Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 10-27-2008, 09:54 PM   #1
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Default 04 sti engine swap to 03 wrx?
IM tired of looking for info, can someone that knows what their doing please tell me what i need to swap an 04 engine to a 03 wrx. So far i was told i need a sti instrument cluster, but then I hear that 04 sti to 03 are plug and play. then i heard i need a engine harness and ecu, ok i get that. also i need the foot pedal and a adaptor. is it true about the adaptor or can i just mickey mouse it, or make it my self. do i need a fuel pump extra hoses perhaps? please help i doing the swap this week.
wrxsubiemod is offline   Reply With Quote
Old 10-30-2008, 09:13 PM   #2
Complacent_One
Member#: 163633
2002 RIP '02 Wagon
search for wrinkleboi threads started. There is plenty of information there to get you going. You need to ask yourself whether or not you feel like rewiring the entire car, or just using the wrx intake manifold and ecu with custom tune. I went with the 04 sti full swap into my 02 Wagon. It was a pain, but well worth it.
Needed parts for the full swap:
-04 STI engine w/ all the bells and whistles
-preferably 04 STI ecu - no immobilizer
-04 Sti Full harness (headlight to tailight)
-04 Sti Fuel pump carriage assembly
-04 STi Heater/AC box and blower box, w/ dash HVAC control
-DBW Go pedal adapter bracket
- sti instument cluster
if staying with the stock 5MT tranny, you will need to use the WRX clutch and flywheel or spend some time modding the tranny housing because the sti flywheel does not quite clear.
It took me just under 3 weeks to complete the swap on my own...spend just 2 or less hours an evening and juggling some weekend time into it. You will have to do a little bit of cut and splice...headlights, and a couple other places.
GOOD LUCK!!!
Complacent_One is offline   Reply With Quote
Old 10-30-2008, 11:09 PM   #3
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
What? Yeah im just going to go the easy route and just swap manifolds.
Old 10-31-2008, 09:54 AM   #4
THE-95-STi
Member#: 113734
1998 FSTi, 95 sold!
the JDM yO!(MAIC4LIFE)
yeah, I'm assuming your asking about the AVCS and what not, you want the STi long block right?
THE-95-STi is offline   Reply With Quote
Old 10-31-2008, 12:55 PM   #5
Crawford Support
Member#: 174347
2008 STI
Have you considered going with a hybrid setup. Basically just swapping in a 2.5L block, injectors, turbo, exhaust ?
Crawford Performance
Crawford Support is offline   Reply With Quote
Old 10-31-2008, 10:11 PM   #6
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
yes sir. did some research and found you get just about the same hp top end even if you dont got the avcs. is this true? ill probably never drop down 4k rmp. jk
Old 11-01-2008, 09:35 PM   #7
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
just to let people know if you are planning on doing the hybrid set up, and keeping the sti tgv's and fuel rails, you will need to cut splice and solder sti fuel injector plugs. its cheaper then buying sti pinks i think.
Old 11-01-2008, 09:40 PM   #8
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
for the hybrid set up, 04 sti crank position sensors dont need a special adaptor bracket! i already got one and found out that on the sti head, theirs a spot to mount a crank position sensor in the wrx's original position. all you need to do is tap a hole for it. I dont know if this will work for non 03 wrx to 04 swap.
Old 11-01-2008, 09:42 PM   #9
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
anyone can step up and put their 2 cents in. But this is just what i found out so far. ill keep up more posts if i find anything else
Old 11-06-2008, 10:49 PM   #10
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
I ran into another issue with the sti O2 sensor. the plugs are different then that of a 03 wrx. sense I damaged my wrx O2 sensor when removing the engine, and not wanting to spend 300 bucks on a new one. I bought a used 03 sensor. Dont be cheap like me. I finally started my new engine today and was suprised to see that it fired on the first try! I got a CEL though. it was PO something, having to do with the TGV sensor going bad. I just swapped it with the one off my wrx TGV and CEL was gone. All I need to do now is get a tune. Yeah.
