Old 10-04-2011, 10:00 PM   #51
Donzo
Member#: 95337
2012 Jeep Overland
PM sent, sugartits!
Donzo is offline   Reply With Quote
Old 10-24-2011, 03:38 PM   #52
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Made a LOT of progress on the wagon over the past few weeks. The bodywork is all back on, although in multiple colors. The dash is in and I got it registered. This weekend I got it aligned and had the ecu flashed to get rid of CELs and put a conservative fuel map on it so I can drive it for a few weeks and work out any kinks. I'll post some pics soon.
Here's the next issue I need to deal with: I need a front mount intercooler. I don't know what kit to buy though. It's gonna have to be an eBay kit or a used name brand one because I can't affort to pay $1000 for anything. I want to preserve the bumper beam, maybe not the whole thing, but definitely something to keep some structural integrity in the front in case of an accident. Does anyone know of a kit that will work for me?
Soarer is offline   Reply With Quote
Old 10-24-2011, 04:49 PM   #53
tirkish
Member#: 171886
16 STi Limited
MurderShine
This should work:
tirkish is offline   Reply With Quote
Old 10-24-2011, 04:57 PM   #54
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Thanks. Very helpful. I'll mount it on the roof rack.
Old 10-24-2011, 06:31 PM   #55
celosteelo
Member#: 80062
06 STi
Yo muchacho, you've got to be able to find a used Perrin or Turbo XS on IWSti. I always see them up there.
celosteelo is offline   Reply With Quote
Old 12-01-2011, 06:33 PM   #56
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Had some bad luck. After getting the car back together and doing a shake-down run, it overheated. I thought it might be air in the cooling system so I bled it out and took another run. It overheated again. I did a compression test and found out that my head gasket was bad on the passenger side. So, I pulled the motor, broke it down and sent the heads to be pressure checked and milled. I put it back together with new gaskets all around and just dropped it back in the car last night. I still need to hook up a few odds and ends to get it running. I'm hoping to have it done this weekend. Then I can really start driving it! Fingers crossed......
Old 12-01-2011, 07:28 PM   #57
Donzo
Member#: 95337
2012 Jeep Overland
You sir are a beast. Carry on.
Old 12-01-2011, 09:45 PM   #58
RScoobyy
Member#: 236276
2006 OBP WRX Wagon
Sorry to hear that man, can't wait to see it working
RScoobyy is offline   Reply With Quote
Old 12-08-2011, 12:14 PM   #59
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Got the head gaskets done last week and she fired up and purred nicely. No more overheating problems! I've been driving the car FINALLY! I got the alignment done at Sears and had to bring it back for another adjustment. It still felt a bit jumpy so my buddy came by with his camber gauge and toe plates and we made some more adjustments last night. Now I'm happy with it. For now. I got the front toe to 1mm of toe out and .6 degrees of negative camber. The problem is now in the rear. I'm running 2.2 degrees of negative camber on one side and 1.9 degrees on the other. I'm going to pick up some rear camber adjustment bolts and see if I can dial this in to about .8 degrees.
My next jobs are:
roll fenders
get a front driver side fender liner
make a wiring harness for my turbo timer (came out of a wrx)
Get some floor mats
FMIC
Tune!!!
Install front sway bar
bodywork & paint
Old 12-08-2011, 12:42 PM   #60
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Why do you want such little negative camber? Admittedly, -2.2/-1.9 is probably a bit much in the rear, but dropping it all the way to -0.8 is unnecessary. And only having -0.6 up front is terrible - you want that to be up around -1.5 if you can get there.
Patrick Olsen is online now   Reply With Quote
Old 12-08-2011, 01:09 PM   #61
Donzo
Member#: 95337
2012 Jeep Overland
FYI I think the driver side an passenger side is typically slightly different to make up for the driver's weight while in the vehicle. I think my WRX was 1.9 left and 2.0 or 2.1 on the right.
Try going to Little Bear Wheel Alignment in Peekskill/Buchanan. They do performance alignments and all that jazz with the laser machines. They know they're stuff.
Old 12-08-2011, 01:14 PM   #62
tirkish
Member#: 171886
16 STi Limited
MurderShine
Wow! Great new Chazzie. Very excited to go for a ride (post tune)!
