Old 10-25-2008, 01:24 PM   #1
yurg
Member#: 188726
Default 04' Fxt to 02' Wrx drivetrain swap help
I have a wrecked 04 fxt and an 02' wrx that had an engine fire. I'm going to try to put the full wiring harness and engine and transmission into the wrx. I had a few questions on the transmission side of the swap. The fxt is a 4eat and the wrx is a 5sp. I figure I need to swap the rear diff to match the 4eat from the fxt. Do I need the driveshaft, axles, spindles etc. from the fxt or are some parts compatible.
yurg is offline   Reply With Quote
Old 10-26-2008, 12:12 AM   #2
sense of nature
Member#: 112759
02 Srp STi...
R ur Boltz to long????
if ur leaving the 5spd alone then no need to swap , axles are different, driveshaft is shorter rear diff is geared different just swap harnesses & leave drive train alone imo
sense of nature is offline   Reply With Quote
Old 10-27-2008, 10:51 PM   #3
yurg
Member#: 188726
I putting the automatic in there, I had no way to test the 5sp and the cluctch was toast and flywheel will need to be resurfaced. I know the auto is good so I'll start there and get it up and running with the stock fxt ecu which is also matched to the auto. So I'm going to need to swap the axles, drive shaft, and diff if I understand correctly.
02' wrx 5speed swap 55k 80% comp yurg Drivetrain 21 05-14-2009 07:11 PM
FS Nova: Full 02 WRX Drivetrain swap, WRX wheels, RS Headers and HFC DiscoGsus MAIC Private Classifieds 13 03-09-2009 02:18 PM
GU: FEELER '07 WRX drivetrain swap for MFactory 5-speed or STi 6spd swap or cash jmun671 Engine/Power/Exhaust 5 07-28-2008 05:26 PM
02' WRX wing swap Reddstars Texas Impreza Club Forum -- TXIC 2 12-25-2004 12:32 AM
Wrx drivetrain swap in to 96 legacy serious Subaru Conversions 0 05-04-2003 05:04 PM
Message Board Statistics All times are GMT -4. The time now is 09:50 PM.
