Old 03-21-2002, 06:30 PM   #1
tymax
Member#: 13712
Default Installed Cobb CAI, rpm drop when shifting?
I just put in the Cobb intake last night in '00 2.5RS, everything went smoothly, just had a question here...when you guys mention low end power loss with a intake, is this what it means? It only happens when shifting from 2nd to 3rd, but when I shift to 3rd gear my RPM's will always drop down, right after the gear changes, and then I'll begin to re-accelerate as they climb back up with more gas...is this normal? Before the intake, I could shift up and the RPM's wouldnt drop at all (well not even as close to as noticeably as this) ..so I'm just wondering, thanks
tymax is offline   Reply With Quote
Old 03-22-2002, 01:38 AM   #2
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
What everyone means by low end loss is tourque down low is lost. You should not experience much or any low end loss with the Cobb. As for the RPM drop... I thought that happened anyway unless you had a million pound flywheel. Maybe I am misunderstanding what you are trying to say. But RPM's should drop between shifts.
Dolphin Overton is offline   Reply With Quote
Old 03-22-2002, 02:05 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
dolphin i must be mis understanding as well...that or there's a loose nut behind the wheel *shrug*
Old 03-22-2002, 02:43 AM   #4
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
my car does this too. when ever i change gears, the revs drop. and when i downshift, the revs go up (and if i go from 5th to 2nd they go up to 8k). i always thought this was normal.
KillerTHC is offline   Reply With Quote
Old 03-22-2002, 03:11 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Thats what gears do!
If the RPMs didnt go down, your engine wouldnt be able to accelerate anymore cause it would just hit redline and stop
Old 03-22-2002, 03:09 PM   #6
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
Do you mean they drop after you let out the clutch or while you are shifting?
JC
JC is offline   Reply With Quote
RPMs don't drop when shifting? JJ's Red Wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 03-19-2008 11:32 AM
large rpm drop when shifting uphill hybrid gti 2 Normally Aspirated Powertrain 7 11-11-2005 06:12 PM
RPM drops when WOT near 5000rpm viodea Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 08-26-2003 03:03 PM
RPMs spike when shifting? quynce Newbies & FAQs 15 06-21-2002 05:42 PM
RPMs drop when thottle is pressed imprez25 Normally Aspirated Powertrain 5 04-04-2002 08:27 PM