Old 12-08-2011, 02:23 PM   #63
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
I've had them do alignments on my SC400 and SC300. they are really good. I think I'll go to them once I get all my other issues sorted out. I'll tell them how I plan to use the car and let them work their magic. I totally trust those guys.
Old 12-08-2011, 02:25 PM   #64
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
OEM specs for the car are to have -0.5 at most in the front. This is a daily driver and I don't want to be burning up tires.
Old 12-08-2011, 05:06 PM   #65
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Hence my recommendation to go to -1.5 up front. I would say -1 to -1.2 in the rear would be good. You will not burn up the tires with -1.5 camber. You should be more concerned that toe is set correctly, as close to 0 as possible, front and rear, to promote tire longevity. (Note that I have a BD/BG Legacy, too, and I have the FSM, so I know what the factory specs are and know what works.)
Excellent work on the swap, particularly the persistence to get it done despite significant down time. I know from personal experience how hard it can be to get back into a major job after time off!
Old 12-19-2011, 12:42 AM   #66
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
I'm going to take the car to Little Bear Alignment in Buchanan, NY this week for a real alignment. Those guys are wizards. I'm gonna tell them the type of driving I do and what I want out of the car and I'm sure they'll dial it in just right.
Old 12-19-2011, 12:44 AM   #67
tirkish
Member#: 171886
16 STi Limited
MurderShine
How did she fair going to the city and back?
Old 12-19-2011, 12:47 AM   #68
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Got some more work done today. I rolled my fenders so now my STI wheels and Potenzas clear front and rear. I drove the car from my house in Danbury to GPNY in Mt. Kisco, NY for some karting. Man, what a nice drive it was down the Saw Mill! Even only running 9 lbs of boost this car is fast. The 4.11 gearing means that 70mph on the highway is 3500 rpm but hey, it sure gets there fast. I also put my Perrin front sway bar in today too. I'm using stock end links which must have a gazillion miles on them so I'm sure they're not doing the best job. I have a set of Perrin end links but lost a few of the hardware bits to bolt them in. I need to find that stuff so get them installed. I also need to find a good rear sway bar. I'm running the stock GT one and it's about the diameter of dental floss.
Next steps are to get an emissions test, performance alignment, mount my winter tires, get a front fender liner and find a good intercooler.
I'm just really psyched that the car is finally daily drivable!!!!
Old 12-19-2011, 12:48 AM   #69
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Besides some tire scraping, it was flawless!
Old 12-19-2011, 01:00 AM   #70
tirkish
Member#: 171886
16 STi Limited
MurderShine
Perrin Endlinks are garbage. Might as well use Erector Set parts.
...can't wait to take her for a drive! Wagon Power!
Old 12-19-2011, 01:45 AM   #71
Donzo
Member#: 95337
2012 Jeep Overland
Like I said, I have stock 06 WRX sways and end links you can have for free. I can drop them off any time after work.
Old 03-12-2012, 01:23 PM   #72
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
That would be sweet. I'll take em!!!
Old 03-12-2012, 01:25 PM   #73
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
I got my wheel bearing job done this weekend. It wasn't bad at all. I used my shop press to do most of the work. If I had a bearing separator, I could have done it all but I had to take it to EVB (Extreme Vehicle Builders) which is 1 mile from my house to have them push the inner bearing race off the spindle.
Then I installed some Deatsch Werks 650cc injectors. It's all coming together finally!!
Old 03-12-2012, 06:24 PM   #74
celosteelo
Member#: 80062
06 STi
Yeah mang! Get R done!
Old 03-25-2012, 10:52 PM   #75
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Tuning this week. So psyched! Finally I'll see this car's potential!
2005 WRX-98 Legacy GT wagon 5MT swap WIP iluvdrt Legacy Forum 33 07-10-2015 06:01 PM
08 WRX suspension into 05 Legacy GT wagon? 02rusWRX Brakes, Steering & Suspension 0 08-24-2008 05:37 PM
EJ251(?) into 98 Legacy GT bagelicious Normally Aspirated Powertrain 2 01-16-2008 02:01 AM
ej20g into 98 Legacy GT bagelicious Subaru Conversions 3 02-19-2007 12:29 AM
WRX: Into 98 Legacy GT Soobie22 Subaru Conversions 9 12-03-2004 01:13 PM
