Old 10-28-2008, 12:28 AM   #1
Rikshaman
Member#: 90817
Unhappy Ej20g fan wiring issue!
Quick question guys,
So far my swap has been running well, aside from this cooling issue ive been having.
I know i know, i should not use stant thermostats but i got it for free.
When driving on freeway, the car loses temp. after a few pulls, the needle begins to drop below normal. Im thinking this is either the fans or the thermostat issue.
also, once i pulled off my bliz nur spec, i was able to hear my fans running. They dont run when the car is idleing, but as im slowing down, i can hear them shutoff.
any ideas??
someone told me their probably wired wrong.
Thanks Guys!
Rikshaman is offline   Reply With Quote
Old 10-28-2008, 03:40 AM   #2
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
hey let me know if you need the wiring diagrams.
gc8awdsti is offline   Reply With Quote
Old 10-28-2008, 11:45 AM   #3
theonlygreat
Member#: 65916
1996 Impreza WRX
Fans are mostly ineffective over 25 mph, so your freeway issue is most likely due to the stant thermostat or a temp sensor problem.
theonlygreat is offline   Reply With Quote
Old 10-30-2008, 02:49 AM   #4
Rikshaman
Member#: 90817
Any ideas on the fan wiring guys?
Old 10-30-2008, 11:18 AM   #5
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
I agree. It sounds like the thermostat to me. My reasoning is if the fans kick on, but not at the right times, It would be the unit that controls them.
Are they two wire or three wire fans? Are they the stock fans?
subaruwrx is offline   Reply With Quote
Old 10-30-2008, 06:39 PM   #6
Rikshaman
Member#: 90817
They are the 3 wire jdm fans.
Old 10-30-2008, 06:55 PM   #7
madmax718
Member#: 172501
You got something funky. If your loosing temps on the highway in norcal, you've got a thermostat/water pump/coolant flow type issue, not a fan issue. I agree with all the other posts above, your fans are actually a hindrance to cooling at highway speeds. So if at highway speeds your loosing temp, I'd look first toward the thermostat.
madmax718 is offline   Reply With Quote
Old 10-31-2008, 04:46 AM   #8
Rikshaman
Member#: 90817
Yeah man,
I see what your saying. Honestly my car is a miracle in my opinion. I cannot believe it has stayed alive for so long. I went into this swap not knowing how to change my own oil. I came out of it with an intricate knowledge of my car. Now that im almost done with college, im still trying to fix the stuff i screwed up when i was in high school. This is a closed deck block 94 ej20g, and i beat the living crap out of it. I never beat on it cold, and i always let it idle down afterwards, but theres nothing better than throwing big flames merging freeway speeds at newer STi's. i dunno what to do, the car just loves freeway pulls. think i may need some help soon though, my car sounds like the tensioner is going out, or some really funny rod knock, only evident at 3k-4k rpm, anywho anyone wannu help assemble my spare motor with new headgaskets??????
Ok guys sorry for the rant,
Im just really drunk right now, and need to vent frustration with my car.
Rikshaman
last piece of the puzzle EJ20g fan wiring GregBolby Pre-2002 Factory Turbo Powertrain 2 08-23-2009 07:57 PM
ej20g...fan dosent come on at all. GripGC8 Pre-2002 Factory Turbo Powertrain 11 07-08-2008 02:27 AM
EJ20g brake booster issue! verendia Pre-2002 Factory Turbo Powertrain 12 11-20-2007 12:10 AM
EJ20G waterbox grumpster issues. anyone besides me? supermoose Subaru Conversions 20 09-28-2005 05:50 PM
EJ20G TWO wire O2 sensor AsphaltsCry Subaru Conversions 3 03-30-2005 01:01 PM