04 sti 02 sensor wont work with 03 wrx ECU. got codes after words. sorry for the bad info.
Old 11-07-2008, 04:32 PM   #11
Bx_ReX
Member#: 86326
02 wagon
darkness
yea man def. gonna need a tune......if you still have your wrx heads, ur gonna need the cam gears..... shell run and all... but the avcs will be running fully advanced all the time, even at idle... which will make your car stall every now and then, this is the problem i have rite now...
Bx_ReX is offline   Reply With Quote
Old 11-08-2008, 06:01 PM   #12
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Dont tell me i need cam gears too! Do I? it runs fine.
dont need differant cam gears. its fine as long as the gears share the same pick up point. different versions come with differant pick up points so double check
Old 11-08-2008, 06:03 PM   #13
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
I dont think i posted this yet but i am running the sti avcs heads. I know avcs will not work, but whats up with the cam gears
Old 11-08-2008, 08:40 PM   #14
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
My car is back from GT motorsports and it ran at the tune of 300 HP and 300ft pounds of torque at the wheels! He said that he could of tuned it for more but He really couldnt mess with the timing because of the lack of AVCS. ow well. But honestly having that much horse power compared to what i used to have makes it all worth it! it runs like a champ. So if your thinking of going with the hybrid swap I would personally recommend it. just make sure you got a good tuner that knows what he is doing.
If anyone has questions please ask, i really didnt have the privalage of having someone that could answer all of mine. I hope any of this helps
Old 11-08-2008, 09:00 PM   #15
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
To list all the things i did in a short summary:
-buy sti long block.
-remove old 2.0 engine
-remove sti intake manifold with tgv's and wiring.
-remove wrx intake manifold with tgv's and wiring.
-now would be a good time to swap turbos
-Take sti tgv's, port them. keep the sensors or not. up to you.
-take the sti injector plugs and cut them off and solder them onto the wrx harness.
-install sti tgv with fuel lines and injectors onto the wrx intake manifold.
-install all of the 2.0 wrx engine wiring on to the injectors and sensors.
-install manifold with tgvs on to the 2.5 engine block.
-drill and tap a hole for the wrx crank position sensor on the driver side head. If you dont have a spot to tap a hole, they sell adapters form cosworth for like 60 bucks
-plug in your coil packs sensors and anything you can while engine is out.
-I had a six speed in my car but i was able to just reuse my sti light weight flywheel and stage 3 clutch from a wrx. i just swapped them.
-all is left for the engine now is to throw it back in. and plug in your factory wrx engine harness to the factory wrx chassis harness, lines and hoses.
-My 04 sti fuel pump did not work, so i bought a walbro 255. the turner said it helped.
-after all is said and done, go get yourself a tune. my car drove 4 miles to the nearist shop. It was ok for me I just made sure i did not boost.
Old 11-09-2008, 04:57 AM   #16
Bx_ReX
Member#: 86326
02 wagon
darkness
my swap is a 05 sti long block w/ wrx intake mani. ,, etc.....and the gruppe-s adapter.... i got her tuned and such, she runs hard and all, but kept on stalling at a red light or stop sign.... and lets say im on the highway,, and i wanna just let the car roll for what ever reason... shell just shut off... so i did some research and found this...
http://elementtuning.com/technical/ej25_install.htm
and i asked my tuner, and he called ECU-tek, and they said to do the same thing.... change the cam gears/sprockets.... all because of the cam position sensor for the wrx reads a different magnetic pulse from the gear, each time it turns...
they said thats the reason why the car always shuts off.... cause the avcs is fully advanced.. all the time, even at idle...dont know why.. but they are....im guessing when you unplug the avcs sensor, its a safty thing to keep them fully adv. so they wont choke the engine??? i really dont know... but this is the prob. im having..
sorry for being to long, i just wanna explain my prob. so you dont have to....
