Old 03-21-2002, 06:34 PM   #1
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Question Minnam kit temperature coated?
Anyone know if the Minnam kit up/down pipes had any type of temperature coating on them?
I need to move my cat and it will involve cutting and re-welding on the downpipe. If it is coated, it will cause problems with a TIG welder.
Thanks!
-Nathan
crash is offline   Reply With Quote
Old 03-21-2002, 07:30 PM   #2
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
Later Minnam kits came with coating pipes, but the earlier batches weren't.
MattC
MattC is offline   Reply With Quote
Old 03-21-2002, 11:13 PM   #3
Avenger
Member#: 1234
FYI, my kit was coated.
Avenger is offline   Reply With Quote
Old 03-22-2002, 05:08 AM   #4
Aphex
Member#: 146
'16 WRX Limited
you can weld on that pipe, we just hacked my intake pipe (jet hot coated) and welded another pipe to it to fit up to a Saab 900 intercooler. so it can be done, but you'll have to grind off the coating from around where you are going to weld.
Eli
Aphex is offline   Reply With Quote
Bad for temperature coating inside? vandysti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-03-2005 05:32 PM
need help want to put minnam kit in 2000 impreza coolguy Normally Aspirated with bolt-on Forced Induction Powertrain 3 07-30-2001 11:31 PM
part # for wastegate from minnam kit? sanders Normally Aspirated Powertrain 2 01-06-2001 05:31 PM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 10:51 AM
What's in the Minnam kit these days Graf Technical Forum Archive 2 07-30-2000 12:34 AM
