Old 10-27-2008, 01:37 PM   #1
illini_wrx
Member#: 155844
Default bad idea to torque down lugs with cheater bar?
i don't own a torque wrench, so i've always just used a 2 foot long cheater bar. someone just warned me about over torquing the lugs because of how much force im imparting with the cheater bar (because it might strip the lugs?)
is that something i should worry about? right now im about to use the stock lugs to put the stock wheels back on if that makes a difference
illini_wrx is offline   Reply With Quote
Old 10-27-2008, 01:41 PM   #2
mla163
Member#: 104922
2013 BRZ. 94 Miata
I would worry about over torquing and breaking the studs. It would take some work , but it's possible. buy a cheap torque wrench, or just get used to the "feel" of the right torque for the lugs.
mla163 is offline   Reply With Quote
Old 10-27-2008, 02:09 PM   #3
fliz
Member#: 30342
You can get a lug-nut worthy torque wrench for $10 from Harbor Freight...really no excuse not to have one.
fliz is offline   Reply With Quote
Old 10-27-2008, 02:12 PM   #4
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Or use a smaller wrench. Our cars only call for ~65 ft/lbs, which would be very easy to exceed with a breaker bar.
Remember that the more you tighten a bolt, the less strength it has.
Tirerack sells a decent torque wrench for 30 bucks or so. Buy one and you won't have to worry about it.
sniper1rfa is offline   Reply With Quote
Old 10-27-2008, 02:16 PM   #5
rdodger
Member#: 156447
99 18g'd 2.5RS-T
It'll be very easy to strip with a 2ft bar unless you don't tighten them down much. Ive stripped some with a large 18in wrench before and generally just use an 8in wrench and go 90% as tight as I can go, or break out the torque wrench.
rdodger is offline   Reply With Quote
Old 10-27-2008, 02:33 PM   #6
the_professor
Member#: 192317
Yeah, buy a torque wrench. It's an investment that is way cheaper than spending hours on replacing studs. Best $ spent for any car enthusiast.
the_professor is offline   Reply With Quote
Old 10-28-2008, 10:52 AM   #7
2fas4u
Member#: 90691
2005 STI / 2009 STI
yeah if your using a 2 foot extension and just torquing the crap out of them that is not good
2fas4u is offline   Reply With Quote
Old 10-28-2008, 11:50 AM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
75ft-lbs is about right
you are likely using 150 or more
get a torque wrench
http://www.harborfreight.com/cpi/cta...itemnumber=239
oh yeah....your lugs are likely stretched all to hell and wont hold now at the correct torque....you are almost certainly going to have loosening issues until you replace all the studs
Bad idea to let my GF learn how to drive a stick in my suby? CoopsCustomz General Community 72 03-30-2010 07:58 PM
Bad idea to drive to shop on un-tuned parts? lennyTR Factory 2.5L Turbo Powertrain 17 10-28-2007 06:51 PM
How to Torque down the top bolt on a set of Tein Coilovers? Slowsoul Brakes, Steering & Suspension 6 01-23-2007 06:14 PM
XR250: How far to torque down clutch springs? CBoldman Off-Topic 1 05-01-2005 12:47 AM
why is it bad to use stock lugs with Rotas? thebing Tire & Wheel 2 10-01-2004 10:39 AM
Message Board Statistics All times are GMT -4. The time now is 08:13 AM.
