Old 10-26-2008, 11:12 PM   #1
bereda
Scooby Scammer- Do Not Buy From User
Member#: 192034
2004 2.5rs
red
Default camber...
how do i add or subtract sum camber on a 04
bereda is offline   Reply With Quote
Old 10-27-2008, 09:19 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
front or rear? the front has eccentric bolts stock
don't forget to re-adjust the toe though
beyond that you'll need additional camber bolts or camber plates
... and i suggest you search / check stickies in the suspension forum, that's where this belongs
UkNuck is offline   Reply With Quote
FS: TXS FMIC, BOV, WL sways, camber plates, stock parts, brake hoses, more benton0311 MAIC Private Classifieds 21 06-12-2010 07:54 PM
Tokico D-Specs + Camber bolts = less camber than stock struts without camber bolts?! formula91 Brakes, Steering & Suspension 10 09-07-2009 12:59 AM
Camber Dilemma: can't get enough front camber. Cosworth Brakes, Steering & Suspension 17 10-11-2002 10:28 PM
Can only get 0.5 negative camber with camber bolts? Tronner Brakes, Steering & Suspension 1 08-23-2002 08:56 PM
Is camber adjustment impossible without camber plates? edkwon Brakes, Steering & Suspension 3 07-23-2002 11:56 AM
