM   #7
jays05
Member#: 78165
05 STI 35r + e85
^ Yes. I drove a good 6hrs roundtrip today to get tuned.
Old 10-24-2008, 09:34 PM   #8
Blacksails192
Member#: 142686
back to european
yes well those numbers are worth it! im from lake placid btw...
Old 10-24-2008, 09:34 PM   #9
kh15
Member#: 132400
does the shop have a website?
kh15 is offline   Reply With Quote
Old 10-24-2008, 09:37 PM   #10
Blacksails192
Member#: 142686
back to european
Old 10-24-2008, 09:38 PM   #11
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
nice going
jeremywrx15554 is offline   Reply With Quote
Old 10-24-2008, 09:42 PM   #12
wuuusaa
Member#: 92894
2015 Wrx
Congrats bro... about time
Old 10-24-2008, 09:48 PM   #13
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Impressive power on pump gas! Congrats! I can't imagine what it must be like to spin all 4 in the lower gears!
Nice torque curve too... or should I say table...?
jigga is offline   Reply With Quote
Old 10-24-2008, 10:32 PM   #14
jays05
Member#: 78165
05 STI 35r + e85
Here is a quickie on the street, spinning like a Honda! I really think I'm gonna break the tranny.
Junior is the man.
http://www.youtube.com/watch?v=7xJMf2z0YpI
Old 10-24-2008, 10:35 PM   #15
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
Junior is the man.
Oh damn...
You drive that baby like that on Sunday, and we are going to have some sick numbers to back up the dyno charts..
Man, I love it when I get a car that makes power and the owner can drive it like it should be..
Glad you like her Jay!
junior
Junior2JZ is offline   Reply With Quote
Old 10-24-2008, 10:48 PM   #16
benw
Member#: 103320
2005 wingless
aspen white
Jay, why didn't you tune it yourself? The results look great, but I know you're big on tuning these cars and wondered why you farmed this particular job out to someone else. No offense meant just curious.
benw is offline   Reply With Quote
Old 10-24-2008, 10:50 PM   #17
jays05
Member#: 78165
05 STI 35r + e85
Well my stock motor blew up and my built motor blew up twice lol. So I changed the engine builder and the tuner.
Old 10-24-2008, 10:55 PM   #18
Blacksails192
Member#: 142686
back to european
who did your prior motors?
Old 10-24-2008, 11:06 PM   #19
jays05
Member#: 78165
05 STI 35r + e85
Synapse, the same shop I still deal with for everything else. We don't know why that motor broke a cosworth cam in half or blew a head gasket. Some clues point to the motor build, some to the tune. I'd rather not get into it here.
Old 10-24-2008, 11:12 PM   #20
Blacksails192
Member#: 142686
back to european
true. anyways the cars a monster. that videos reciculous!
Old 10-24-2008, 11:29 PM   #21
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
I wouldn't blame your tune... Like I told you today your work on the ROM file was great, that and your attention to detail.. well I doubt it was anything you did.
Old 10-24-2008, 11:33 PM   #22
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
i've seen sets of cosworth cams break like you describe. On a recent car I was working on, it was the intake cam for 2 and 4 cylinder broke in half, right in the middle...between the machined and unfinished part of the cam.
Not sure what cosworth is doing but, its definitely not good quality control on these breaking cams
Benchmark Tuning is offline   Reply With Quote
Old 10-24-2008, 11:38 PM   #23
jays05
Member#: 78165
05 STI 35r + e85
Yup right over cyl #2
And then again right over cyl #2
Old 10-25-2008, 12:41 AM   #24
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
We have a car that did the same thing - odd
alfriedesq is offline   Reply With Quote
Old 10-25-2008, 02:07 AM   #25
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
sick numbers
