Old 03-24-2002, 11:36 PM   #26
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Originally posted by Zahnster
I was going back and reading an earlier thread and someone suggested using the sheilds from the H-6. Anyone have any thoughts on this? (I guess you'd have to weld these ones on too....ugh)
this is the quesiton that i wanted to ask...i am going to be doing the WRX/Legacy GT front brake conversion to my RS to increase the swept distance and was also hearing rumors about the legacy GT rear Brake swap to increase swept distance as an option. Does anyone know if the shields are avialable seperately or just with the knuckle?? it's kinda strange they are tack welded...i would have expected hold down screws. Well anyhow i am gonna use up my stock brakes before i worry about this. Keep the info coming guys. Good job on the install, looks KILLER!!!
Jeremy
Old 03-25-2002, 10:11 AM   #27
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
I or one or the PR guys might have been where he got the Idea as we have been doing this mod to the Imprezas ever since the '00 Outback came out. Mind you that the regular 2000 (New style) Outbacks all have that rear breaks, not just the H-6.
This is a worthwhile mod as you will notice that the car breaks mor level instead of "nosediving" when you slam on the breakes.
I have been talking to Power Slot and they are almost ready to release (if they haven't already) this rotor.
Im waiting for it to order the full slotted set.
Good luck guys.
Leo
Leonardo is offline   Reply With Quote
Old 03-25-2002, 10:57 AM   #28
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Originally posted by JamesC
$200/each rotor for the turbo legacy kit seems a bit high in comparison to many oem sized aftermarket fronts
The rotors for the legacy swap are only $72 each if you pay MSRP . Keep in mind the Legacy Swap is more expensive because you are also changing to a
A) vented rotor
B) larger calipers with larger pads and a larger pot
The legacy setup costs more because you need the calipers as well . The rotor size on the legacy swap is marginally (1mm) larger than the stock rear rotor, but the pad is much much larger. I'm going to have to do some calculations as to how much bigger next time I have the rear apart. You not only increase effective swept area but you also increase the force applied to the brakepad due to the larger pots. Until we have concrete numbers from both setups, it's anyone's guess as to which one is better in the long run. I'll keep my vented legacy rotors and my brake shields either way though .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.subaruwrxparts.com
Old 03-25-2002, 11:27 AM   #29
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
The rotors are $50 a piece at Subaru parts. The brackets unfortunately are also about $50 a piece.
Zahnster is offline   Reply With Quote
Old 03-25-2002, 02:52 PM   #30
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Taking this concept to an extreme is a kit that uses 318mm rear discs with the stock caliper that will supposedly fit under 16" wheels (unknown if that means stock or 16x7 RS rims, or only 'select' 16" rims)
I saw it initially at Graham Goode
http://www.grahamgoode.com/cgi-bin/p...page=tarox.htm
avsport.net is also selling the kit, but I have not received a response from them about the price yet, but if it's 472 Pounds at GGR, I'm not hopeful that it would be under $600.
But still, 318mm discs in the rear would sure look better, but it looks more like the Outback rotors will win out (for 1/3 the cost)
Concillian is offline   Reply With Quote
Old 03-25-2002, 04:34 PM   #31
mpaone
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Lightbulb Agreed Brian.
Brian,
I agree with you on the Legacy Turbo rears. Pad and pot are a good deal larger than stock.
These rear brakes were used by Prodrive in the early Legacy rally cars and in the verI to III (I believe) WRX overseas.
I also don't agree with anyone that states that it's great to upgrade your front brakes and not your rears. Not saying you should get vented discs, but some sort of upgrade is needed.
I spoke with a 12 year SOA veteran this pass weekend at our meet and he got into a long discussion on brake valve proportioning, master cylinder size and brake pressures (most of which lost me completely!). The concensus was don't upgrade your fronts unless you upgrade your rears... it wont stop the car any faster, but it will create much better straight line stability and increase the brake system longevity.
That is all.
-Mike.
mpaone is offline   Reply With Quote
Old 03-25-2002, 07:47 PM   #32
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Mike, I can confirm that the Ver I - III STi rear brake rotors are the same size and the caliper is the same. The two pot rear conversions for the I-III were caliper and bracket conversions, keeping the same rotor . So, if someone wants to read between the lines....
you *can* have two pot rears without hub or bracket modifications on an RS .
Brian
Old 03-26-2002, 01:19 PM   #33
tselway
Member#: 7490
2014 2.0i 5dr 5MT
Deep Sea Blue Pearl
don't believe that this question has been answered:
"So, what is the risk of having no brake shield? Will this affect brake cooling or does it just protect from roadkill?
