Old 10-27-2008, 12:32 AM   #1
toebotypera
Member#: 76418
04 wrx
java black pearl
Default is the o2 in the exhaust manifold really needed?
can we bypass the o2 sensor in the exhaust manifold or is it really needed?
toebotypera is offline   Reply With Quote
Old 10-27-2008, 06:34 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
100% needed - it is used by the ECU to control closed loop AFR. Don't mess with it.
UkNuck is offline   Reply With Quote
Old 10-27-2008, 10:41 PM   #3
toebotypera
Member#: 76418
04 wrx
java black pearl
can I replace with a wideband o2 sensor from http://www.tactrix.com/product_info....ab6aa1c14570dd ?
Old 10-28-2008, 08:56 AM   #4
rkramer
Member#: 118209
2015 WRX Limitec
no, and ideally you don't want to leave the lc1 in all the time either. install it in a downpipe bung, tune, and then remove it until you tune again.
Old 11-01-2008, 10:41 PM   #5
nelam
Member#: 93679
are you better off sticking with the oem O2 sensor in the exhaust manifold, or is there another one out there that has a better reputation?
nelam is offline   Reply With Quote
Old 11-02-2008, 07:15 AM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
aftermarket sensors tend not to work so well (throw CEL/codes)
OEM is best in this case.
Old 11-03-2008, 04:49 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
You can safely remove the rear 02 sensor if necessary. The LC-1 is still fairly accurate when installed after the cats.
I don't agree. The sensor used with the LC-1 is an OEM part used in many vehicles and is meant to be installed and used as the primary sensor.
2.5 o2 sensor the one in the manifold stage2?? Private 'Wanted' Classifieds 3 02-09-2009 11:16 PM
Exhaust leak? Really need help! jt0thevizzle Newbies & FAQs 15 06-13-2008 01:11 AM
Am I about to destroy the threads in my exhaust manifold? whtlegacy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-31-2006 03:24 PM
Is Subaru really redesigning the Impreza in the near future? wilddave1 News & Rumors 55 07-08-2004 02:58 PM
Is it easy to change the cams in the 2.5RS Impreza i need details thanks Imprezive2002 Normally Aspirated Powertrain 15 05-13-2003 07:15 PM