Old 11-09-2008, 10:46 AM   #17
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Im not saying dont do this, but that article you posted is saying that the two cam gears do have the same pick up points. And all we have to do is just swap out our wrx cam position sensor onto that driver side head location.
As to your stalling issue. maybe it can solve all of your problems, but id look deeper into it. I really want to know now, so please keep me updated.
Old 11-10-2008, 10:29 AM   #18
douthinkicare
Member#: 169054
2002 WRX vf22
white
I am looking to do the same thing avcs be damned i am on a buget with little room for downtime. Thanks for all the great info guys..
douthinkicare is offline   Reply With Quote
Old 11-10-2008, 11:57 PM   #19
ajohnson360
Member#: 169086
2002 Impreza WRX
Maroon
My swap right now is an 04 STi into my 02 WRX- It's at the mechanics and IN! HOWEVER the wiring is now the next question to tackle... Already I bought an 04 accelerator pedal but come to find out, that is not enough to make it work.... Apparently best/cheapest thing to do at this point is to use old ecu/harnesses/throttle body?
This is a great post thanks Bx_Rex and wrxsubiemod!!
ajohnson360 is offline   Reply With Quote
Old 11-20-2008, 03:17 PM   #20
benmoo
Member#: 193901
1998 Integra GS-R
Very interested in doing this hybrid swap, have a couple questions though.
From my understanding buying the complete '04 STi shortblock and mating it with the '02-'03 WRX head is plug and play except for that crank sensor. Will I be able to use the stock WRX harness/ECU/cluster with the hybrid setup? Also, will the car be able to pass CA SMOG with the stock ECU (maybe reflashed?) with the new block/turbo/etc. Would a front mount IC pose problems for emissions?
Hopefully I'll be able to find a 2002-2003 WRX with busted engine/body and swap in the engine with little incident...
benmoo is offline   Reply With Quote
Old 11-22-2008, 08:06 PM   #21
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
You can use your stock wrx crank sensor with a short block swap, or a long block swap. it would be exactly the same. This thread is about using 04 sti long block and mating the intake manifold and wiring onto a wrx. In my conditon it was a 03 wrx. I was able to use a wrx harness and ecu and cluster. the other things i had to change was the fuel pump, and some splicing. and of course a tune.
Old 11-24-2008, 10:24 AM   #22
benmoo
Member#: 193901
1998 Integra GS-R
What kind of tuning standalone/piggyback are you going to use? Is there any system that is compatible with OBDII diagnostics for SMOG testing?
Old 11-25-2008, 12:03 AM   #23
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Im using ECU teck. And the only problem im running is not having the AVCS. But i seriously dont care because if i want to go fast im going to be in a higher RPM range where AVCS doesnt really matter.
Old 12-03-2008, 02:11 PM   #24
ajohnson360
Member#: 169086
2002 Impreza WRX
Maroon
Post what now?
My mechanic and I are in the shop with a question of what to do next. HOW EXACTLY do I make the 02 ecu work with the avcs from the 04 motor? do I NEED to purchase something? Should we modify the intake to be avcs free?
Old 12-03-2008, 02:21 PM   #25
demartinoink
Member#: 164494
+1 for No AVCS!
demartinoink is offline   Reply With Quote
04 sti drivetrain swap into 03 wrx please help!!!! mike739wrx Transmission (AT/MT) & Driveline 6 03-15-2010 03:36 PM
05 STi Radio swap to 03 WRX? RelentlessWRX Car Audio, Video & Security 2 01-05-2008 08:23 AM
Swapping US 04 Sti struts into 02/03 WRX? edkwon Brakes, Steering & Suspension 2 07-22-2004 09:06 PM
04 STI engine in me 03 wrx drunkguy Subaru Conversions 4 03-29-2004 05:08 PM
wrx/sti engine swap to 1999 impreza L (2.2 MT) Qaveboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-10-2003 06:10 PM
