Old 10-25-2008, 01:50 PM   #1
jasv11
Member#: 117862
2006 STi [email protected]
96 impreza 9.55e.t.146mph
Default Oh ya!! TEN'S baby !!!!!
Went to the track last night despite the weather man calling for rain.
The outside temp was around 55 deg. with about 70 % humidity.
Made a 11.1 pass and coming back from the ticket booth I got stopped by the track manager and told I need to slow it down as I need a roll cage and a firesuite to got that fast. After begging and barganing with her I got her to agree that I could give it one more try and could she please spray the line as I need to get this pig into the tens.
I've run 11.26 2 weeks ago and they never said squat, with there only being 15 cars there last night with the quickest car being a 13 second runner I guess I drew to much attention.
I got to make one more single pass so I was really concentrating on the launch and wasnt too concerned for my reaction as you can see in the slip.
Just a side note because someone always points it out is that reaction time does not effect your time only comes into in play when you race another car.
I want to give out a big big big big big big thanks to Mike at Innovative tuning for his tuning and build advice throughout the developement of my car. All the crew at Innovative Justin, Joe, Mike Jr,. and John big ups to you guys for the help and mechanic skills on a couple of the jobs to big for me to handle myself.
run was made on c16 (car has gone 11.3at125mph on 93 and 50/50meth at 24.5lbs with street potenza's)
boost was peaking at 27 lbs and holding to 7500 rpm
slip
Video
2006 STi
weight with driver 3440 lbs
MODS
Innovative stage 2+ motor
unsleeved STi 2.5 block
stock crank
coated ACL Race bearings
08 STi oil pump
Eagle rods
Arias 9.5 to 1 pistons
stock STi heads
Supertech double valve springs
.5 mm bigger valves
No porting, Stock Cams
07 transmission swap
upgraded DSS axle bars
MT 3221 tires 26x7x17
UR GT35R kit
hks ignition box
ARP head studs
modded 140 amp alternator
turboxs dual stage boost controller
AEM Standalone
UR fuel rails and 1000cc injectors
Tial 50 mm BOV
Tial 44mm EWG
APS 725 FMIC
Perrin Headers Jethot coated and wrapped
Koyo rad
Walbro FP
Exedy triple plate clutch
jasv11 is offline   Reply With Quote
Old 10-25-2008, 02:37 PM   #2
fulie
Member#: 142345
2002 WRX 34'd
Hey man congrats on that. All the hard work has paid off and you finally have a 10 SECOND CAR! how sick does that sound.
fulie is offline   Reply With Quote
Old 10-25-2008, 02:56 PM   #3
bloopsta26
Member#: 131371
05 buy my parts so
i can get my sti running
sweet ride, gives me hope on my unsleeved motor. good job tho for sure
bloopsta26 is offline   Reply With Quote
Old 10-25-2008, 03:03 PM   #4
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Congrats Jason! You've been a model customer and friend. All the guys at the shop and I are very happy for you.
I was hoping you'd get more than two passes, only one of them with a real launch. We know you'd only get quicker with practice, lower tire pressure, and accepting potential axle failure and letting it rip. When the girl from the track reluctantly said they'd allow you a second pass, but that was it, I was definitely nervous. I know it's easy to botch a run once a car gets this quick. You did a great job making it happen! They definitely did not spray the track for you.
This ten second pass was a great accomplishment, but I'm happiest because you reached your goal for the car. You gave us what we needed to make it happen, put in a lot of effort on your own, and now you're there. For those who may not know specifically, the goal we were given was that the car could run 11.5's consistently because he didn't want to cage the car or strip the interior etc. We had talked about trying to do it with/without various things like race gas etc. After taking it to the track we found he goes 11.3-11.4 just the way he drives it every day without changing ANYTHING to go racing. No race gas, no drag radials or race tires, no removing weight, no dropping the exhaust, no changing the tune or raising/lowering the boost. No changes necessary at all. To me that's just as cool as knowing the car can run a 10 when he wants to spend a few minutes adjusting things and doesn't mind getting thrown out.
We don't really know if he's the only one who has done this, but we haven't noticed anyone locally or online who has run a 10 second pass in an STi without head porting or upgraded cams, neither of which Jason has, so I'm happy about that too. His power falls after 5500 rpm, same as my car did since I was unported with stock cams. I've tuned STi engines just with porting, just with upgraded cams, and with both and holy cow what a difference those things make on these cars.
I think it's also significant to add that his suspension is basically stock. He has lowering springs. After he gets coilovers traction should be improved, and they're also lighter, allowing for better times.
For the record, we never intended this car to go this fast since this wasn't the goal we were given. For that reason the engine was not sleeved. These passes at 26.5-27 psi are something Jason knows we don't recommend because bore distortion can occur at this power level. If he wants to continue running this power level rather than the one that was intended, he'll have to sleeve it.
