Old 10-25-2008, 11:31 PM   #1
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Default Boost dropping/hesitation odd problem please help
Ok so THIS is where the car sits currently,... It runs very well as you can see. The problem is this... When we turned up the boost at the last tune to 21 it developed what I would desribe as boost stutter. It only does this under MAX load in 5th gear. When you hear the noise (which sounds like blaster fire from Star Wars) the boost drops aprox 1 to 2 psi and recovers quickly. As long as you stay in it at WOT you will get the Jitter/hesitation aprox every 2 seconds over and over again.
During the tune I had some electrical voltage issues and we thought it may be spark blowout due to weak spark. These issues have been fixed (Bad Neg. Batt. cable). I also thought the stock bpv was not holding boost and dumping so I replaced it with an APS to no avail.
I need to get this resolved so I can utilize my Meth kit or get a race gas tune(read Turn up the boost). Thanks in advance
jmlaser is offline   Reply With Quote
Old 10-26-2008, 12:07 AM   #2
Venividivichi
Member#: 176793
2009 pontiac G8
black
what boost control system do u have?
Venividivichi is offline   Reply With Quote
Old 10-26-2008, 11:46 AM   #3
jmlaser
Member#: 125529
02 WRX 18G EJ205
Perrin style EBCS
I may try to get a log done today,.... I am certain the tune is fine or Jorge would have thrown frowns all over when it was on the dyno
Old 10-26-2008, 12:02 PM   #4
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
To be perfectly honest, it sounds like some sort of fuel cut... check your logs, your boost limit tables, and your boost control disable tables... And LOG!!!
gto7419 is offline   Reply With Quote
'03 Legacy w/ Odd Audio Problem - Please Help ejcookso Car Audio, Video & Security 1 10-07-2009 10:03 AM
05 WRX hesitation problem, please help. Sir Wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-28-2008 02:25 PM
Boost gauge install problem please help dolinga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-28-2001 10:24 PM
Hesitation problems......please help! Italiano Technical Forum Archive 6 08-22-2000 09:00 AM
Low RPM hesitation problems.. please help! (cont. ) Orbiter Technical Forum Archive 0 08-18-2000 03:47 AM
