Old 10-27-2008, 07:07 PM   #1
HSBabyFace
Member#: 130204
14 JKUR
Default Tires 235/45's or 245/40's
I just got a set of 17x8 48 offset rota torques and I am debating between 235/45's and 245/40's. I want to know if anyone has had any rubbing issues with the 245 or if anyone has any recomendations. As far as suspension goes Ive got the Eibach Pro springs. Thanks
HSBabyFace is offline   Reply With Quote
Old 10-27-2008, 09:24 PM   #2
ChuiSTi
Member#: 61212
2005 STi
CGM
245/40's worked fine with me -2 camber on front (plates) -1 on back (bolts). lowered on cusco zero 2r coilovers
ChuiSTi is offline   Reply With Quote
Old 10-27-2008, 09:26 PM   #3
Zorin
Member#: 164106
2006 STi
F'ing Blue
I concur as well, mine work great with this size tire.
Zorin is offline   Reply With Quote
Old 10-28-2008, 02:42 AM   #4
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
I could be wrong but I think the rear fenders are rolled more from the factory on the 05+ sti then the wrx. ?
Someone please correct me if im wrong.
rexworx is online now   Reply With Quote
Old 10-28-2008, 05:15 PM   #5
Scooba Stimpy
Member#: 187721
XX Scoobyless
i have the exact same rims with 225/45 on sti springs. the rear struts clear by about 8mm
Scooba Stimpy is offline   Reply With Quote
Old 10-28-2008, 05:40 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
235/40 or 245/40
will not rub unless it is slammed
Old 10-28-2008, 06:09 PM   #7
wrxskier18
Member#: 88005
2002 WRX + NSX
Silver + Green
Yes, you are correct. You can see the rear fender flares on a 05-04 STi
If you have a sedan you should be fine. If you have a wagon, you'll rub.
wrxskier18 is offline   Reply With Quote
Old 10-28-2008, 07:05 PM   #8
HSBabyFace
Member#: 130204
14 JKUR
Thanks for the help. I've decided to go with the 245/40 Potenza RE760 sports. Looking to get them put on this weekend.
Old 10-28-2008, 10:14 PM   #9
Gonz
Member#: 18642
2005 Impreza WRX STi
I have 245/40 on 17x8 +48 wheesl (not Rotas) and it used to rub in the rear. I rolled the fenders with a pipe.
They won't rub "all the time" but when you corner hard, hit bumps, or load up the trunk, I bet it's going to rub. May depend a bit on the tire used. I have Hankook RS-2s.
Gonz is offline   Reply With Quote
Old 10-28-2008, 10:49 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
your car and the OP's car are NOT the same
the 06-07 wrx have more room in back and can run wider tires without rubbing
Old 10-29-2008, 09:02 AM   #11
bmak21
Member#: 165379
VTEC GOOOOOOOOOOOOOO
BWWWWAAAHHHHHHHHHHHHHHHH
also aren;t bugeyes fendors smaller?
bmak21 is offline   Reply With Quote
Old 10-29-2008, 06:26 PM   #12
HSBabyFace
Member#: 130204
14 JKUR
Thats what I thought too... Only thing Im really worried about is swallowing the wheel. One of the reasons I want a wider tire is to protect the wheel from parking in the city. Also to put a little more rubber to the ground I just want to make sure that the 245's aren't going to look odd.
Old 10-29-2008, 10:14 PM   #13
Gonz
Member#: 18642
Didn't know 06s were different than 02s. Guess it's the newb in me coming out
If you want to protect the rim from the curb, you can look for a tire with a rim protector bead too.
Old 01-20-2009, 09:48 PM   #14
midnighted
Member#: 131869
2002 BMW M3
Topaz Blue
Not to bump an old thread but I have 245/40 Sumitomo HTR Z III on 17x8 Boosts on my car. I have not experienced rubbing yet. Im dropped on Tanabe DF210s with Tokico Dspecs.
midnighted is offline   Reply With Quote
Old 01-20-2009, 10:12 PM   #15
grippy monkey
Member#: 131067
your "stance"
sucks
I like 40 series in both 235 and 245 on 17's. I noticed a slight increase in acceleration coming from 235/40/18 to 235/40/17.
grippy monkey is offline   Reply With Quote
Old 01-20-2009, 10:21 PM   #16
HSBabyFace
Member#: 130204
14 JKUR
^^^ Interesting about the increase in acceleration cause I notice a decrease when I stepped up from the stock 215 to a 235
I ended up with 235/45's but am now selling the whole set up Got a ticket and need the money to help pay. But im going to end up getting some 17x9's with 245/40's next hopefully this summer.
Old 01-20-2009, 11:45 PM   #17
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
For a 17x8 wheel I tend to recommend 225/45/17, 235/40/17, or 245/40/17 tires. It all depends on what you plan to do with the car, type of tires, etc..
It all depends on your overall rolling diameter.
When Grippy went from a 235/40/18 to a 235/40/17 his overall rolling diameter decreased by a full inch. The 235/40/17 being a shorter overall diameter will make the car quicker given the same gearing.
When you went from a stock 215/45/17 to a 235/45/17 you increased your overall rolling diameter by .7" which will make it so your wheel rotates less per mile, making acceleration slightly slower.
-Dan
suby_dude is offline   Reply With Quote
Old 01-21-2009, 10:02 AM   #18
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
according to this site http://www.rims-n-tires.com/rt_specs...0&text1=&text2
it will change only by 2.8%. So i don't know how you could feel such small the difference going from 215/45/17 to 235/45/17 tyres...
Tomas26 is offline   Reply With Quote
Old 01-21-2009, 10:46 PM   #19
HSBabyFace
Member#: 130204
14 JKUR
-Dan
Yeah I asked some people about that when I first put the wheels and tires on about my car feeling slower and I got a lot of people thinkin I was crazy. But the physics makes sense. I am going to end up getting a set of 17x9's and 245/40's
Old 02-24-2009, 01:46 PM   #20
jondl
Member#: 148591
2007 WRX Sedan
CGM
I'm thinking of picking up a set of Rota 17x8 +48 and would like to know the max I should go without rubbing. I'm on Dspec struts with jdm pinks with no fender rolling.
I'm thinking 235/45/17. Anyone?
jondl is offline   Reply With Quote
Old 02-24-2009, 05:22 PM   #21
subaru3169
Member#: 55252
* pullup bar *
i was rubbing in the back with 235/45.. fronts were fine
subaru3169 is offline   Reply With Quote
Old 02-24-2009, 08:49 PM   #22
nhat
Member#: 140163
03 STi
hellaflunctional
nope. no way. not with stock rear fenders. you'll probably rub with 235/40s too. 225/45 if you want to be safe, or roll your rear fenders and go with a 245/40.
Old 02-24-2009, 08:54 PM   #23
jondl
Member#: 148591
2007 WRX Sedan
CGM
Thanks for the quick responses guys. I guess I'll have to spend the extra cash for the 245/40/17. The RE01R deals got me.
235/45R17 or 245/45R17 focused_80 Tire & Wheel 14 05-03-2008 07:31 PM
2005 STI... 235/45 OR 245/40 (on 8" stock wheels) DSTI Tire & Wheel 24 12-25-2004 06:45 PM
235 or 245 17" tires SupraTT&WRX Texas Impreza Club Forum -- TXIC 2 06-25-2004 07:03 AM
Anyone running 235 or 245 width tires? rex n effect Brakes, Steering & Suspension 6 01-03-2003 02:18 AM
235 or 245 width tires on 7.5in rim... will it work? LttLDGN Brakes, Steering & Suspension 3 01-18-2002 12:17 PM
