Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 10-27-2008, 11:16 PM   #1
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
Default Anyone removed an 08-09 WRX gauge cluster?
just wondering if it would be possible to remove the bulb for the TPMS warning light. I plan to have several sets of wheels (winter, summer, track) and don't want to deal with the idiot TPMS every time I change them.
How easy/difficult is it to remove the 08-09 gauge cluster?
irish44j is offline   Reply With Quote
Old 10-27-2008, 11:29 PM   #2
Impreza_R34
Member#: 186935
2004 Impreza OBS
Green/Gold
http://forums.nasioc.com/forums/show...php?p=23501256
This isn't exactly a "cluster removal" thread, it shows you how to remove the dash and get the radio and HVAC out, but they do tell you how to get the cluster off.
Impreza_R34 is offline   Reply With Quote
Old 10-27-2008, 11:34 PM   #3
irish44j
Member#: 191290
09 OPB SM WRXsedan
thanks, if it's anything like my other cars hopefully can pull the cluster without removng all the center console stuff. Then see if I can get to the light for the TPMS and disable/remove the bulb....
Old 10-28-2008, 01:37 AM   #4
Impreza_R34
Member#: 186935
2004 Impreza OBS
Green/Gold
If you can get it off, please post up exactly how you did so, if you don't mine. I'm planning on changing the color of mine.
Old 03-19-2010, 11:16 PM   #5
REDCHARGE
Member#: 187304
News
So I see no one ever did this?........I will be pulling the cluster tomorrow when I wake up .....to see if the led bulb can be pulled. If I cant pull it, then I will cover the tpms light .
REDCHARGE is offline   Reply With Quote
Old 03-25-2010, 01:24 AM   #6
Subarudave09
Member#: 209316
14 XV
if taken it out/
Pull on the cowl it will pop off
2 Phillps screws on the top take them out
Pull on the cluster to release the 2 pop pins one on each lower side
Remove wire plug
Push all clear tabs away from the white plastic
Cut a piece of electrical tape and cover the lighted section
Subarudave09 is offline   Reply With Quote
Old 04-01-2010, 08:27 PM   #7
whatsupdoc
Member#: 242930
Default how to take it off
As my 2010 speedo gauge is hard to read, the numbers are inside the dial and the needle sits on top... and the numbers did I say they are also SMALL?
Well,, I looked and behold. I found a WS manuls PM if you want it was pretty useless. I then place neon yellow pastel hash marks to WOW SLOW TFD!!
Caution on the removal of the wire harness and the imobiliser key system it was mentioned in the book. Not sure if it would mean reprograming. Call the dealer first.
Move the steering wheel down all the way and if it is telescoping all the way towards the seat. Now Take a firm grip on the very edge of the whole outside gauge cluster. visor, and at the clock positions of 11, 1, 4, 7 pulling directly towards you, that is towards the seat, with all your four hands ( april fools ) work your way around.
It should unclip, it is held in place with yellow plastic clips, that attach to the visor.
Also the glass i.e. scratches VERY easily
whatsupdoc is offline   Reply With Quote
Old 04-05-2010, 04:10 AM   #8
twentyclowns
Member#: 173176
2008 WRX sedan
Black OBP
you just pull the bezel behind the steering wheel out then unscrew the cluster, its actually pretty easy
twentyclowns is offline   Reply With Quote
Old 06-19-2010, 02:21 AM   #9
cbrrida
Member#: 244268
2010 WRX
WR Blue
Just order a second set of sensors..tire rack sells them pretty cheap.
cbrrida is offline   Reply With Quote
Old 06-19-2010, 06:49 PM   #10
nmalinoski
Member#: 220192
2009 WRX, WR Blue
But then he has to reactivate those sensors every time he swaps wheels, which is a pain. I find the ideal setup is to get a second TPMS box synced to that second set and swap it in when you swap your wheels. That way you retain the benefit of TPMS without completely disabling it. Others will have their opinions; this is mine.
nmalinoski is offline   Reply With Quote
Old 06-27-2010, 09:30 PM   #11
irish44j
Member#: 191290
09 OPB SM WRXsedan
wow, looks like this thread got bumped lol...
anyhow, I ended up just taking off the clear cover of the gauge cluster (5 minutes) and putting a tiny square piece of electrical tape over the TPMS warning light. It is almost invisible during the daytime unless you're looking specifically at it, and at night totally invisible and blocks all the light. An easier solution than taking crap apart, and easily reversible in the winter when my stock wheels/winter tires (with TPMS) are back on the car.
Old 06-27-2010, 09:31 PM   #12
irish44j
Member#: 191290
09 OPB SM WRXsedan
you have to get them reprogrammed every time you switch wheels, even if you have 2 sets of sensors (IIRC this costs like $40 at the dealer to do, every time). And I have 3 sets of wheels (summer, winter, track), so that would be quite inconvenient
Old 06-28-2011, 05:20 PM   #13
adstarr
Member#: 281168
I would love a copy of the WS Manual!! I need to pull out my cluster on my 2010 WRX also!!! Cheers Adam
adstarr is offline   Reply With Quote
Old 03-23-2014, 06:53 PM   #14
The04of518
Member#: 269322
2011 sti
I just pulled my dash out of my 2011 wrx cause i wanted to remove the tpms, and removing it only took 2 min. Pull trim off then its just 2 screws. Getting the gauge cluster apart took a little more time. After i got it apart i found that the lights are all leds that are soldered to the computer board im sure there is a way to remove them but i dont have the knowledge of that kind of stuff so i just did the "electrical tape trick". Anyone remove the leds from the board before?
The04of518 is offline   Reply With Quote
Old 03-23-2014, 07:38 PM   #15
2subiesinyard
Member#: 139562
2015 STi, 01 Fozzy
Blue n Gold
After a few years you don't even notice the light. Mines been light since 2010....and I have sensors in the wheels, but I'm to cheap to pay the dealer $45 dollars to do something that should be free.
2subiesinyard is offline   Reply With Quote
Does anyone know if an 08-10 WRX gauge cluster will go in a 02-07 WRX? 100_Percent_Juice Interior & Exterior Modification 32 04-04-2010 01:33 AM
70mm intake for an 08/09 WRX/STI? Anyone know of one? ntbass Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 11-03-2009 07:05 PM
08 - 06 wrx gauge cluster subadupa Subaru Conversions 0 09-25-2009 01:32 PM
Will a coilover for an 08/09 hatch work for an 08/09 sti? pio!pio! Brakes, Steering & Suspension 1 12-13-2008 07:28 PM
08-09 wrx cluster fit in a 06-07 wrx. sam n boo Interior & Exterior Modification 2 10-28-2008 12:23 PM
