Old 10-26-2008, 02:20 PM   #1
the_virus
Member#: 104153
2011 ForesterXT
Exclamation Need Help Please!!
I have an 03 wrx with a 04ecu. I have to do my emissions by the end of Oct. and I am getting a CEL P1491, something to do with the PCV connector but the 03 does not have this sensor so does anyone know how to fix this problem?
the_virus is offline   Reply With Quote
Old 10-26-2008, 02:42 PM   #2
bfreeskier
Member#: 104808
1998 RSTi
Wasthe 04 ECU from a auto or manual trans? I know autos have a PVC value vs the manual don't. I'm not sure there is away around it, if it is hard wired into the ECU. That's just my guess though.
bfreeskier is offline   Reply With Quote
Old 10-26-2008, 03:33 PM   #3
the_virus
Member#: 104153
2011 ForesterXT
both ECU's are manual trans.
Old 10-26-2008, 03:34 PM   #4
the_virus
Member#: 104153
2011 ForesterXT
sorry both cars are manual
Old 10-27-2008, 11:38 AM   #5
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
Looks like the computer needed to be connected to the PVC diagnostic connector in order to keep that code from appearing. It may be easiest to swap back your 03 computer if you still have it or you will need to do some wiring.
Pin 2 on the 24 pin ECU plug go to Pin 2 on the PCV Diag connector, pin 1 on the PCV Diag Conn goes to ground. I do not know if you can fool the ecu by using a resistor or it needs variable voltage to simulate operation.
bobjr94 is offline   Reply With Quote
NNJ: Need to use a lift or need help! PLEASE! CoBB_tHiS! Tri-State Area Forum 6 05-05-2010 05:46 PM
i need help.. PLEASE HELP. WRXdriver04 Engine Management & Tuning 6 12-14-2005 09:17 AM
need help, please help!!! ralyrcr Mid West Subaru Owners Club Forum -- MWSOC 11 08-30-2005 08:39 PM
I need to order a clutch ASAP - Need help please Rizzo314 Transmission (AT/MT) & Driveline 3 11-05-2004 07:10 AM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