Can you buy the Legacy brake shield and install it? "
Thanks
TonyS
tselway is offline   Reply With Quote
Old 03-26-2002, 02:47 PM   #34
RDJ
Member#: 13435
Asprin White
Default 1 H-6 Upgrade for sale
Ok so I jumped on this mod and bought the rotors/brackets. Now I've deciced not to install. Parts take about 1.5 weeks for delivery from subaruparts.com but I have them NOW. Purchase my new-in-box rotors/brackets for 200.00 shipped. PM me if interested.
-RJ
RDJ is offline   Reply With Quote
Old 03-26-2002, 03:36 PM   #35
Yebisu69
Member#: 11989
2006 LegacyGT LTD
Brilliant Metallic Silver
Default Re: 1 H-6 Upgrade for sale
-RJ
I bit. Emailed you.
Yebisu69 is offline   Reply With Quote
Old 04-12-2002, 02:37 PM   #36
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
anybody know what parts I will need to do this on a GC8? Same thing isn't it? Same part numbers? Rotors and brackets, right?
FatCatTurbo is offline   Reply With Quote
Old 04-12-2002, 03:41 PM   #37
DoorKnob
Member#: 395
2000 Impreza 2.5RS
Blue Ridge Pearl
Anyone know how the increased rear brake bias is going to affect handling? Since more rear bias is supposed to increase oversteer, there's got to be some difference right.
I've been considering this one ever since I did a WRX front swap.
DoorKnob is offline   Reply With Quote
Old 04-13-2002, 12:08 PM   #38
deadbolt
Member#: 990
96 Brighton and...
many
One more question, you said you had to take off the rear shield and that it was spot welded, did you replace it or just leave it off?
Thanks!
deadbolt is offline   Reply With Quote
Old 04-13-2002, 12:41 PM   #39
hunter001
Member#: 12153
4EAT WRX Wagon Silvr
Acura 3.2TL w/Navigation
What if, after the rotor upgrade, we put new 4-pots on the front and shift the current 2-pots in the front to the rear ? Is this possible ?
Later...AH
hunter001 is offline   Reply With Quote
Old 04-13-2002, 01:13 PM   #40
Austin
Member#: 7089
2016 STi
Thanks!
I pounded the edges back. With the stock 10.3" rotor, it curls around the edges. With it pushed/pounded back with the 11.4" rotor, it is flush with the outside rim of the rotor.
Austin is offline   Reply With Quote
Old 04-14-2002, 06:28 PM   #41
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
News from the battlefield... Bill Harvey and I attempted the H6 rear brake conversion on his MY98RS. It will not work! The MY98 caliper has one bolting pin and one sliding pin whereas the MY99-02 Imprezas have two bolts holding the caliper to the bracket. If any MY98 Impreza or Forester owners (possibly even Legacy GT, not sure) want to do this mod, you need new (or used) calipers as well as the bracket (which is the same bracket as used on the WRX front brakes by the way ) and rotors. Picture below:
This pin bolts in on the MY98 bracket and just goes into the housing of the MY98 caliper and stays there, no bolts/nuts. The MY99-02 has the pins go through the bracket and bolt into the calipers. There is no provision on the H6 caliper bracket to bolt this pin into (ie: no threads). You could "arrange" something I suppose, but it's not a straight swap from MY98 => H6 whereas it is from MY99-02 => H6.
Brian
Old 10-21-2002, 04:06 PM   #42
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Bringing this back from the dead...
Does anybody have any real world experience to answer DoorKnob's question?
I'm working on getting the parts to convert my L wagon up to h6 braking status. However, I'm a little leery of this due to the fact that this brake configuration was designed for the Legacy chassis, not the Impreza chassis. I'm also worried about the bias due to some mention that my brake proportion is already different since my car started out from the factory with drums instead of discs.
-Jon
www.nothingserious.net
FS - MD: - H6 / DBA rear brake upgrade & 04 WRX rear brakes MD04WRX Suspension/Brakes/Handling 10 03-20-2009 03:46 PM
WRX rear brake upgrade anyone? Prog Brakes, Steering & Suspension 27 02-04-2002 11:14 PM
rear brake upgrade? V6 Brakes, Steering & Suspension 10 02-02-2002 05:28 PM
rear brake upgrade question? spike Brakes, Steering & Suspension 0 01-11-2002 03:04 AM
rear brake upgrade 5doorman Brakes, Steering & Suspension 0 07-17-2001 12:10 AM
