Old 10-26-2008, 12:41 PM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default Remove EGT Probe from Iron Manifold when Hot/Cold?
I need to replace my autometer EGT probe. It is screwed in to a tapped hole in my cast-iron exhaust manifold. Would I be better off doing this removal when the manifold was hot or cold or does it matter at all?
whtlegacy is offline   Reply With Quote
Old 10-26-2008, 01:49 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the probe???
cold is fine
the probe should be installed in a bung that is installed in the manifold
the probe shouldn't be installed directly into the manifold
Old 10-26-2008, 03:19 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
if the manifold is WARM (not sizzling your skin hot) it will make it a little easier to remove, just don't reinstall warm. But as scotty mentioned, the manifold shouldn't make any difference. It should be installed in a brass bung, with a compression locknut holding the actual probe in.
Old 10-26-2008, 07:39 PM   #4
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Thanks for the help - it came out quite easily. The probe is installed in a bung that came with the probe. This bung was screwed into a hole threaded by a machinist. I am always scared to unscrew the bung with the probe...
Old 10-27-2008, 12:13 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
if it was installed properly, there is little chance of the bung coming out
remove egt probe w/o removing uppipe? krayjeegsr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-27-2007 10:21 AM
Help Needed: Remove EGT probe but not Up Pipe ??? Sausage Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-01-2006 01:42 PM
EGT probe in stock manifold. bcblues Engine Management & Tuning 8 03-21-2006 01:56 AM
Will flex up-pipe help to stop EGT probe from loosing? msun2000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 02-13-2004 05:15 PM
For those of you that removed passenger manifolds for EGT probe install... BeavisNuke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-09-2002 03:30 PM
