Old 10-26-2008, 09:48 PM   #1
Snobaru
Member#: 177697
2005 Saab 9-2x Aero
Desert Silver Metallic
Default Stock 05 WRX - Hesitation around 3K RPM at WOT
Hello Everyone,
I am newbie to NASIOC and the forum, just got my first 2005 SAAB 9-2x Aero (WRX Wagon). It's a 2005 with 27,000miles. Everything is bone stock and the car is well maintained with all dealer service records.
My background is with the VW/Audi 1.8t drivetrains for many years.
Here is my issue..
It seems that on a couple of occasions, that I had this weird hesitation around 3,000 - 3,750rpms, almost wide open throttle, as if the ignition or boost cut out for a split second and then everything is good again. Typically in 2nd or 3rd gear. No engine lights.
At WOT, I can reach almost 1 bar of boost. I always run 93 octane.
In the VW/Audi world, I would chalk this up to a possible leaking bypass valve, but would have better direction as typically this scenerio would through an engine code for "desired boost not reached".
Is this a common issue with this motor (EJ205)? Is there somewhere where I should look first in order to find and resolve my issue?
I really appreciate all of your help and experience!!;)
Snobaru is offline   Reply With Quote
Old 10-26-2008, 10:09 PM   #2
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
All stock I assume? If so I do believe this is a drop in the oe timing tables. My car had it until I learned to tune via open source. Timing on the stock rom is really weird, pretty jumpy.. If it was higher, say 4k or so I would say you are hitting a higher load value, which would drop the timing off a bit and could cause a bit of a slugish feeling for a split second...
Maybe I'm wrong?
JSarv is offline   Reply With Quote
Old 10-26-2008, 10:13 PM   #3
Snobaru
Member#: 177697
2005 Saab 9-2x Aero
Could be at around 4,000 rpm. All stock. I found something while searching around that pertains to "open/closed loop" situations for 04+ WRXs. Can this apply here?
Old 10-27-2008, 06:38 AM   #4
Spenk
Member#: 7164
---> Spoiler alert:
Everyone dies at the end.
It's just the crap factory tune. While the OL/CL issue isn't as bad as on the 2004 cars, it's still a tune that's more concerned with hitting tailpipe emission targets than making power.
Solution: find a used AP v1 (make sure it's for a 2005 5MT 2.0l) in the classifieds for $300, flash to Stage One and enjoy.
And by the way -- Saabarus are the shiz!
Spenk is offline   Reply With Quote
Old 10-27-2008, 09:02 AM   #5
Dutchman1101
Member#: 155735
2005 '05 LGT LTD
Satin White Pearl
While Stage 1 does kick the factory tunes ass, I'd take it in to get checked out. IMO getting stage one might be masking some bigger problem. It's probably nothing major but better to be safe then sorry.
Spenk-Are you a Panic fan by chance? I noticed you have a LG&M reference in your info.
Dutchman1101 is offline   Reply With Quote
Old 10-27-2008, 08:23 PM   #6
Snobaru
Member#: 177697
2005 Saab 9-2x Aero
Thanks everyone!
Just a personal opinion, would you take this car to SAAB because it is still under factory warrant and risk that they don't know the quirks of a Subaru or to a Subaru dealer, pay the labor because the car ultimatly is a Subaru?
Old 10-28-2008, 01:01 AM   #7
SlverEJ20
Member#: 157158
05 WRX stage 2
Try flashing to stage one and see if that helps. It was like night and day for me.
SlverEJ20 is offline   Reply With Quote
Old 10-28-2008, 02:23 AM   #8
Audiosavvy
Trust me, I'm a scientist
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Sounds to me like the factory tune, which is crap. Some timing and a better tune should smooth that out, unless you have some actual problems.
If your car is tuned and for some reason goes into limp mode, you will experience similar results for similar reasons.
Audiosavvy is offline   Reply With Quote
06 WRX Hesitation between 3000 RPM - 5000 RPM dao Newbies & FAQs 11 01-19-2012 11:56 AM
Can 3K make my Stock 05 WRX as fast as a STI? eshtog General Community 18 06-29-2004 09:47 AM
Car hesitates above 3K rpms SIMPFLY Factory 2.0L Turbo Powertrain 12 05-02-2004 08:20 PM
When does boost kick in? At RPM? At WOT? rharder Factory 2.0L Turbo Powertrain 3 07-25-2002 08:27 PM
Message Board Statistics All times are GMT -4. The time now is 03:16 AM.