There she is:
Innovative Tuning is offline   Reply With Quote
Old 10-25-2008, 03:08 PM   #5
lev98
Member#: 140529
01 Ferrari 360 spy
Congrats man. So did the track ban you for no roll cage?
lev98 is offline   Reply With Quote
Old 10-25-2008, 03:33 PM   #6
jasv11
Member#: 117862
I can go back but I have to just stay slower than 11.49 and I'm good.
Old 10-25-2008, 03:50 PM   #7
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
congrats man This gives me hope for my 10 second pass
spoolinsti05 is offline   Reply With Quote
Old 10-25-2008, 03:56 PM   #8
brumby
Member#: 162631
03 subaru wrx
Nice job!
brumby is offline   Reply With Quote
Old 10-25-2008, 05:04 PM   #9
Got Grip
Member#: 177269
10 WRX
I think thats awsome jason great job. Glad you could accomplish your goals.
Got Grip is offline   Reply With Quote
Old 10-25-2008, 05:21 PM   #10
elazulWRX
Member#: 166110
2003 Evo VIII
Apex Silver
Congrats. Its hard and pricey to build a 10 sec Subaru.
elazulWRX is offline   Reply With Quote
Old 10-25-2008, 05:24 PM   #11
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Congrats man - nice car and nice run - welcome to the 10 second club
Us Subarus are starting to make ground on the Evos slowly but surely
alfriedesq is offline   Reply With Quote
Old 10-25-2008, 05:32 PM   #12
Schnitz
Member#: 119499
2006 STI
Congrats! It's been a long road and you deserve some accolades for sticking with it this long.
Schnitz is offline   Reply With Quote
Old 10-25-2008, 06:33 PM   #13
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Wow...that 60' is wicked.
Congrats indeed.
zeropsi is offline   Reply With Quote
Old 10-25-2008, 06:57 PM   #14
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Congrats! Innovative strikes again
That car too.. so clean...
I do have a question though... What purpose does the modified 140amp alternator serve?
jigga is offline   Reply With Quote
Old 10-25-2008, 07:15 PM   #15
jasv11
Member#: 117862
Thanks everybody
Isnt more always better, actually my stock one was toast and it wasn't that expensive for that one so i figured what the hell.
A few of the road coarse guys around Toronto do it to their race cars and way back in the day (early 80's)when I raced roundy round we would always try a find a alternator from a large luxury car that would fit in the race car. Its just what we did.
Old 10-25-2008, 10:59 PM   #16
garboplateNY88
Member#: 134113
05 LEGACYGT
247hp 300tq retuned STM
Post
Are you going to put the video on youtube?
garboplateNY88 is offline   Reply With Quote
Old 10-26-2008, 12:22 PM   #17
CatfaceType-R
Member#: 81102
congrats man
CatfaceType-R is offline   Reply With Quote
Old 10-26-2008, 12:43 PM   #18
jbpsti
Member#: 192057
04 WRX STI
JBP
Wow nice run!
jbpsti is offline   Reply With Quote
Old 10-26-2008, 01:01 PM   #19
Speed
Member#: 67371
05 BUILT 2.4L STI
Nice!
I like your tires. They're pruven!
Speed is offline   Reply With Quote
Old 10-26-2008, 01:03 PM   #20
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
awesome run bro
D Money is offline   Reply With Quote
Old 10-26-2008, 09:03 PM   #21
06wrxlbart
Member#: 154013
2012 S4
Monsoon Grey
Nice pass, good looking car also. Good luck.
06wrxlbart is offline   Reply With Quote
Old 10-26-2008, 09:47 PM   #22
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
lmao, now running 10's without a roll cage be prepared to get banned from the track! That's my dream one day.
tux121 is offline   Reply With Quote
Old 10-26-2008, 09:48 PM   #23
jasv11
Member#: 117862
now on youtube
http://www.youtube.com/watch?v=xlz5wNHYkWI
Old 10-26-2008, 09:55 PM   #24
moreboost
Member#: 124212
06 STI
Built By Inn-Tune
Nice number, Glad to see someone from Ontario hitting good #'s!! I will have my chance next summer when I get things sorted.
Your ride kinda looks like mine!
moreboost is offline   Reply With Quote
Old 10-26-2008, 09:59 PM   #25
MattD87
Member#: 126930
2015 Legacy
CGM
Fast and it looks good, nice job!
MattD87 is offline   Reply With Quote
Tial Gt3076r Oh Ya! kmurphy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 156 01-05-2009 05:28 PM
Oh Ya thats the stuff Flexx999 Canada Region Forum 5 04-19-2006 01:26 PM
Oh Ya just got a steel gray 2 and 10 General Community 27 03-11-2006 04:46 PM
Oh ya, I`m a specialist. gossamer_monster New England Impreza Club Forum -- NESIC 10 05-20-2001 06:00 PM
